[SCM] PostGIS branch master updated. 3.7.0beta2-29-g321342d9e
Tue Aug 11 10:35:45 PDT 2026
the project "PostGIS".
       via  321342d9e1b2f88dfeae3d7050539bfacfd27d10 (commit)
       via  ee01b53cd8449eee04548d11bf00a8a5d2b7dd3b (commit)
       via  5bbc1de9bf2c53f85a46a95b4726060454d6f213 (commit)
       via  58300a97ac7b2c454461771c53298b4bf1d63beb (commit)
      from  369235b92e0d03584916c42bf074cd02122addb9 (commit)
revisions in full, below.
commit 321342d9e1b2f88dfeae3d7050539bfacfd27d10
Merge: 369235b92 ee01b53cd
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Tue Aug 11 10:35:44 2026 -0700
    Merge pull request 'Handle topology and shp2pgsql allocation failures' (!728) from Komzpa/postgis:pick/gh-1170-1171-alloc-handlers into master
    Ports two allocation-failure hardening patches from GitHub mirror pull requests into the canonical Gitea review flow.
    - Handle failed topology ring-shell array allocation before constructing the shell polygon.
    - Handle shp2pgsql loader allocation failures during loader creation, field metadata setup, geometry array construction, polygon ring construction, and escaped attribute output.
    The branch also includes a review follow-up that replaces an assert-only polygon ring size guard with a runtime bounds check and shared allocation-failure cleanup.
    References https://github.com/postgis/postgis/pull/1170
    References https://github.com/postgis/postgis/pull/1171
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/728
commit ee01b53cd8449eee04548d11bf00a8a5d2b7dd3b
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Tue Aug 11 19:29:07 2026 +0400
    loader: harden allocation failure cleanup
diff --git a/liblwgeom/topo/lwgeom_topo.c b/liblwgeom/topo/lwgeom_topo.c
index 8e18e7be1..11fed9091 100644
--- a/liblwgeom/topo/lwgeom_topo.c
+++ b/liblwgeom/topo/lwgeom_topo.c
@@ -2072,9 +2072,9 @@ _lwt_MakeRingShell(LWT_TOPOLOGY *topo, LWT_ELEMID *signed_edge_ids, uint64_t num
   POINTARRAY **points = lwalloc(sizeof(POINTARRAY*));
   if (!points)
-    ptarray_free(full_ring_pa);
-    lwerror("Could not allocate ring shell rings array");
-    return NULL;
+	  ptarray_free(full_ring_pa);
+	  lwerror("Could not allocate ring shell rings array");
+	  return NULL;
   points[0] = full_ring_pa;
diff --git a/loader/shp2pgsql-core.c b/loader/shp2pgsql-core.c
index ded9472e1..74415c039 100644
--- a/loader/shp2pgsql-core.c
+++ b/loader/shp2pgsql-core.c
@@ -16,7 +16,7 @@
 #include "../postgis_config.h"
 #include <math.h> /* for isnan */
-#include <limits.h>
+#include <stdint.h>
 #include <strings.h>
 #include "shp2pgsql-core.h"
@@ -469,6 +469,39 @@ PIP(Point P, Point *V, int n)
 	return (cn&1);    /* 0 if even (out), and 1 if odd (in) */
+static void
+ShpLoaderFreeFieldMetadata(SHPLOADERSTATE *state)
+	for (int j = 0; j < state->num_fields; j++)
+		if (state->field_names)
+			free(state->field_names[j]);
+		if (state->pgfieldtypes)
+			free(state->pgfieldtypes[j]);
+	free(state->field_names);
+	state->field_names = NULL;
+	free(state->types);
+	state->types = NULL;
+	free(state->widths);
+	state->widths = NULL;
+	free(state->precisions);
+	state->precisions = NULL;
+	free(state->pgfieldtypes);
+	state->pgfieldtypes = NULL;
+	free(state->col_names);
+	state->col_names = NULL;
+	state->num_fields = 0;
+static int
+ShpLoaderOpenShapeFieldAllocFailure(SHPLOADERSTATE *state)
+	ShpLoaderFreeFieldMetadata(state);
