[SCM] PostGIS branch master updated. 3.7.0beta2-19-g2b660395d
Mon Aug 10 15:01:50 PDT 2026
the project "PostGIS".
       via  2b660395d68955fff632ec1774d2f04698edb6d2 (commit)
       via  4434b8dee7b7dc5a61af35251ff7c3cad3ad6fb1 (commit)
      from  46203ec75913d646be780030819af6a6578d6718 (commit)
revisions in full, below.
commit 2b660395d68955fff632ec1774d2f04698edb6d2
Merge: 46203ec75 4434b8dee
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Mon Aug 10 15:01:49 2026 -0700
    Merge pull request 'liblwgeom: reject malformed GSERIALIZED polygon rings' (!724) from Komzpa/postgis:fix/ossfuzz-544800490-gserialized2-poly into master
    Reject non-empty polygon rings with fewer than four points while deserializing v1/v2 GSERIALIZED payloads. This prevents malformed bytea inputs from constructing an LWPOLY that later crashes in gserialized2_from_lwpoly during fuzzer roundtrip serialization.
    Credit to OSS-Fuzz.
    OSS-Fuzz issue: https://issues.oss-fuzz.com/issues/544800490
    Validation:
    - git clang-format upstream/master
    - make -C liblwgeom -j$(nproc) && make -C liblwgeom/cunit check
    - UBSAN_OPTIONS=exitcode=77:silence_unsigned_overflow=1 gserialized_from_bytea_fuzzer testcase 5672880541859840
    - make -C fuzzers dummyfuzzers FUZZER_OUT=/tmp/postgis-ossfuzz-544800490-fuzzout-rebased built gserialized_from_bytea_fuzzer, then stopped later at raster_deserialize_fuzzer because this local checkout was configured without raster_config.h
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/724
commit 4434b8dee7b7dc5a61af35251ff7c3cad3ad6fb1
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Tue Aug 11 01:54:59 2026 +0400
    fix(liblwgeom): reject malformed GSERIALIZED polygon rings
    Validate non-empty polygon ring point counts while deserializing GSERIALIZED buffers so malformed inputs cannot build LW polygons with too few ring points and crash during later serialization.
    Credit to OSS-Fuzz.
diff --git a/NEWS b/NEWS
index 59a5c27c8..46206a39f 100644
--- a/NEWS
+++ b/NEWS
@@ -10,6 +10,8 @@ These are only changes since 3.7.0beta2.
  - OSSFuzz 5607611131822080, keep GSERIALIZED bytea fuzzer allocations
           consistent with hostile varlena size headers (Darafei Praliaskouski)
+ - OSSFuzz 544800490, reject malformed GSERIALIZED polygon rings before
+          deserializing geometry data (Darafei Praliaskouski)
  - OSSFuzz 6152109301760000, reject overlong encoded polyline coordinate
           varints (Darafei Praliaskouski)
diff --git a/liblwgeom/cunit/cu_gserialized1.c b/liblwgeom/cunit/cu_gserialized1.c
index a4ae77056..cfc49bcc7 100644
--- a/liblwgeom/cunit/cu_gserialized1.c
+++ b/liblwgeom/cunit/cu_gserialized1.c
@@ -1251,6 +1251,43 @@ assert_gserialized1_malformed_rejected(GSERIALIZED *g)
 	CU_ASSERT_EQUAL(gserialized1_peek_first_point(g, &point), LW_FAILURE);
+static uint8_t *
+gserialized1_test_payload_p(GSERIALIZED *g)
+	return (uint8_t *)(void *)g + gserialized1_header_size(g);
+static void
+test_gserialized1_malformed_polygon_ring_count(void)
+	LWGEOM *lwgeom = lwgeom_from_wkt("POLYGON((0 0, 1 0, 1 1, 0 0))", LW_PARSER_CHECK_NONE);
+	LWGEOM *malformed_lwgeom;
+	GSERIALIZED *g;
+	uint8_t *payload;
+	uint32_t type;
+	uint32_t nrings;
+	uint32_t npoints = 1;
+	CU_ASSERT_PTR_NOT_NULL_FATAL(lwgeom);
+	g = gserialized1_from_lwgeom(lwgeom, NULL);
+	CU_ASSERT_PTR_NOT_NULL_FATAL(g);
+	payload = gserialized1_test_payload_p(g);
+	memcpy(&type, payload, sizeof(type));
+	memcpy(&nrings, payload + sizeof(uint32_t), sizeof(nrings));
+	CU_ASSERT_EQUAL(type, POLYGONTYPE);
+	CU_ASSERT_EQUAL(nrings, 1);
+	memcpy(payload + 2 * sizeof(uint32_t), &npoints, sizeof(npoints));
+	cu_error_msg_reset();
+	malformed_lwgeom = lwgeom_from_gserialized1(g);
+	CU_ASSERT_PTR_NULL(malformed_lwgeom);
+	CU_ASSERT_NOT_EQUAL(strlen(cu_error_msg), 0);
+	lwgeom_free(lwgeom);
+	lwfree(g);
 static void
 test_gserialized1_malformed_declared_size(void)
@@ -1305,5 +1342,6 @@ void gserialized1_suite_setup(void)
 	PG_ADD_TEST(suite, test_gbox_same_2d);
 	PG_ADD_TEST(suite, test_signum_macro);
 	PG_ADD_TEST(suite, test_gserialized1_peek_first_point);
