[SCM] PostGIS branch master updated. 3.7.0beta2-31-g67cd3dece
Wed Aug 12 03:41:45 PDT 2026
the project "PostGIS".
       via  67cd3deceb298c2705db58da8a3e0d6b5a79302e (commit)
       via  8aeaff1f1539246a0fa63851d83949c772de8dff (commit)
      from  321342d9e1b2f88dfeae3d7050539bfacfd27d10 (commit)
revisions in full, below.
commit 67cd3deceb298c2705db58da8a3e0d6b5a79302e
Merge: 321342d9e 8aeaff1f1
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Wed Aug 12 03:41:44 2026 -0700
    Merge pull request 'Guard encoded polyline coordinate accumulation' (!729) from Komzpa/postgis:fix/encoded-polyline-accum-545389411 into master
    OSS-Fuzz found that encoded polyline inputs can produce valid int32 deltas whose cumulative latitude or longitude sum overflows `int32_t`.
    This keeps the existing varint validation, but routes coordinate accumulation through a checked `int64_t` add and rejects values outside the int32 coordinate range before storing them back. The new CUnit case covers the minimized OSS-Fuzz input shape, while the existing valid, truncated, and overlong-varint cases stay in the same suite.
    Validation:
    - `./liblwgeom/cunit/cu_tester encoded_polyline_input`
    - `make check-news`
    - `make check-contributor-credits`
    - `git diff --check upstream/master...HEAD`
    - `git diff --cached --check`
    - `encoded_polyline_import_fuzzer` replay of OSSFuzz testcase 4743900859006976, minimized and unminimized, with no UBSAN runtime-error output
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/729
commit 8aeaff1f1539246a0fa63851d83949c772de8dff
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Wed Aug 12 14:37:32 2026 +0400
diff --git a/NEWS b/NEWS
index f5ecc0175..299e6398d 100644
--- a/NEWS
+++ b/NEWS
@@ -20,6 +20,8 @@ These are only changes since 3.7.0beta2.
           comparisons aligned with serialized bbox flags (Darafei Praliaskouski)
  - OSSFuzz 6152109301760000, reject overlong encoded polyline coordinate
           varints (Darafei Praliaskouski)
+ - OSSFuzz 4743900859006976, reject encoded polyline coordinate deltas
+          that overflow accumulated int32 coordinates (Darafei Praliaskouski)
diff --git a/liblwgeom/cunit/cu_in_encoded_polyline.c b/liblwgeom/cunit/cu_in_encoded_polyline.c
index 7fcb7841a..9d9329ba8 100644
--- a/liblwgeom/cunit/cu_in_encoded_polyline.c
+++ b/liblwgeom/cunit/cu_in_encoded_polyline.c
@@ -76,6 +76,19 @@ in_encoded_polyline_test_overlong_varint(void)
 	CU_ASSERT_PTR_NULL(lwgeom_from_encoded_polyline("~~~~~~P", 5));
+static void
+in_encoded_polyline_test_coordinate_overflow(void)
+	char input[] = {(char)0xff, (char)0xff, (char)0xff, (char)0xff, (char)0xff, '\\', '?',
+			(char)0xff, (char)0xff, (char)0xff, (char)0xff, (char)0xff, '\\', '?',
+			(char)0xff, (char)0xff, (char)0xff, (char)0xff, '\\',       '?',  (char)0xff,
+			(char)0xff, (char)0xff, (char)0xff, (char)0xff, '\\',       0};
+	/* OSSFuzz 4743900859006976: cumulative deltas must not overflow int32_t. */
+	CU_ASSERT_PTR_NULL(lwgeom_from_encoded_polyline(input, 2));
 ** Used by test harness to register the tests in this file.
@@ -88,4 +101,5 @@ void in_encoded_polyline_suite_setup(void)
 	PG_ADD_TEST(suite, in_encoded_polyline_test_close_points);
 	PG_ADD_TEST(suite, in_encoded_polyline_test_truncated_input);
 	PG_ADD_TEST(suite, in_encoded_polyline_test_overlong_varint);
+	PG_ADD_TEST(suite, in_encoded_polyline_test_coordinate_overflow);
diff --git a/liblwgeom/lwin_encoded_polyline.c b/liblwgeom/lwin_encoded_polyline.c
index ef35d8c0f..9ee22d4da 100644
--- a/liblwgeom/lwin_encoded_polyline.c
+++ b/liblwgeom/lwin_encoded_polyline.c
@@ -76,6 +76,20 @@ encoded_polyline_zigzag_decode(uint32_t value)
 	return (int32_t)((value >> 1) ^ (uint32_t)(-(int32_t)(value & 1)));
+static int
+encoded_polyline_add_delta(int32_t *coordinate, int32_t delta)
+	int64_t next = (int64_t)*coordinate + delta;
+	if (next < INT32_MIN || next > INT32_MAX)
+		lwerror("lwgeom_from_encoded_polyline: coordinate value is too large");
+		return LW_FALSE;
+	*coordinate = next;
+	return LW_TRUE;
 LWGEOM*
 lwgeom_from_encoded_polyline(const char *encodedpolyline, int precision)
@@ -100,7 +114,11 @@ lwgeom_from_encoded_polyline(const char *encodedpolyline, int precision)
 	    return NULL;
     int32_t deltaLat = encoded_polyline_zigzag_decode(res);
-    latitude += deltaLat;
+    if (!encoded_polyline_add_delta(&latitude, deltaLat))
+	    ptarray_free(pa);
+	    return NULL;
     if (!encoded_polyline_read_varint(encodedpolyline, length, &idx, &res))
@@ -108,7 +126,11 @@ lwgeom_from_encoded_polyline(const char *encodedpolyline, int precision)
 	    return NULL;
     int32_t deltaLon = encoded_polyline_zigzag_decode(res);
-    longitude += deltaLon;
+    if (!encoded_polyline_add_delta(&longitude, deltaLon))
+	    ptarray_free(pa);
+	    return NULL;
     pt.x = longitude/scale;
     pt.y = latitude/scale;
Summary of changes:
 NEWS                                     |  2 ++
 liblwgeom/cunit/cu_in_encoded_polyline.c | 14 ++++++++++++++
 liblwgeom/lwin_encoded_polyline.c        | 26 ++++++++++++++++++++++++--
 3 files changed, 40 insertions(+), 2 deletions(-)
hooks/post-receive
