[SCM] PostGIS branch master updated. 3.7.0beta2-42-g89cd60efd
Fri Aug 14 12:49:20 PDT 2026
the project "PostGIS".
       via  89cd60efddcd85323dd9ed9ec33cd3a87dbf1091 (commit)
       via  93818486edb5c4c16799b96aaccb6b42c9195230 (commit)
      from  e3d6e352d7b90b99afbd7bd0a1c21261389d061a (commit)
revisions in full, below.
commit 89cd60efddcd85323dd9ed9ec33cd3a87dbf1091
Merge: e3d6e352d 93818486e
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Fri Aug 14 12:49:19 2026 -0700
    Merge pull request 'liblwgeom: include NURBS extrema in bboxes' (!720) from Komzpa/postgis:fix/nurbs-control-point-bbox-20260810 into master
    NURBS Cartesian bboxes were computed from a 32-segment sampled linestring. That approximation can miss coordinate extrema between fixed sample parameters, so serialized bboxes can exclude part of the curve and cause bbox or index false negatives.
    This replaces fixed sampling with a conservative rational Bezier construction. The NURBS is converted to homogeneous coordinates, knots are inserted until every non-empty knot span is a Bezier span, and each span is recursively subdivided with de Casteljau. Positive NURBS weights keep the curve inside the convex hull of each span's projected control points, so every merged hull is a proof of containment rather than an extrema-search heuristic.
    Subdivision stops when the control hull and its endpoint box have the same outward-rounded float bounds used by serialized boxes. A finite-precision/no-progress fallback merges the current hull, which may be looser but remains conservative. There are no fixed linearization, derivative-scan, or finite-difference epsilon settings in the bbox path.
    CUnit coverage keeps the simple quadratic expectation at `ymax = 0.5`, checks the high-curvature maximum at `t = 1/64`, the outward float boundary, rational weights, repeated knots, and a complete Bezier arch inside a knot span narrower than one step of the former derivative scan.
    Current head: `93818486edb5c4c16799b96aaccb6b42c9195230`.
    Validation:
    - `make -C liblwgeom -j32`
    - `make -C liblwgeom/cunit check` (`373` tests, `5844` assertions)
    - `git clang-format --extensions c,h gitea/master --diff`
    - `git diff --check gitea/master...HEAD`
    - scope gate: only `NEWS`, `liblwgeom/gbox.c`, and `liblwgeom/cunit/cu_gserialized1.c` changed
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/720
commit 93818486edb5c4c16799b96aaccb6b42c9195230
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Tue Aug 11 00:01:29 2026 +0400
diff --git a/NEWS b/NEWS
index d167ad9a0..4f4cd19e6 100644
--- a/NEWS
+++ b/NEWS
@@ -25,6 +25,8 @@ These are only changes since 3.7.0beta2.
           comparisons aligned with serialized bbox flags (Darafei Praliaskouski)
  - Reject truncated GSERIALIZED NURBS vector payloads before validating vector
           contents (Darafei Praliaskouski)
+ - Include detected NURBS coordinate extrema in curve bounding boxes
+          (Darafei Praliaskouski)
  - OSSFuzz 6152109301760000, reject overlong encoded polyline coordinate
           varints (Darafei Praliaskouski)
  - OSSFuzz 4743900859006976, reject encoded polyline coordinate deltas
diff --git a/liblwgeom/cunit/cu_gserialized1.c b/liblwgeom/cunit/cu_gserialized1.c
index cfc49bcc7..1153c1a8b 100644
--- a/liblwgeom/cunit/cu_gserialized1.c
+++ b/liblwgeom/cunit/cu_gserialized1.c
@@ -155,6 +155,56 @@ static void test_lwgeom_calculate_gbox(void)
 	CU_ASSERT_DOUBLE_EQUAL(b.ymax, 0.5, 0.0000001);
 	lwgeom_free(g);
+	/* The curve apex is inside the parameter range, not at a control point. */
+	g = lwgeom_from_wkt("NURBSCURVE(2, (0 0, 1 1000000000, 2 -62000000000))", LW_PARSER_CHECK_NONE);
