[SCM] PostGIS branch master updated. 3.7.0beta2-21-g5de061ff1
git at osgeo.org
git at osgeo.org
Tue Aug 11 06:10:39 PDT 2026
the project "PostGIS".
via 5de061ff1c8e927e25ae3aa8c6a48d69f2ae093f (commit)
via 809ca7e307cfc0d81b5adbf0c0a0c806c5367451 (commit)
from 2b660395d68955fff632ec1774d2f04698edb6d2 (commit)
revisions in full, below.
commit 5de061ff1c8e927e25ae3aa8c6a48d69f2ae093f
Merge: 2b660395d 809ca7e30
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Tue Aug 11 06:10:37 2026 -0700
Merge pull request 'fuzzers: compare serialized LWGEOM bboxes by stored flags' (!725) from Komzpa/postgis:fix/ossfuzz-544936363-gserialized-lwgeom into master
The `gserialized_from_lwgeom_fuzzer` bbox oracle was still assuming that the
parsed input bbox metadata is the exact metadata that `GSERIALIZED` will write
back out.
Malformed WKB can leave the input geometry flags and input bbox flags out of
sync. `GSERIALIZED` serializes the bbox according to the geometry flags, so a
round trip can legitimately return a bbox with different serialized metadata
while preserving the geometry payload. This updates the fuzzer oracle to build
the expected bbox using the serialized geometry flags, include the geodetic Z
ordinates written by `GSERIALIZED`, and avoid treating NaN payload differences
as a fuzzer crash.
References: https://issues.oss-fuzz.com/issues/544936363
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/725
commit 809ca7e307cfc0d81b5adbf0c0a0c806c5367451
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Tue Aug 11 17:05:52 2026 +0400
The GSERIALIZED-from-LWGEOM fuzzer used the parsed input bbox as the direct oracle for the round-tripped bbox. Malformed WKB can carry bbox flags that do not match the geometry flags; serialization writes the bbox according to the geometry flags, so the round trip can legitimately return different serialized bbox metadata while preserving geometry semantics.
Build the expected bbox with the serialized geometry flags, include the geodetic Z ordinates that GSERIALIZED writes, and treat NaN payload differences as equal for this oracle.
Credit to OSS-Fuzz.
diff --git a/NEWS b/NEWS
index 46206a39f..70eda4519 100644
--- a/NEWS
+++ b/NEWS
@@ -12,6 +12,8 @@ These are only changes since 3.7.0beta2.
consistent with hostile varlena size headers (Darafei Praliaskouski)
- OSSFuzz 544800490, reject malformed GSERIALIZED polygon rings before
deserializing geometry data (Darafei Praliaskouski)
+ - OSSFuzz 544936363, keep GSERIALIZED LWGEOM fuzzer bbox
+ comparisons aligned with serialized bbox flags (Darafei Praliaskouski)
- OSSFuzz 6152109301760000, reject overlong encoded polyline coordinate
varints (Darafei Praliaskouski)
diff --git a/fuzzers/gserialized_from_lwgeom_fuzzer.cpp b/fuzzers/gserialized_from_lwgeom_fuzzer.cpp
index b6f2445c5..83eb93315 100644
--- a/fuzzers/gserialized_from_lwgeom_fuzzer.cpp
+++ b/fuzzers/gserialized_from_lwgeom_fuzzer.cpp
@@ -16,6 +16,7 @@
#include <stddef.h>
#include <stdint.h>
#include <stdlib.h>
+#include <math.h>
extern "C" {
#include "geos_stub.h"
@@ -42,6 +43,39 @@ postgis_fuzzer_assert(int condition)
abort();
+static int
+same_serialized_double(double expected, double actual)
+ if (isnan(expected) && isnan(actual))
+ return LW_TRUE;
+ return expected == actual;
+static int
+same_serialized_gbox(const GBOX *expected, const GBOX *actual)
+ if (FLAGS_GET_ZM(expected->flags) != FLAGS_GET_ZM(actual->flags))
+ return LW_FALSE;
+ if (!same_serialized_double(expected->xmin, actual->xmin) ||
+ !same_serialized_double(expected->xmax, actual->xmax) ||
+ !same_serialized_double(expected->ymin, actual->ymin) ||
+ !same_serialized_double(expected->ymax, actual->ymax))
+ return LW_FALSE;
+ if ((FLAGS_GET_Z(expected->flags) || FLAGS_GET_GEODETIC(expected->flags)) &&
+ (!same_serialized_double(expected->zmin, actual->zmin) ||
+ !same_serialized_double(expected->zmax, actual->zmax)))
+ return LW_FALSE;
+ if (FLAGS_GET_M(expected->flags) && (!same_serialized_double(expected->mmin, actual->mmin) ||
+ !same_serialized_double(expected->mmax, actual->mmax)))
+ return LW_FALSE;
+ return LW_TRUE;
static void
assert_matching_gbox(const LWGEOM *input, const LWGEOM *roundtrip)
@@ -56,8 +90,14 @@ assert_matching_gbox(const LWGEOM *input, const LWGEOM *roundtrip)
/* GSERIALIZED stores a float-rounded bbox. */
expected = *input->bbox;
+ expected.flags = input->flags;
gbox_float_round(&expected);
- postgis_fuzzer_assert(gbox_same(&expected, roundtrip->bbox));
+ if (FLAGS_GET_GEODETIC(expected.flags) && !FLAGS_GET_Z(expected.flags))
+ expected.zmin = next_float_down(expected.zmin);
+ expected.zmax = next_float_up(expected.zmax);
+ postgis_fuzzer_assert(same_serialized_gbox(&expected, roundtrip->bbox));
static void
Summary of changes:
NEWS | 2 ++
fuzzers/gserialized_from_lwgeom_fuzzer.cpp | 42 +++++++++++++++++++++++++++++-
2 files changed, 43 insertions(+), 1 deletion(-)
hooks/post-receive
