[SCM] PostGIS branch master updated. 3.7.0beta2-40-ge3d6e352d
git at osgeo.org
git at osgeo.org
Fri Aug 14 04:17:11 PDT 2026
the project "PostGIS".
via e3d6e352d7b90b99afbd7bd0a1c21261389d061a (commit)
via 8d0d0e0e04c7ded0d62fcd3a40dccdfde7e479fa (commit)
from ed950a3b0b2aeda97bfcbb6db62c8be9ad38be0c (commit)
revisions in full, below.
commit e3d6e352d7b90b99afbd7bd0a1c21261389d061a
Merge: ed950a3b0 8d0d0e0e0
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Fri Aug 14 04:17:09 2026 -0700
Merge pull request 'docs: avoid password argv in Docker setup' (!733) from Komzpa/postgis:fix/docker-dev-password-argv-20260814 into master
The Docker development setup prompted for POSTGIS_DEV_PASSWORD and then passed it to psql with `-v password=...`, which made the entered password visible in process arguments.
Use psql's built-in `\password postgres` prompt instead, so the password is read by psql and is not carried in the shell command line.
References https://chatgpt.com/codex/cloud/security/findings/a54251275c8081919b2111d42cfa5e6b.
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/733
commit 8d0d0e0e04c7ded0d62fcd3a40dccdfde7e479fa
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Fri Aug 14 14:13:12 2026 +0400
diff --git a/doc/development/environment/docker.md b/doc/development/environment/docker.md
index c453df502..808f6cde4 100644
--- a/doc/development/environment/docker.md
+++ b/doc/development/environment/docker.md
@@ -64,17 +64,15 @@ the cluster:
```sh
export PGVER=15
export PGPORT="$(grep ^port /etc/postgresql/${PGVER}/main/postgresql.conf | awk '{print $3}')"
-read -rs POSTGIS_DEV_PASSWORD
-printf '\n'
psql -d postgres -c "ALTER SYSTEM SET listen_addresses='*';"
printf '%s\n' "host all all 0.0.0.0/0 scram-sha-256" >> "/etc/postgresql/${PGVER}/main/pg_hba.conf"
-psql -d postgres -v password="$POSTGIS_DEV_PASSWORD" -c "ALTER ROLE postgres PASSWORD :'password';"
-unset POSTGIS_DEV_PASSWORD
+psql -d postgres -c '\password postgres'
service postgresql restart "${PGVER}"
-Use a strong password and narrower `pg_hba.conf` rule on shared hosts. The
-example is intended for a short-lived local development container.
+Enter a strong password when `psql` prompts for it, and use a narrower
+`pg_hba.conf` rule on shared hosts. The example is intended for a short-lived
+local development container.
From the host, connect to the PostgreSQL version whose container port you
exposed. For example, if PostgreSQL inside the container listens on `5436` and
Summary of changes:
doc/development/environment/docker.md | 10 ++++------
1 file changed, 4 insertions(+), 6 deletions(-)
hooks/post-receive