+	snprintf(state->message, SHPLOADERMSGLEN, "unable to allocate memory for field information");
+	return SHPLOADERERR;
 int
 FindPolygons(SHPObject *obj, Ring ***Out)
@@ -516,7 +549,23 @@ FindPolygons(SHPObject *obj, Ring ***Out)
 		/* Compute number of vertices */
 		nv = ve - vs;
-		assert(nv >= 0 && nv < INT_MAX / sizeof(Point));
+		if (nv <= 0 || (size_t)nv > SIZE_MAX / sizeof(*ring->list))
+			for (pi = 0; pi < out_index; pi++)
+				free(Outer[pi]->list);
+				free(Outer[pi]);
+			for (pi = 0; pi < in_index; pi++)
+				free(Inner[pi]->list);
+				free(Inner[pi]);
+			free(Outer);
+			free(Inner);
+			return -1;
+		size_t ring_list_size = sizeof(*ring->list) * (size_t)nv;
 		/* Allocate memory for a ring */
 		ring = (Ring *)malloc(sizeof(Ring));
@@ -537,7 +586,7 @@ FindPolygons(SHPObject *obj, Ring ***Out)
 			free(Inner);
 			return -1;
-		ring->list = (Point *)malloc(sizeof(Point) * (size_t)nv);
+		ring->list = (Point *)malloc(ring_list_size);
 		if (!ring->list)
 			free(ring);
@@ -1391,7 +1440,7 @@ ShpLoaderOpenShape(SHPLOADERSTATE *state)
 	 * field_names and pgfieldtypes hold per-field strings that are freed
 	 * individually; use calloc so any slot never assigned stays NULL and
 	 * free(NULL) is safe on the allocation-failure cleanup path. */
-	state->field_names = calloc(state->num_fields, sizeof(char*));
+	state->field_names = calloc(state->num_fields, sizeof(char *));
 	state->types = (DBFFieldType *)malloc(state->num_fields * sizeof(int));
 	state->widths = malloc(state->num_fields * sizeof(int));
 	state->precisions = malloc(state->num_fields * sizeof(int));
@@ -1401,12 +1450,11 @@ ShpLoaderOpenShape(SHPLOADERSTATE *state)
 			(state->config->readshape ? strlen(state->geo_col) : 0) + 1,
 		sizeof(char)
-	if (!state->col_names ||
-		(state->num_fields && (!state->field_names || !state->types ||
-			!state->widths || !state->precisions || !state->pgfieldtypes)))
+	int fields_allocated = !state->num_fields || (state->field_names && state->types && state->widths &&
+						      state->precisions && state->pgfieldtypes);
+	if (!state->col_names || !fields_allocated)
-		state->num_fields = 0;
-		goto open_shape_field_alloc_failure;
+		return ShpLoaderOpenShapeFieldAllocFailure(state);
 	/* Generate a string of comma separated column names of the form "col1, col2 ... colN" for the SQL
@@ -1496,7 +1544,7 @@ ShpLoaderOpenShape(SHPLOADERSTATE *state)
 		state->field_names[j] = strdup(name);
 		if (!state->field_names[j])
 		/* Now generate the PostgreSQL type name string and width based upon the shapefile type */
 		switch (state->types[j])
@@ -1553,7 +1601,7 @@ ShpLoaderOpenShape(SHPLOADERSTATE *state)
 		if (!state->pgfieldtypes[j])
 		strcat(state->col_names, "\"");
 		strcat(state->col_names, name);
@@ -1575,31 +1623,6 @@ ShpLoaderOpenShape(SHPLOADERSTATE *state)
 	/* Return status */
 	return ret;
-open_shape_field_alloc_failure:
-	/* Release the per-field strings populated so far; free(NULL) is safe for
-	 * the slots that were never assigned. */
-	for (int j = 0; j < state->num_fields; j++)
-		free(state->field_names[j]);
-		free(state->pgfieldtypes[j]);
-	free(state->field_names);
-	state->field_names = NULL;
-	free(state->types);
-	state->types = NULL;
-	free(state->widths);
-	state->widths = NULL;
-	free(state->precisions);
-	state->precisions = NULL;
-	free(state->pgfieldtypes);
-	state->pgfieldtypes = NULL;
-	free(state->col_names);
-	state->col_names = NULL;
