[PostGIS] #6111: Don't run test_check_news.py when not using git
PostGIS trac at osgeo.org
Mon Aug 10 05:22:52 PDT 2026
 Reporter:  Bas Couwenberg  |      Owner:  robe
     Type:  defect          |     Status:  new
 Priority:  medium          |  Milestone:  PostGIS 3.7.0
Component:  documentation   |    Version:  master
 Keywords:                  |
 The Debian package build for 3.7.0beta2 failed because git is not
 available in the build environment (it uses the release tarballs):
 make -C doc check
 make[3]: Entering directory '/build/postgis-3.7.0~beta2+dfsg/doc'
 /usr/bin/python3
 /build/postgis-3.7.0~beta2+dfsg/utils/docs/tests/test_docbook_qa.py
 Ran 39 tests in 0.064s
 OK
 make[3]: Leaving directory '/build/postgis-3.7.0~beta2+dfsg/doc'
 ! find . -name '*.c' -o -name '*.h' -o -name '*.proto' | \
         grep -v lwin_wkt_lex.c | \
         grep -v lwin_wkt_parse | \
         grep -v lookup3 | \
         grep -v vector_tile.pb-c | \
         grep -v postgis/sqldefines.h | \
         grep -v deps/ | \
         xargs grep -n '[[:space:]]$'
 ...E/usr/lib/python3.14/tempfile.py:961: ResourceWarning: Implicitly
 cleaning up <TemporaryDirectory '/tmp/tmpiz932xzj'>
   _warnings.warn(warn_message, ResourceWarning)
 E/usr/lib/python3.14/tempfile.py:961: ResourceWarning: Implicitly cleaning
 up <TemporaryDirectory '/tmp/tmpvly8rpy7'>
 up <TemporaryDirectory '/tmp/tmpj3m9u7f2'>
 up <TemporaryDirectory '/tmp/tmpgs8yeuqx'>
 up <TemporaryDirectory '/tmp/tmpu9306zm9'>
 up <TemporaryDirectory '/tmp/tmpkif2coxd'>
 up <TemporaryDirectory '/tmp/tmpb3k3_pe5'>
 up <TemporaryDirectory '/tmp/tmpmzi7ukke'>
 up <TemporaryDirectory '/tmp/tmp5t3lrgj4'>
 up <TemporaryDirectory '/tmp/tmpobfyb42i'>
 up <TemporaryDirectory '/tmp/tmpeavqleg4'>
 up <TemporaryDirectory '/tmp/tmpu4czyaas'>
 up <TemporaryDirectory '/tmp/tmprxgqpydx'>
 ERROR: test_duplicate_released_entry_fails
 (__main__.NewsValidationTest.test_duplicate_released_entry_fails)
   File
 "/build/postgis-3.7.0~beta2+dfsg/./utils/docs/tests/test_check_news.py",
 line 103, in setUp
     self.fixture = NewsFixture()
   File
 line 62, in __init__
     self.git("init", "--initial-branch=main")
   File
 line 74, in git
     return subprocess.run(
         ["git", *args],
     ...<3 lines>...
         capture_output=True,
   File "/usr/lib/python3.14/subprocess.py", line 555, in run
     with Popen(*popenargs, **kwargs) as process:
   File "/usr/lib/python3.14/subprocess.py", line 1039, in __init__
     self._execute_child(args, executable, preexec_fn, close_fds,
                         pass_fds, cwd, env,
     ...<5 lines>...
                         gid, gids, uid, umask,
                         start_new_session, process_group)
   File "/usr/lib/python3.14/subprocess.py", line 1990, in _execute_child
     raise child_exception_type(errno_num, err_msg, err_filename)
 FileNotFoundError: [Errno 2] No such file or directory: 'git'
 ERROR: test_x_placeholder_date_section_accepts_new_entries
 (__main__.NewsValidationTest.test_x_placeholder_date_section_accepts_new_entries)
   File
 line 103, in setUp
   File
   File
 line 74, in git
         ["git", *args],
     ...<3 lines>...
                         pass_fds, cwd, env,
     ...<5 lines>...
 Ran 16 tests in 0.037s
 FAILED (errors=13)
 make[2]: *** [GNUmakefile:103: check-news] Error 1
 make[2]: Leaving directory '/build/postgis-3.7.0~beta2+dfsg'
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6111>
