[PostGIS] #6111: Don't run test_check_news.py when not using git
PostGIS trac at osgeo.org
Tue Aug 11 07:52:18 PDT 2026
  Reporter:  Bas Couwenberg  |      Owner:  robe
      Type:  defect          |     Status:  closed
  Priority:  medium          |  Milestone:  PostGIS 3.7.0
 Component:  documentation   |    Version:  master
Resolution:  fixed           |   Keywords:
Changes (by Darafei Praliaskouski <me@…>):
 * resolution:   => fixed
 * status:  new => closed
Comment:
 In [changeset:"b45a1f078a93b84ef5dc95685e408b5970a4e71a/git" b45a1f0/git]:
 {{{#!CommitTicketReference repository="git"
 revision="b45a1f078a93b84ef5dc95685e408b5970a4e71a"
 build: skip NEWS unit tests outside Git worktrees
 The NEWS Python unit tests create temporary Git repositories, so release-
 tarball builds without git cannot run them. Skip those unit tests when the
 source tree is not a Git worktree, while still running the shell NEWS
 checks that do not need Git history.
 Closes #6111
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6111#comment:1>
