[SCM] PostGIS branch master updated. 3.7.0beta2-33-g4e26c6f76
git at osgeo.org
git at osgeo.org
Wed Aug 12 20:58:40 PDT 2026
the project "PostGIS".
via 4e26c6f769934a1c27d86cb7ae2ca9cc7879d83a (commit)
via 11b2025818f3249d08c1cf4b9b13c7b0a5fce43c (commit)
from 67cd3deceb298c2705db58da8a3e0d6b5a79302e (commit)
revisions in full, below.
commit 4e26c6f769934a1c27d86cb7ae2ca9cc7879d83a
Merge: 67cd3dece 11b202581
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Wed Aug 12 20:58:39 2026 -0700
Merge pull request 'Fuzzers: normalize GSERIALIZED bytea SRIDs' (!731) from Komzpa/postgis:fix/ossfuzz-gserialized-roundtrip-545658571 into master
OSS-Fuzz issue 545658571 found that `gserialized_from_bytea_fuzzer` could abort while checking a GSERIALIZED -> EWKB bytea -> LWGEOM round trip.
The minimized input carries a raw GSERIALIZED SRID of `0x202020`, outside PostGIS' valid SRID range. Normal serialization paths clamp that value to the WKB-visible SRID `999483`, so the fuzzer oracle was comparing hostile GSERIALIZED-only metadata rather than the semantic value preserved by the bytea round trip.
This updates the fuzzer to compare SRIDs after `clamp_srid()` and to apply the same normalized SRID before the final semantic geometry comparison. It also adds a NEWS entry for the OSS-Fuzz issue.
Validation:
- `make -j32`
- `make -C fuzzers dummyfuzzers FUZZER_OUT=/home/kom/proj/ai_pr/postgis-ossfuzz-545658571/fuzzout-fixed -j32`
- `ASAN_OPTIONS=exitcode=77 fuzzout-fixed/gserialized_from_bytea_fuzzer /home/kom/downloads/clusterfuzz-testcase-minimized-gserialized_from_bytea_fuzzer-6419041586315264`
- `ASAN_OPTIONS=exitcode=77 fuzzout-fixed/gserialized_from_bytea_fuzzer /home/kom/downloads/clusterfuzz-testcase-gserialized_from_bytea_fuzzer-6419041586315264`
- `make -C fuzzers check-corpus FUZZER_OUT=/home/kom/proj/ai_pr/postgis-ossfuzz-545658571/fuzzout-fixed`
- `git clang-format --diff upstream/master -- fuzzers/gserialized_from_bytea_fuzzer.cpp`
- `git diff --check -- fuzzers/gserialized_from_bytea_fuzzer.cpp NEWS`
- `make check-contributor-credits`
Credit to OSS-Fuzz.
Closes https://issues.oss-fuzz.com/issues/545658571
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/731
commit 11b2025818f3249d08c1cf4b9b13c7b0a5fce43c
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Thu Aug 13 07:31:48 2026 +0400
fuzzers: normalize GSERIALIZED bytea SRIDs
diff --git a/NEWS b/NEWS
index 299e6398d..08ba5397d 100644
--- a/NEWS
+++ b/NEWS
@@ -8,6 +8,8 @@ These are only changes since 3.7.0beta2.
* Bug Fixes *
+ - OSSFuzz 545658571, compare GSERIALIZED bytea fuzzer SRIDs after
+ normalizing out-of-range values (Darafei Praliaskouski)
- OSSFuzz 5607611131822080, keep GSERIALIZED bytea fuzzer allocations
consistent with hostile varlena size headers (Darafei Praliaskouski)
- #6111, Skip NEWS unit tests outside Git worktrees, fixing source
diff --git a/fuzzers/gserialized_from_bytea_fuzzer.cpp b/fuzzers/gserialized_from_bytea_fuzzer.cpp
index a62fb1c71..f98f6951c 100644
--- a/fuzzers/gserialized_from_bytea_fuzzer.cpp
+++ b/fuzzers/gserialized_from_bytea_fuzzer.cpp
@@ -70,17 +70,19 @@ assert_gserialized_bytea_roundtrip(LWGEOM *lwgeom)
postgis_fuzzer_assert(first_size == LWSIZE_GET(first->size));
postgis_fuzzer_assert(second_size == LWSIZE_GET(second->size));
postgis_fuzzer_assert(lwgeom->type == from_bytea->type);
- postgis_fuzzer_assert(lwgeom->srid == from_bytea->srid);
+ postgis_fuzzer_assert(clamp_srid(lwgeom->srid) == from_bytea->srid);
postgis_fuzzer_assert(FLAGS_GET_Z(lwgeom->flags) == FLAGS_GET_Z(from_bytea->flags));
postgis_fuzzer_assert(FLAGS_GET_M(lwgeom->flags) == FLAGS_GET_M(from_bytea->flags));
postgis_fuzzer_assert(FLAGS_GET_GEODETIC(lwgeom->flags) == FLAGS_GET_GEODETIC(from_bytea->flags));
- /* WKB bytea does not preserve GSERIALIZED bounding boxes. Arbitrary
- * GSERIALIZED input can carry a bbox that is not byte-for-byte reproduced
- * after geometry->bytea->geometry, so compare the semantic geometry.
+ /* WKB bytea does not preserve GSERIALIZED-only metadata. Arbitrary
+ * GSERIALIZED input can carry a bbox or out-of-range SRID that is
+ * normalized after geometry->bytea->geometry, so compare the semantic
+ * geometry after applying the same normalization.
lwgeom_drop_bbox(lwgeom);
lwgeom_drop_bbox(from_bytea);
+ lwgeom_set_srid(lwgeom, from_bytea->srid);
postgis_fuzzer_assert(lwgeom_same(lwgeom, from_bytea));
lwgeom_free(from_bytea);
Summary of changes:
NEWS | 2 ++
fuzzers/gserialized_from_bytea_fuzzer.cpp | 10 ++++++----
2 files changed, 8 insertions(+), 4 deletions(-)
hooks/post-receive
