[SCM] PostGIS branch master updated. 3.7.0beta2-23-gac50b1860
git at osgeo.org
git at osgeo.org
Tue Aug 11 07:37:17 PDT 2026
the project "PostGIS".
via ac50b1860aafaa3aa7dbc24466db64d01b1ea88a (commit)
via 4e5b21e1bd3a137c13bbe2c2ed92af8b41b3d977 (commit)
from 5de061ff1c8e927e25ae3aa8c6a48d69f2ae093f (commit)
revisions in full, below.
commit ac50b1860aafaa3aa7dbc24466db64d01b1ea88a
Merge: 5de061ff1 4e5b21e1b
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Tue Aug 11 07:37:15 2026 -0700
Merge pull request 'docs: document GMP build dependency' (!726) from Komzpa/postgis:codex/ticket-6112-readme-gmp into master
README.postgis now documents the current build dependency contract and points readers at the generated compatibility browser for the maintained support matrix. It updates PostgreSQL 14+, libgmp-dev and pkg-config in the apt dependency example, GDAL 2.4+ for raster builds, SFCGAL minimum/full-feature wording, and the compatibility-browser-derived iconv, gettext, protobuf-c, and GTK classifications.
The same dependency-version sweep also updates current manual/release docs: NEWS records the #6112 README dependency documentation fix for 3.7.0rc1, doc/postgis.xml carries the current PostgreSQL and GEOS entity values, installation docs align GEOS/GDAL/SFCGAL wording, release_notes.xml uses PostgreSQL 19beta2, and the dependency guard example uses the current SFCGAL 2.3 threshold.
Closes https://trac.osgeo.org/postgis/ticket/6112
Closes #6112
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/726
commit 4e5b21e1bd3a137c13bbe2c2ed92af8b41b3d977
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Tue Aug 11 17:44:43 2026 +0400
Closes #6112
diff --git a/NEWS b/NEWS
index 70eda4519..61540a408 100644
--- a/NEWS
+++ b/NEWS
@@ -10,6 +10,8 @@ These are only changes since 3.7.0beta2.
- OSSFuzz 5607611131822080, keep GSERIALIZED bytea fuzzer allocations
consistent with hostile varlena size headers (Darafei Praliaskouski)
+ - #6112, Document GMP and current build dependency requirements in
+ README.postgis (Darafei Praliaskouski)
- OSSFuzz 544800490, reject malformed GSERIALIZED polygon rings before
deserializing geometry data (Darafei Praliaskouski)
- OSSFuzz 544936363, keep GSERIALIZED LWGEOM fuzzer bbox
diff --git a/README.postgis b/README.postgis
index 6817356cf..1ab49a34c 100644
--- a/README.postgis
+++ b/README.postgis
@@ -35,24 +35,31 @@ Directory structure::
REQUIREMENTS
-PostGIS is compatible with PostgreSQL 12 and above.
+PostGIS is compatible with PostgreSQL 14 and above.
+Current release, PostgreSQL, dependency, and packaging support details are
+maintained in the PostGIS compatibility browser:
+ https://postgis.net/development/compatibility/
You *must* have the full PostgreSQL - including server headers - installed for
this to work.
-For apt-based systems you can run this command to install the below dependencies (except for GTK):
+For apt-based GNU/Linux systems you can run this command to install most of the
+below dependencies (except for GTK):
sudo apt-get install \
docbook-xsl-ns \
gettext \
libgdal-dev \
libgeos-dev \
+ libgmp-dev \
libjson-c-dev \
libproj-dev \
libprotobuf-c-dev \
libsfcgal-dev \
libxml2-dev \
libxml2-utils \
+ pkg-config \
protobuf-c-compiler \
xsltproc
@@ -82,11 +89,23 @@ For apt-based systems you can run this command to install the below dependencies
http://xmlsoft.org/
-* GNU gettext
+* GMP (Required):
- The loader, and hence PostGIS, requires GNU gettext 0.14 or higher
- for translation support
- (typically in libc on GNU/Linux, in which case 0.17 is required).
+ The GMP arbitrary precision arithmetic library is required by PostGIS
+ topology support.
+ https://gmplib.org
+* iconv/libiconv (Required):
+ The iconv conversion library is required by the shp2pgsql loader for encoding
+ conversion. On GNU/Linux systems it is typically provided by libc; on other
+ platforms you may need a separate libiconv package.
+* GNU gettext (Optional)
+ GNU gettext is used for loader and documentation translation support. It may
+ be disabled with ``--with-gettext=no``.
* JSON-C (Optional, Version 0.9 or higher)
@@ -94,26 +113,26 @@ For apt-based systems you can run this command to install the below dependencies
http://github.com/json-c/json-c/wiki
-* GDAL (Optional, Version 2 or higher 3+ is strongly recommended)
+* GDAL (Required for raster, Version 2.4 or higher 3+ is strongly recommended)
GDAL (https://gdal.org) is *required* if you want to compile PostGIS
with raster support. To compile without raster support you
must ``./configure --without-raster``
-* CGAL 5+ and SFCGAL 1.4+ (Optional) needed for advanced 3D support
-* SFCGAL 2.1.0 is required for additional functionality.
