[SCM] PostGIS branch master updated. 3.7.0beta2-17-g46203ec75
git at osgeo.org
git at osgeo.org
Mon Aug 10 14:52:59 PDT 2026
the project "PostGIS".
via 46203ec75913d646be780030819af6a6578d6718 (commit)
via bd9e37cbd125c528313730b1fba52098b0c670ec (commit)
from 9e382377bc054c59b4ed4a0d8c431c82e2e86590 (commit)
revisions in full, below.
commit 46203ec75913d646be780030819af6a6578d6718
Merge: 9e382377b bd9e37cbd
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Mon Aug 10 14:52:58 2026 -0700
Merge pull request 'fuzzers: allocate GSERIALIZED bytea inputs by declared size' (!723) from Komzpa/postgis:fix/ossfuzz-gserialized-gbox-544807008 into master
The GSERIALIZED bytea fuzzer intentionally preserves the hostile varlena size header so malformed declared-size cases still reach the deserializer. When a testcase is shorter than that declared size, UBSAN builds do not provide allocator-size metadata, so the harness could manufacture a short allocation that the parser had no way to distinguish from the declared buffer.
Allocate and zero-fill the fuzzer copy up to a bounded declared GSERIALIZED size while leaving the input header untouched. That keeps the malformed-header coverage but lets the parser validate the declared buffer instead of the UBSAN harness reading past its allocation.
Credit to OSS-Fuzz: https://issues.oss-fuzz.com/issues/544807008
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/723
commit bd9e37cbd125c528313730b1fba52098b0c670ec
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Tue Aug 11 01:44:50 2026 +0400
Keep the hostile varlena size header intact, but allocate and zero-fill the fuzzer buffer up to the bounded declared size when the testcase bytes are shorter. This lets UBSAN builds exercise parser validation without walking past the fuzzer allocation.
diff --git a/NEWS b/NEWS
index 258077332..59a5c27c8 100644
--- a/NEWS
+++ b/NEWS
@@ -8,6 +8,8 @@ These are only changes since 3.7.0beta2.
* Bug Fixes *
+ - OSSFuzz 5607611131822080, keep GSERIALIZED bytea fuzzer allocations
+ consistent with hostile varlena size headers (Darafei Praliaskouski)
- OSSFuzz 6152109301760000, reject overlong encoded polyline coordinate
varints (Darafei Praliaskouski)
diff --git a/fuzzers/gserialized_from_bytea_fuzzer.cpp b/fuzzers/gserialized_from_bytea_fuzzer.cpp
index 087f97d3e..a62fb1c71 100644
--- a/fuzzers/gserialized_from_bytea_fuzzer.cpp
+++ b/fuzzers/gserialized_from_bytea_fuzzer.cpp
@@ -35,6 +35,8 @@ LLVMFuzzerInitialize(int * /*argc*/, char *** /*argv*/)
extern "C" int LLVMFuzzerTestOneInput(const uint8_t *buf, size_t len);
+static const size_t POSTGIS_FUZZER_MAX_GSERIALIZED_SIZE = 16 * 1024 * 1024;
static void
postgis_fuzzer_assert(int condition)
@@ -99,17 +101,25 @@ LLVMFuzzerTestOneInput(const uint8_t *buf, size_t len)
return 0;
- /* Copy exactly the bytes supplied by the fuzzer and leave g->size
- * untouched. The first four bytes are the PostgreSQL varlena size
- * header read through LWSIZE_GET(), and they are attacker-controlled
- * when GSERIALIZED arrives from a damaged page, binary COPY, bytea cast,
- * or hostile dump. Rewriting the header to len would make every input
- * self-consistent and hide the over-declared-size cases this target is
- * meant to exercise.
+ uint32_t size_header;
+ memcpy(&size_header, buf, sizeof(size_header));
+ const size_t declared_size = LWSIZE_GET(size_header);
+ if (declared_size > POSTGIS_FUZZER_MAX_GSERIALIZED_SIZE)
+ return 0;
+ const size_t allocation_size = declared_size > len ? declared_size : len;
+ /* Leave the varlena size header untouched. The first four bytes are
+ * attacker-controlled when GSERIALIZED arrives from a damaged page,
+ * binary COPY, bytea cast, or hostile dump. When the declared size is
+ * larger than the supplied testcase, zero-fill the missing tail so the
+ * parser can validate the declared buffer without UBSAN builds reading
+ * past the fuzzer allocation.
- GSERIALIZED *gserialized = static_cast<GSERIALIZED *>(postgis_lwgeom_fuzzer_malloc(len));
+ GSERIALIZED *gserialized = static_cast<GSERIALIZED *>(postgis_lwgeom_fuzzer_malloc(allocation_size));
if (gserialized == NULL)
return 0;
+ memset(gserialized, 0, allocation_size);
memcpy(gserialized, buf, len);
LWGEOM *lwgeom = lwgeom_from_gserialized(gserialized);
Summary of changes:
NEWS | 2 ++
fuzzers/gserialized_from_bytea_fuzzer.cpp | 26 ++++++++++++++++++--------
2 files changed, 20 insertions(+), 8 deletions(-)
hooks/post-receive
