[PostGIS] #6113: 3.7.0beta2 visual examples build error
PostGIS trac at osgeo.org
Mon Aug 10 06:07:14 PDT 2026
 Reporter:  gdt      |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 3.6.5
Component:  postgis  |    Version:  3.6.x
 Keywords:           |
 Building 3.7.0beta2 under pkgsrc, it fails with a check about "visual
 examples" and a warning to build with a regress makefile.  At this point
 pkgsrc is only building, not building/running tests.
 gmake[1]: Entering directory '/tmp/work/databases/postgresql-
 postgis2/work/postgis-3.7.0beta2'
 /usr/pkg/bin/perl ./utils/repo_revision.pl
 fatal: not a git repository (or any parent up to mount point /)
 Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not set).
 Can't determine revision from git log
 Not updating existing rev file at 6e55c62
 /tmp/work/databases/postgresql-postgis2/work/.tools/bin/gmake -C doc html
 gmake[2]: Entering directory '/tmp/work/databases/postgresql-
 postgis2/work/postgis-3.7.0beta2/doc'
 /usr/pkg/bin/perl -pe "s!\@\@XSLBASE\@\@!/usr/pkg/share/xsl/docbook!g;
 s!\@\@ABS_SRCDIR\@\@!/tmp/work/databases/postgresql-
 postgis2/work/postgis-3.7.0beta2/doc!g;" /tmp/work/databases/postgresql-
 postgis2/work/postgis-3.7.0beta2/doc/xsl/postgis-html.xsl.in > postgis-
 html.xsl
 mkdir -p /tmp/work/databases/postgresql-
 postgis2/work/postgis-3.7.0beta2/doc/html
 /usr/pkg/bin/python3 /tmp/work/databases/postgresql-
 postgis2/work/postgis-3.7.0beta2/utils/docs/docbook_qa.py ref-index
 postgis-out.xml /tmp/work/databases/postgresql-
 postgis2/work/postgis-3.7.0beta2/doc/html/postgis-ref-index.json
 wrote /tmp/work/databases/postgresql-
 postgis2/work/postgis-3.7.0beta2/doc/html/postgis-ref-index.json and
 /tmp/work/databases/postgresql-postgis2/work/postgis-3.7.0beta2/doc/html
 /postgis-ref-index.js; commands=1, functions=630, operator pages=37, SQL
 keywords=63
 postgis2/work/postgis-3.7.0beta2/doc/html/images visual-examples-check
 gmake[3]: Entering directory '/tmp/work/databases/postgresql-
 postgis2/work/postgis-3.7.0beta2/doc/html/images'
 Visual examples are missing. Run 'make -C regress visual-examples' first.
 gmake[3]: *** [Makefile:52: visual-examples-check] Error 1
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6113>