-	state->num_records = 0;
-	snprintf(state->message, SHPLOADERMSGLEN, "unable to allocate memory for field information");
-	return SHPLOADERERR;
 /* Return a pointer to an allocated string containing the header for the specified loader state */
@@ -1983,7 +2006,9 @@ ShpLoaderGenerateSQLRowStatement(SHPLOADERSTATE *state, int item, char **strreco
 			if (!escval)
-				snprintf(state->message, SHPLOADERMSGLEN, "unable to allocate memory for escaped attribute value");
+					 SHPLOADERMSGLEN,
+					 "unable to allocate memory for escaped attribute value");
 				SHPDestroyObject(obj);
 				stringbuffer_destroy(sbwarn);
 				stringbuffer_destroy(sb);
@@ -2233,35 +2258,13 @@ void
 ShpLoaderDestroy(SHPLOADERSTATE *state)
 	/* Destroy a state object created with ShpLoaderOpenShape */
-	int i;
 	if (state != NULL)
 		if (state->hSHPHandle)
 			SHPClose(state->hSHPHandle);
 		if (state->hDBFHandle)
 			DBFClose(state->hDBFHandle);
-		if (state->field_names)
-			for (i = 0; i < state->num_fields; i++)
-				free(state->field_names[i]);
-		if (state->pgfieldtypes)
-				free(state->pgfieldtypes[i]);
-		if (state->types)
-		if (state->widths)
-		if (state->precisions)
-		if (state->col_names)
 		/* Free any column map fieldnames if specified */
 		colmap_clean(&state->column_map);
diff --git a/loader/shp2pgsql-gui.c b/loader/shp2pgsql-gui.c
index 50f9c8623..16ba66a4b 100644
--- a/loader/shp2pgsql-gui.c
+++ b/loader/shp2pgsql-gui.c
@@ -1579,7 +1579,15 @@ pgui_action_import(GtkWidget *widget, gpointer data)
 		if (!state)
 			pgui_logf(_("Warning: Could not load shapefile %s"), loader_file_config->shp_file);
-			goto import_cleanup;
+			ret = SHPLOADERERR;
+			is_running = FALSE;
+			PQfinish(pg_connection);
+			pg_connection = NULL;
+			pgui_logf(_("Shapefile import failed."));
+			free(progress_shapefile);
+			progress_shapefile = NULL;
+			is_valid = gtk_tree_model_iter_next(GTK_TREE_MODEL(import_file_list_store), &iter);
+			continue;
 		/* Open the shapefile */
commit 5bbc1de9bf2c53f85a46a95b4726060454d6f213
Author: Maksim Korotkov <m.korotkov at postgrespro.ru>
Date:   Tue Aug 11 19:29:06 2026 +0400
    loader: handle shp2pgsql allocation failures
    Check the return of malloc/calloc in the shp2pgsql loader paths and bail out cleanly instead of dereferencing NULL. Escaped-value and field-info allocation failures now error out before the value is written, so no unescaped attribute reaches the output buffer. The partial-allocation paths in FindPolygons and ShpLoaderOpenShape release what was already allocated and null the owning pointers so ShpLoaderDestroy stays safe.
    Found by PostgresPro with Svace Static Analyzer.
    Signed-off-by: Maksim Korotkov <m.korotkov at postgrespro.ru>
diff --git a/loader/shp2pgsql-cli.c b/loader/shp2pgsql-cli.c
index a7c6db37d..394140980 100644
--- a/loader/shp2pgsql-cli.c
+++ b/loader/shp2pgsql-cli.c
@@ -571,6 +571,11 @@ main (int argc, char **argv)
 	/* Create the shapefile state object */
 	state = ShpLoaderCreate(config);
+	if (!state)
+		fprintf(stderr, "Unable to allocate memory for loader state\n");
+		exit(1);
 	ret = ShpLoaderOpenShape(state);
index 9ebfa8fb4..ded9472e1 100644
@@ -16,6 +16,7 @@
+#include <limits.h>
@@ -170,6 +171,8 @@ escape_copy_string(char *str)
 	size = ptr - str + toescape + 1;
 	result = calloc(1, size);
+	if (!result)
+		return NULL;
 	optr = result;
 	ptr = str;
@@ -223,6 +226,8 @@ escape_insert_string(char *str)