+	PG_ADD_TEST(suite, test_gserialized1_malformed_polygon_ring_count);
 	PG_ADD_TEST(suite, test_gserialized1_malformed_declared_size);
diff --git a/liblwgeom/cunit/cu_gserialized2.c b/liblwgeom/cunit/cu_gserialized2.c
index c60b0f56b..61cdf5a80 100644
--- a/liblwgeom/cunit/cu_gserialized2.c
+++ b/liblwgeom/cunit/cu_gserialized2.c
@@ -589,6 +589,37 @@ test_gserialized2_malformed_nurbs_degree(void)
 	lwfree(g);
+static void
+test_gserialized2_malformed_polygon_ring_count(void)
+	GSERIALIZED *g;
+	uint8_t *payload;
+	uint32_t type;
+	uint32_t nrings;
+	g = gserialized2_from_lwgeom(lwgeom, NULL);
+	payload = gserialized2_test_payload_p(g);
+	malformed_lwgeom = lwgeom_from_gserialized2(g);
+	lwfree(g);
 static void
 assert_gserialized2_malformed_rejected(GSERIALIZED *g)
@@ -703,6 +734,7 @@ void gserialized2_suite_setup(void)
 	PG_ADD_TEST(suite, test_gserialized2_peek_first_point);
 	PG_ADD_TEST(suite, test_gserialized2_malformed_collection_count);
 	PG_ADD_TEST(suite, test_gserialized2_malformed_nurbs_degree);
+	PG_ADD_TEST(suite, test_gserialized2_malformed_polygon_ring_count);
 	PG_ADD_TEST(suite, test_gserialized2_malformed_declared_size);
 	PG_ADD_TEST(suite, test_gserialized2_malformed_short_allocation);
 	PG_ADD_TEST(suite, test_gserialized2_wkb_roundtrip_float_rounded_box);
diff --git a/liblwgeom/gserialized1.c b/liblwgeom/gserialized1.c
index 4528a790f..2c68f2c71 100644
--- a/liblwgeom/gserialized1.c
+++ b/liblwgeom/gserialized1.c
@@ -273,6 +273,17 @@ gserialized1_pointarray_payload_size(uint32_t npoints, lwflags_t lwflags, size_t
 	return LW_SUCCESS;
+static int
+gserialized1_validate_polygon_ring_count(uint32_t npoints)
+	if (npoints > 0 && npoints < 4)
+		lwerror("%s: invalid non-empty polygon ring point count %u", __func__, npoints);
+		return LW_FAILURE;
+	return LW_SUCCESS;
 static int
 gserialized1_validate_geometry_buffer(uint8_t *data_ptr, uint8_t *data_end, lwflags_t lwflags, size_t *size)
@@ -1515,6 +1526,12 @@ static LWPOLY* lwpoly_from_gserialized1_buffer(uint8_t *data_ptr, lwflags_t lwfl
 		/* Read in the number of points. */
 		npoints = gserialized1_get_uint32_t(data_ptr);
 		data_ptr += 4;
+		if (gserialized1_validate_polygon_ring_count(npoints) == LW_FAILURE)
+			poly->nrings = i;
+			lwpoly_free(poly);
+			return NULL;
 		/* Make a point array for the ring, and move the ordinate pointer past the ring ordinates. */
 		poly->rings[i] = ptarray_construct_reference_data(FLAGS_GET_Z(lwflags), FLAGS_GET_M(lwflags), npoints, ordinate_ptr);
@@ -1718,7 +1735,10 @@ LWGEOM* lwgeom_from_gserialized1(const GSERIALIZED *g)
 	lwgeom = lwgeom_from_gserialized1_buffer(data_ptr, lwflags, &size);
 	if ( ! lwgeom )
 		lwerror("%s: unable create geometry", __func__); /* Ooops! */
+		return NULL;
 	lwgeom->type = lwtype;
 	lwgeom->flags = lwflags;
diff --git a/liblwgeom/gserialized2.c b/liblwgeom/gserialized2.c
index 7a89593c6..d8169979a 100644
--- a/liblwgeom/gserialized2.c
+++ b/liblwgeom/gserialized2.c
@@ -398,6 +398,17 @@ gserialized2_pointarray_payload_size(uint32_t npoints, lwflags_t lwflags, size_t
 	return LW_SUCCESS;
+static int
+gserialized2_validate_polygon_ring_count(uint32_t npoints)
 static int
 gserialized2_validate_geometry_buffer(uint8_t *data_ptr, uint8_t *data_end, lwflags_t lwflags, size_t *size)
@@ -2054,6 +2065,12 @@ lwpoly_from_gserialized2_buffer(uint8_t *data_ptr, lwflags_t lwflags, size_t *si
 		npoints = gserialized2_get_uint32_t(data_ptr);
 		data_ptr += 4;
+		if (gserialized2_validate_polygon_ring_count(npoints) == LW_FAILURE)
+			poly->nrings = i;
+			return NULL;
@@ -2484,7 +2501,10 @@ LWGEOM* lwgeom_from_gserialized2(const GSERIALIZED *g)
 	lwgeom = lwgeom_from_gserialized2_buffer(data_ptr, lwflags, &size, srid);
 	if (!lwgeom)
+		return NULL;
Summary of changes:
 NEWS                              |  2 ++
 liblwgeom/cunit/cu_gserialized1.c | 38 ++++++++++++++++++++++++++++++++++++++
 liblwgeom/cunit/cu_gserialized2.c | 32 ++++++++++++++++++++++++++++++++
 liblwgeom/gserialized1.c          | 20 ++++++++++++++++++++
 liblwgeom/gserialized2.c          | 20 ++++++++++++++++++++
 5 files changed, 112 insertions(+)
hooks/post-receive