+	lwgeom_calculate_gbox_cartesian(g, &b);
+	CU_ASSERT_DOUBLE_EQUAL(b.xmin, 0.0, 0.0000001);
+	CU_ASSERT_DOUBLE_EQUAL(b.ymin, -62000000000.0, 0.0000001);
+	CU_ASSERT_DOUBLE_EQUAL(b.xmax, 2.0, 0.0000001);
+	CU_ASSERT_EQUAL(next_float_up(b.ymax), next_float_up(15625000.0));
+	lwgeom_free(g);
+	/* The bbox must expand through the extremum's outward float boundary. */
+	g = lwgeom_from_wkt("NURBSCURVE(2, (0 0.99898996343746105, 1 1.000999975937461, 2 0.99900998843746103))",
+			    LW_PARSER_CHECK_NONE);
+	CU_ASSERT(b.ymax >= 1.000000001);
+	CU_ASSERT_EQUAL(next_float_up(b.ymax), next_float_up(1.000000001));
+	lwgeom_free(g);
+	/* This entire Bezier arch lies between two adjacent samples of the old
+	 * uniform derivative scan. Knot-span decomposition must still find it. */
+	    "NURBSCURVE(2, (0 0, 0.25 0, 0.5 0, 0.5 0, 0.5005 1, 0.501 0, 0.501 0, 0.75 0, 1 0), "
+	    "(1, 1, 1, 1, 1, 1, 1, 1, 1), "
+	    "(0, 0, 0, 0.5, 0.5, 0.5, 0.501, 0.501, 0.501, 1, 1, 1))",
+	CU_ASSERT_DOUBLE_EQUAL(b.xmax, 1.0, 0.0000001);
+	CU_ASSERT_DOUBLE_EQUAL(b.ymin, 0.0, 0.0000001);
+	CU_ASSERT_EQUAL(next_float_up(b.ymax), next_float_up(0.5));
+	lwgeom_free(g);
+	/* Rational Bezier spans use the projected weighted control hull. */
+	g = lwgeom_from_wkt("NURBSCURVE(2, (0 0, 1 1, 2 0), (1, 3, 1), (0, 0, 0, 1, 1, 1))", LW_PARSER_CHECK_NONE);
+	CU_ASSERT_EQUAL(next_float_up(b.ymax), next_float_up(0.75));
+	lwgeom_free(g);
+	/* Repeated knots split the curve into independent Bezier spans. */
+	g = lwgeom_from_wkt("NURBSCURVE(2, (0 0, 1 1, 2 0, 3 1, 4 0), (1, 1, 1, 1, 1), (0, 0, 0, 0.5, 0.5, 1, 1, 1))",
+	CU_ASSERT_DOUBLE_EQUAL(b.xmax, 4.0, 0.0000001);
+	lwgeom_free(g);
 	/* Inf = 0x7FF0000000000000 */
 	/* POINT(0 0) = 00 00000001 0000000000000000 0000000000000000 */
 	/* POINT(0 Inf) = 00 00000001 0000000000000000 7FF0000000000000 */
diff --git a/liblwgeom/gbox.c b/liblwgeom/gbox.c
index a5d4f9998..1530466cd 100644
--- a/liblwgeom/gbox.c
+++ b/liblwgeom/gbox.c
@@ -25,9 +25,25 @@
 #include "liblwgeom_internal.h"
 #include "lwgeodetic.h"
 #include "lwgeom_log.h"
+#include <float.h>
 #include <stdlib.h>
 #include <math.h>
+typedef struct {
+	double x;
+	double y;
+	double z;
+	double m;
+	double w;
+} NURBS_BBOX_HPOINT;
+typedef struct {
+	uint32_t degree;
+	uint32_t npoints;
+	uint32_t nknots;
+	NURBS_BBOX_HPOINT *points;
+	double *knots;
+} NURBS_BBOX_WORK;
 GBOX* gbox_new(lwflags_t flags)
@@ -688,6 +704,468 @@ static int lwcircstring_calculate_gbox_cartesian(LWCIRCSTRING *curve, GBOX *gbox
 	return LW_SUCCESS;
+ * Projects a homogeneous control point by dividing its weighted coordinates
+ * by w, failing when w is zero and the Cartesian point is undefined.
+static int
+lwnurbscurve_hpoint_project(const NURBS_BBOX_HPOINT *hpoint, POINT4D *point)
+	if (hpoint->w == 0.0)
+		return LW_FAILURE;
+	point->x = hpoint->x / hpoint->w;
+	point->y = hpoint->y / hpoint->w;
+	point->z = hpoint->z / hpoint->w;
+	point->m = hpoint->m / hpoint->w;
+	return LW_SUCCESS;
+ * Interpolates in homogeneous space, as required by rational de Casteljau
+ * subdivision and Boehm knot insertion; interpolating projected points would
+ * describe a different curve.
+static NURBS_BBOX_HPOINT
+lwnurbscurve_hpoint_lerp(const NURBS_BBOX_HPOINT *a, const NURBS_BBOX_HPOINT *b, double t)
+	NURBS_BBOX_HPOINT out;
+	double s = 1.0 - t;
+	out.x = s * a->x + t * b->x;
+	out.y = s * a->y + t * b->y;
+	out.z = s * a->z + t * b->z;
+	out.m = s * a->m + t * b->m;
+	out.w = s * a->w + t * b->w;
+	return out;
+ * Expands a Cartesian box in each enabled dimension, keeping dimensionality
+ * decisions out of the projection and subdivision helpers.
