[PostGIS] #6111: Don't run test_check_news.py when not using git
trac at osgeo.org
Tue Aug 11 07:52:19 PDT 2026
Reporter: Bas Couwenberg | Owner: robe
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 3.7.0
Component: documentation | Version: master
Resolution: fixed | Keywords:
Comment (by Darafei Praliaskouski <komzpa@…>):
In [changeset:"369235b92e0d03584916c42bf074cd02122addb9/git" 369235b/git]:
{{{#!CommitTicketReference repository="git"
revision="369235b92e0d03584916c42bf074cd02122addb9"
Merge pull request 'build: skip NEWS unit tests outside Git worktrees'
(!727) from Komzpa/postgis:codex/ticket-6111-check-news-no-git into master
Skip the Python NEWS unit tests when the source tree is not a Git
worktree, while still running the shell NEWS checks that do not require
Git history. This fixes source package documentation checks in build
environments where git is absent.
Patch by Bas Couwenberg.
Closes https://trac.osgeo.org/postgis/ticket/6111
Closes #6111
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/727
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6111#comment:2>
