[SCM] PostGIS branch master updated. 3.7.0beta2-10-g2b8bb15d7
Mon Aug 10 02:01:41 PDT 2026
the project "PostGIS".
       via  2b8bb15d7a3a872ce9f0f6f4e680f9edd8b7415a (commit)
       via  c7287d8a085581c37be947859c4b0cc285a83cd2 (commit)
      from  8b55c63cfa65a37dd0cabdf51782d589b62f8773 (commit)
revisions in full, below.
commit 2b8bb15d7a3a872ce9f0f6f4e680f9edd8b7415a
Merge: 8b55c63cf c7287d8a0
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Mon Aug 10 02:01:37 2026 -0700
    Merge pull request 'liblwgeom: reject overlong encoded polylines' (!715) from Komzpa/postgis:fix/encoded-polyline-shift-544518840 into master
    Encoded polyline coordinate varints were accumulated into a signed `int`, so malformed inputs could shift a high 5-bit group into the signed bit range under UBSAN. Decode the varint into a bounded unsigned accumulator instead, and reject truncated, invalid, or overlong coordinate varints before shifting them.
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/715
commit c7287d8a085581c37be947859c4b0cc285a83cd2
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Mon Aug 10 12:55:53 2026 +0400
    fix(liblwgeom): reject overlong encoded polylines
diff --git a/NEWS b/NEWS
index 024608787..258077332 100644
--- a/NEWS
+++ b/NEWS
@@ -8,6 +8,8 @@ These are only changes since 3.7.0beta2.
 * Bug Fixes *
+ - OSSFuzz 6152109301760000, reject overlong encoded polyline coordinate
+          varints (Darafei Praliaskouski)
diff --git a/liblwgeom/cunit/cu_in_encoded_polyline.c b/liblwgeom/cunit/cu_in_encoded_polyline.c
index 9cd4a7e1f..7fcb7841a 100644
--- a/liblwgeom/cunit/cu_in_encoded_polyline.c
+++ b/liblwgeom/cunit/cu_in_encoded_polyline.c
@@ -69,6 +69,13 @@ static void in_encoded_polyline_test_truncated_input(void)
 	CU_ASSERT_PTR_NULL(lwgeom_from_encoded_polyline("`", 5));
+static void
+in_encoded_polyline_test_overlong_varint(void)
+	/* OSSFuzz 6152109301760000: 17 << 30 must be rejected before shifting. */
+	CU_ASSERT_PTR_NULL(lwgeom_from_encoded_polyline("~~~~~~P", 5));
 ** Used by test harness to register the tests in this file.
@@ -80,4 +87,5 @@ void in_encoded_polyline_suite_setup(void)
 	PG_ADD_TEST(suite, in_encoded_polyline_test_precision);
 	PG_ADD_TEST(suite, in_encoded_polyline_test_close_points);
 	PG_ADD_TEST(suite, in_encoded_polyline_test_truncated_input);
+	PG_ADD_TEST(suite, in_encoded_polyline_test_overlong_varint);
diff --git a/liblwgeom/lwin_encoded_polyline.c b/liblwgeom/lwin_encoded_polyline.c
index d1af103ea..ef35d8c0f 100644
--- a/liblwgeom/lwin_encoded_polyline.c
+++ b/liblwgeom/lwin_encoded_polyline.c
@@ -32,6 +32,50 @@
 #include "lwgeom_log.h"
 #include "../postgis_config.h"
+static int
+encoded_polyline_read_varint(const char *encodedpolyline, int length, int *idx, uint32_t *value)
+	uint32_t res = 0;
+	unsigned int shift = 0;
+	while (1)
+		int byte;
+		if (*idx >= length)
+			lwerror("lwgeom_from_encoded_polyline: input is truncated");
+			return LW_FALSE;
+		byte = (unsigned char)encodedpolyline[(*idx)++] - 63;
+		if (byte < 0)
+			lwerror("lwgeom_from_encoded_polyline: input contains an invalid byte");
+			return LW_FALSE;
+		if (shift > 30 || (shift == 30 && ((byte & 0x1C) || (byte >= 0x20))))
+			lwerror("lwgeom_from_encoded_polyline: coordinate value is too large");
+			return LW_FALSE;
+		res |= (uint32_t)(byte & 0x1F) << shift;
+		if (byte < 0x20)
+			break;
+		shift += 5;
+	*value = res;
+	return LW_TRUE;
+static int32_t
+encoded_polyline_zigzag_decode(uint32_t value)
+	return (int32_t)((value >> 1) ^ (uint32_t)(-(int32_t)(value & 1)));
 LWGEOM*
 lwgeom_from_encoded_polyline(const char *encodedpolyline, int precision)
@@ -48,36 +92,22 @@ lwgeom_from_encoded_polyline(const char *encodedpolyline, int precision)
   while (idx < length) {
     POINT4D pt;
-    char byte = 0;
+    uint32_t res = 0;
-    int res = 0;
-    char shift = 0;
-    do {
-      if (idx >= length) {
-        lwerror("lwgeom_from_encoded_polyline: input is truncated");
-        ptarray_free(pa);
-        return NULL;
-      byte = encodedpolyline[idx++] - 63;
-      res |= (byte & 0x1F) << shift;
-      shift += 5;
-    } while (byte >= 0x20);
-    int32_t deltaLat = ((res & 1) ? ~(res >> 1) : (res >> 1));
+    if (!encoded_polyline_read_varint(encodedpolyline, length, &idx, &res))
+	    ptarray_free(pa);
+	    return NULL;
+    int32_t deltaLat = encoded_polyline_zigzag_decode(res);
     latitude += deltaLat;
-    shift = 0;
-    res = 0;
-    do {
-        ptarray_free(pa);
-        return NULL;
-      shift += 5;
-    int32_t deltaLon = ((res & 1) ? ~(res >> 1) : (res >> 1));
+	    ptarray_free(pa);
+	    return NULL;
+    int32_t deltaLon = encoded_polyline_zigzag_decode(res);
     longitude += deltaLon;
     pt.x = longitude/scale;
Summary of changes:
 NEWS                                     |  2 +
 liblwgeom/cunit/cu_in_encoded_polyline.c |  8 +++
 liblwgeom/lwin_encoded_polyline.c        | 86 +++++++++++++++++++++-----------
 3 files changed, 68 insertions(+), 28 deletions(-)
hooks/post-receive