+	if (!result)
+		return NULL;
 	optr = result;
 	ptr = str;
@@ -271,6 +276,11 @@ GeneratePointGeometry(SHPLOADERSTATE *state, SHPObject *obj, char **geometry, in
 		/* Allocate memory for our array of LWPOINTs and our dynptarrays */
 		lwmultipoints = malloc(sizeof(LWPOINT *) * obj->nVertices);
+		if (!lwmultipoints)
+			snprintf(state->message, SHPLOADERMSGLEN, "unable to allocate memory for point geometry");
 		/* We need an array of pointers to each of our sub-geometries */
 		for (u = 0; u < obj->nVertices; u++)
@@ -361,6 +371,11 @@ GenerateLineStringGeometry(SHPLOADERSTATE *state, SHPObject *obj, char **geometr
 	/* Allocate memory for our array of LWLINEs and our dynptarrays */
 	lwmultilinestrings = malloc(sizeof(LWPOINT *) * obj->nParts);
+	if (!lwmultilinestrings)
+		snprintf(state->message, SHPLOADERMSGLEN, "unable to allocate memory for linestring geometry");
 	for (u = 0; u < obj->nParts; u++)
@@ -474,6 +489,12 @@ FindPolygons(SHPObject *obj, Ring ***Out)
 	/* Allocate initial memory */
 	Outer = (Ring **)malloc(sizeof(Ring *) * obj->nParts);
 	Inner = (Ring **)malloc(sizeof(Ring *) * obj->nParts);
+	if (!Outer || !Inner)
+		free(Outer);
+		free(Inner);
+		return -1;
 	/* Iterate over rings dividing in Outers and Inners */
 	for (pi=0; pi < obj->nParts; pi++)
@@ -495,10 +516,46 @@ FindPolygons(SHPObject *obj, Ring ***Out)
 		nv = ve - vs;
+		assert(nv >= 0 && nv < INT_MAX / sizeof(Point));
-		ring->list = (Point *)malloc(sizeof(Point) * nv);
+		if (!ring)
+			/* Free rings allocated so far (stored in Outer/Inner) */
+				free(Outer[pi]);
+				free(Inner[pi]);
+			free(Outer);
+			free(Inner);
+			return -1;
+		ring->list = (Point *)malloc(sizeof(Point) * (size_t)nv);
+		if (!ring->list)
+			free(ring);
+				free(Outer[pi]);
+				free(Inner[pi]);
+			free(Outer);
+			free(Inner);
+			return -1;
 		ring->n = nv;
 		ring->next = NULL;
 		ring->linked = 0;
@@ -660,6 +717,12 @@ GeneratePolygonGeometry(SHPLOADERSTATE *state, SHPObject *obj, char **geometry)
 	polygon_total = FindPolygons(obj, &Outer);
+	if (polygon_total < 0)
+		snprintf(state->message, SHPLOADERMSGLEN, "unable to allocate memory for polygon rings");
 	if (state->config->simple_geometries == 1 && polygon_total != 1) /* We write Non-MULTI geometries, but have several parts: */
 		snprintf(state->message, SHPLOADERMSGLEN, _("We have a Multipolygon with %d parts, can't use -S switch!"), polygon_total);
@@ -669,6 +732,12 @@ GeneratePolygonGeometry(SHPLOADERSTATE *state, SHPObject *obj, char **geometry)
 	/* Allocate memory for our array of LWPOLYs */
 	lwpolygons = malloc(sizeof(LWPOLY *) * polygon_total);
+	if (!lwpolygons)
+		ReleasePolygons(Outer, polygon_total);
+		snprintf(state->message, SHPLOADERMSGLEN, "unable to allocate memory for polygon geometry");
 	/* Cycle through each individual polygon */
 	for (pi = 0; pi < polygon_total; pi++)
@@ -1000,6 +1069,8 @@ ShpLoaderCreate(SHPLOADERCONFIG *config)
 	/* Create a new state object and assign the config to it */
 	state = malloc(sizeof(SHPLOADERSTATE));
+	if (!state)
+		return NULL;
 	state->config = config;
 	/* Set any state defaults */
@@ -1316,17 +1387,27 @@ ShpLoaderOpenShape(SHPLOADERSTATE *state)
 	state->num_records = DBFGetRecordCount(state->hDBFHandle);
-	/* Allocate storage for field information */
-	state->field_names = malloc(state->num_fields * sizeof(char*));
+	/* Allocate storage for field information.
