[SCM] PostGIS branch master updated. 3.7.0beta2-25-g369235b92
Tue Aug 11 07:52:16 PDT 2026
the project "PostGIS".
       via  369235b92e0d03584916c42bf074cd02122addb9 (commit)
       via  b45a1f078a93b84ef5dc95685e408b5970a4e71a (commit)
      from  ac50b1860aafaa3aa7dbc24466db64d01b1ea88a (commit)
revisions in full, below.
commit 369235b92e0d03584916c42bf074cd02122addb9
Merge: ac50b1860 b45a1f078
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Tue Aug 11 07:52:14 2026 -0700
    Merge pull request 'build: skip NEWS unit tests outside Git worktrees' (!727) from Komzpa/postgis:codex/ticket-6111-check-news-no-git into master
    Skip the Python NEWS unit tests when the source tree is not a Git worktree, while still running the shell NEWS checks that do not require Git history. This fixes source package documentation checks in build environments where git is absent.
    Patch by Bas Couwenberg.
    Closes https://trac.osgeo.org/postgis/ticket/6111
    Closes #6111
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/727
commit b45a1f078a93b84ef5dc95685e408b5970a4e71a
Author: Bas Couwenberg <sebastic at debian.org>
Date:   Tue Aug 11 18:48:16 2026 +0400
    The NEWS Python unit tests create temporary Git repositories, so release-tarball builds without git cannot run them. Skip those unit tests when the source tree is not a Git worktree, while still running the shell NEWS checks that do not need Git history.
    Closes #6111
diff --git a/GNUmakefile.in b/GNUmakefile.in
index 75824f48a..5c7f83717 100644
--- a/GNUmakefile.in
+++ b/GNUmakefile.in
@@ -100,7 +100,9 @@ visual-examples: staged-install
 	$(MAKE) -C regress visual-examples-run
 check-news:
-	@if test -z "$(PYTHON3)"; then \
+	@if test ! -e "$(top_srcdir)/.git"; then \
+		echo "SKIP: NEWS unit tests require a Git worktree"; \
+	elif test -z "$(PYTHON3)"; then \
 		echo "SKIP: NEWS unit tests require python3"; \
 	else \
 		$(PYTHON3) -B $(top_srcdir)/utils/docs/tests/test_check_news.py; \
diff --git a/NEWS b/NEWS
index 61540a408..f5ecc0175 100644
--- a/NEWS
+++ b/NEWS
@@ -10,6 +10,8 @@ These are only changes since 3.7.0beta2.
  - OSSFuzz 5607611131822080, keep GSERIALIZED bytea fuzzer allocations
           consistent with hostile varlena size headers (Darafei Praliaskouski)
+ - #6111, Skip NEWS unit tests outside Git worktrees, fixing source
+          package documentation checks without git (Bas Couwenberg)
  - #6112, Document GMP and current build dependency requirements in
           README.postgis (Darafei Praliaskouski)
  - OSSFuzz 544800490, reject malformed GSERIALIZED polygon rings before
Summary of changes:
 GNUmakefile.in | 4 +++-
 NEWS           | 2 ++
 2 files changed, 5 insertions(+), 1 deletion(-)
hooks/post-receive