+* SFCGAL 1.3.1+ (Optional) needed for advanced 3D support
+* SFCGAL 2.3+ is required for all postgis_sfcgal extension features.
https://sfcgal.gitlab.io/sfcgal
* protobuf-c (Optional, Version 1.1.0 or higher)
- The protobuf-c library and compiler is required for ST_AsMVT and
+ The protobuf-c library and compiler are required to enable ST_AsMVT and
ST_AsGeobuf output. Also, pkg-config is required to verify the correct
minimum version of protobuf-c.
https://github.com/protobuf-c/protobuf-c
-* GTK (Optional, Version 2 series: 2.2.0 or higher)
+* GTK (Optional, Version 2 series: 2.8.0 or higher)
The GTK library is required to build the GUI version of shp2pgsql
loader.
diff --git a/doc/development/release/dependencies.md b/doc/development/release/dependencies.md
index df91edbe5..b7e4530d6 100644
--- a/doc/development/release/dependencies.md
+++ b/doc/development/release/dependencies.md
@@ -45,17 +45,17 @@ endif
SFCGAL guards appear in C files:
```c
-#if POSTGIS_SFCGAL_VERSION >= 20100
-/* SFCGAL 2.1+ required */
+#if POSTGIS_SFCGAL_VERSION >= 20300
+/* SFCGAL 2.3+ required */
#endif
Add matching test guards in `sfcgal/regress/tests.mk.in`:
```make
-ifeq ($(shell expr "$(POSTGIS_SFCGAL_VERSION)" ">=" 20100),1)
+ifeq ($(shell expr "$(POSTGIS_SFCGAL_VERSION)" ">=" 20300),1)
TESTS += \
- my_sfcgal_201_test
+ my_sfcgal_203_test
endif
diff --git a/doc/installation.xml b/doc/installation.xml
index cc5526ac4..69cad523a 100644
--- a/doc/installation.xml
+++ b/doc/installation.xml
@@ -185,7 +185,7 @@ sh autogen.sh
<listitem>
<para>
- GEOS geometry library, version &min_geos_version; or greater, but GEOS 3.14+ is required to take full advantage of all the new functions and features. GEOS is available for download from
+ GEOS geometry library, version &min_geos_version; or greater, but GEOS 3.15+ is required to take full advantage of all the new functions and features. GEOS is available for download from
<link xlink:href="https://libgeos.org/">
https://libgeos.org
</link>.
@@ -216,8 +216,8 @@ sh autogen.sh
<listitem>
<para>
- GDAL, version 3+ is preferred. This is required for raster
- support.
+ GDAL, version 2.4 or higher, is required for raster support.
+ GDAL 3+ is preferred.
<link xlink:href="https://gdal.org/download.html">https://gdal.org/download.html</link>.
</para>
</listitem>
@@ -255,7 +255,7 @@ sh autogen.sh
<listitem>
<para>
- SFCGAL, 1.4.1 or higher is required,
+ SFCGAL, 1.3.1 or higher is required,
2.3+ is needed to be able to use all functionality.
SFCGAL can be used to provide additional 2D and 3D advanced
analysis functions to PostGIS cf <xref linkend="reference_sfcgal"/>.
diff --git a/doc/postgis.xml b/doc/postgis.xml
index 9e9e2e677..e6566362e 100644
--- a/doc/postgis.xml
+++ b/doc/postgis.xml
@@ -14,9 +14,9 @@
<!-- Change these values to update the version numbers referenced within the documentation -->
<!ENTITY last_proj_release_version "9.2.1">
<!ENTITY last_geos_release_version "3.14.0">
-<!ENTITY min_geos_version "3.8.0">
+<!ENTITY min_geos_version "3.10.0">
<!ENTITY min_postgres_version "14">
-<!ENTITY max_postgres_version "18">
+<!ENTITY max_postgres_version "19beta2">
<!ENTITY introduction SYSTEM "introduction.xml">
<!ENTITY credits SYSTEM "credits.xml">
diff --git a/doc/release_notes.xml b/doc/release_notes.xml
index 277b64485..3958a7e9f 100644
--- a/doc/release_notes.xml
+++ b/doc/release_notes.xml
@@ -4,7 +4,7 @@
<section xml:id="release_notes_3_7_0">
<title>PostGIS 3.7.0</title>
<subtitle>2026/xx/xx</subtitle>
- <para>This version requires GEOS 3.10+, PostgreSQL 14-19beta1, Proj 6.1+, libgmp. To take advantage of all features postgis extension features, GEOS 3.15+ is needed. To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed.</para>
+ <para>This version requires GEOS 3.10+, PostgreSQL 14-19beta2, Proj 6.1+, libgmp. To take advantage of all features postgis extension features, GEOS 3.15+ is needed. To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed.</para>
<simplesect>
<title>Breaking Changes</title>
<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5688">#5688</link>, [topology] topology building functions now interpret tolerance 0 (old default) to really mean 0 and want -1 (new default) to mean "use topology precision" (Sandro Santilli)</para>
Summary of changes:
NEWS | 2 ++
README.postgis | 41 ++++++++++++++++++++++++---------
doc/development/release/dependencies.md | 8 +++----
doc/installation.xml | 8 +++----
doc/postgis.xml | 4 ++--
doc/release_notes.xml | 2 +-
6 files changed, 43 insertions(+), 22 deletions(-)
hooks/post-receive