+	 * field_names and pgfieldtypes hold per-field strings that are freed
+	 * individually; use calloc so any slot never assigned stays NULL and
+	 * free(NULL) is safe on the allocation-failure cleanup path. */
+	state->field_names = calloc(state->num_fields, sizeof(char*));
-	state->pgfieldtypes = malloc(state->num_fields * sizeof(char *));
+	state->pgfieldtypes = calloc(state->num_fields, sizeof(char *));
 	state->col_names = calloc(
 		(size_t)state->num_fields * (MAXFIELDNAMELEN + 2) +
 		sizeof(char)
+		(state->num_fields && (!state->field_names || !state->types ||
+			!state->widths || !state->precisions || !state->pgfieldtypes)))
+		goto open_shape_field_alloc_failure;
 	   insertion string */
@@ -1414,6 +1495,8 @@ ShpLoaderOpenShape(SHPLOADERSTATE *state)
+		if (!state->field_names[j])
@@ -1469,6 +1552,9 @@ ShpLoaderOpenShape(SHPLOADERSTATE *state)
+		if (!state->pgfieldtypes[j])
@@ -1489,6 +1575,31 @@ ShpLoaderOpenShape(SHPLOADERSTATE *state)
 	/* Return status */
 	return ret;
+open_shape_field_alloc_failure:
+	/* Release the per-field strings populated so far; free(NULL) is safe for
+	 * the slots that were never assigned. */
+	state->num_records = 0;
@@ -1864,14 +1975,26 @@ ShpLoaderGenerateSQLRowStatement(SHPLOADERSTATE *state, int item, char **strreco
 			if (state->config->dump_format)
 				escval = escape_copy_string(val);
-				stringbuffer_aprintf(sb, "%s", escval);
 			else
 				escval = escape_insert_string(val);
-				stringbuffer_aprintf(sb, "'%s'", escval);
+			if (!escval)
+				snprintf(state->message, SHPLOADERMSGLEN, "unable to allocate memory for escaped attribute value");
+				SHPDestroyObject(obj);
+				stringbuffer_destroy(sbwarn);
+				stringbuffer_destroy(sb);
+			if (state->config->dump_format)
+				stringbuffer_aprintf(sb, "%s", escval);
+			else
+				stringbuffer_aprintf(sb, "'%s'", escval);
 			/* Free the escaped version if required */
 			if (val != escval)
 				free(escval);
index 37a9a04d0..50f9c8623 100644
@@ -1219,6 +1219,11 @@ validate_remote_loader_columns(SHPLOADERCONFIG *config, PGresult *result)
 					/* If we have a row then lets do some simple column validation... */
+					if (!state)
+						pgui_logf(_("Warning: Could not load shapefile %s"), config->shp_file);
 					if (ret != SHPLOADEROK)
@@ -1571,6 +1576,11 @@ pgui_action_import(GtkWidget *widget, gpointer data)
 		state = ShpLoaderCreate(loader_file_config);
+		if (!state)
+			pgui_logf(_("Warning: Could not load shapefile %s"), loader_file_config->shp_file);
+			goto import_cleanup;
@@ -1768,7 +1778,9 @@ import_cleanup:
 		/* If we didn't finish inserting all of the items (and we expected to), an error occurred */
-		if ((state->config->plan.load_data && i != ShpLoaderGetRecordCount(state)) || !ret)
+		if (state && ((state->config->plan.load_data && i != ShpLoaderGetRecordCount(state)) || !ret))
+		else if (!state)
 		else
 			pgui_logf(_("Shapefile import completed."));
commit 58300a97ac7b2c454461771c53298b4bf1d63beb
    topo: handle ring shell allocation failure
    default_allocator can silently return NULL.
index 5ac10cb83..8e18e7be1 100644
@@ -2070,6 +2070,12 @@ _lwt_MakeRingShell(LWT_TOPOLOGY *topo, LWT_ELEMID *signed_edge_ids, uint64_t num
   *isccw = lwt_IsTopoRingCCW(full_ring_pa);
+  if (!points)
+    return NULL;
   /* NOTE: the ring may very well have collapsed components,
Summary of changes:
 liblwgeom/topo/lwgeom_topo.c |   6 ++
 loader/shp2pgsql-cli.c       |   5 ++
 loader/shp2pgsql-core.c      | 184 ++++++++++++++++++++++++++++++++++++-------
 loader/shp2pgsql-gui.c       |  22 +++++-
 4 files changed, 187 insertions(+), 30 deletions(-)
hooks/post-receive