+static void
+lwnurbscurve_add_point_to_gbox(const POINT4D *point, GBOX *gbox)
+	gbox->xmin = FP_MIN(gbox->xmin, point->x);
+	gbox->xmax = FP_MAX(gbox->xmax, point->x);
+	gbox->ymin = FP_MIN(gbox->ymin, point->y);
+	gbox->ymax = FP_MAX(gbox->ymax, point->y);
+	if (FLAGS_GET_Z(gbox->flags))
+		gbox->zmin = FP_MIN(gbox->zmin, point->z);
+		gbox->zmax = FP_MAX(gbox->zmax, point->z);
+	if (FLAGS_GET_M(gbox->flags))
+		gbox->mmin = FP_MIN(gbox->mmin, point->m);
+		gbox->mmax = FP_MAX(gbox->mmax, point->m);
+ * Projects and merges one homogeneous control point, centralizing zero-weight
+ * rejection before any coordinate reaches a box accumulator.
+static int
+lwnurbscurve_add_hpoint_to_gbox(const NURBS_BBOX_HPOINT *hpoint, GBOX *gbox)
+	POINT4D point;
+	if (lwnurbscurve_hpoint_project(hpoint, &point) == LW_FAILURE)
+	lwnurbscurve_add_point_to_gbox(&point, gbox);
+ * Initializes an empty double-precision accumulator for the requested
+ * dimensions, using inverted extrema for later additions. Float rounding is
+ * deferred until the subdivision stop test.
+static void
+lwnurbscurve_gbox_init(GBOX *gbox, lwflags_t flags)
+	gbox->flags = flags;
+	gbox->xmin = gbox->ymin = gbox->zmin = gbox->mmin = DBL_MAX;
+	gbox->xmax = gbox->ymax = gbox->zmax = gbox->mmax = -DBL_MAX;
+ * Bounds the projected control-point hull of a positive-weight rational Bezier
+ * span, providing the conservative outer bound used during subdivision.
+static int
+lwnurbscurve_bezier_hull_gbox(const NURBS_BBOX_HPOINT *points, uint32_t npoints, lwflags_t flags, GBOX *gbox)
+	uint32_t i;
+	lwnurbscurve_gbox_init(gbox, flags);
+	for (i = 0; i < npoints; i++)
+		if (lwnurbscurve_add_hpoint_to_gbox(&points[i], gbox) == LW_FAILURE)
+ * Bounds the projected endpoints of a Bezier span, providing an inner
+ * coordinate-range bound to compare with the control hull's outer bound.
+static int
+lwnurbscurve_bezier_endpoint_gbox(const NURBS_BBOX_HPOINT *points, uint32_t degree, lwflags_t flags, GBOX *gbox)
+	if (lwnurbscurve_add_hpoint_to_gbox(&points[0], gbox) == LW_FAILURE ||
+	    lwnurbscurve_add_hpoint_to_gbox(&points[degree], gbox) == LW_FAILURE)
+ * Tests whether two boxes round outward to the same float bounds, so refinement
+ * stops once it can no longer change the serialized bounding box. The caller
+ * supplies boxes with identical dimensional flags.
+static int
+lwnurbscurve_gbox_same_float(const GBOX *a, const GBOX *b)
+	if (next_float_down(a->xmin) != next_float_down(b->xmin) || next_float_up(a->xmax) != next_float_up(b->xmax) ||
+	    next_float_down(a->ymin) != next_float_down(b->ymin) || next_float_up(a->ymax) != next_float_up(b->ymax))
+		return LW_FALSE;
+	if (FLAGS_GET_Z(a->flags) &&
+	    (next_float_down(a->zmin) != next_float_down(b->zmin) || next_float_up(a->zmax) != next_float_up(b->zmax)))
+		return LW_FALSE;
+	if (FLAGS_GET_M(a->flags) &&
+	    (next_float_down(a->mmin) != next_float_down(b->mmin) || next_float_up(a->mmax) != next_float_up(b->mmax)))
+		return LW_FALSE;
+	return LW_TRUE;
+ * Detects when floating-point subdivision no longer changes a control net.
+ * Exact equality is intentional: any changed component permits more progress;
+ * otherwise recursion stops with the current conservative hull.
+static int
+lwnurbscurve_hpoints_same(const NURBS_BBOX_HPOINT *a, const NURBS_BBOX_HPOINT *b, uint32_t npoints)
+	uint32_t i;
+		if (a[i].x != b[i].x || a[i].y != b[i].y || a[i].z != b[i].z || a[i].m != b[i].m || a[i].w != b[i].w)
+			return LW_FALSE;
+	return LW_TRUE;
+ * Splits a homogeneous Bezier control net at t = 1/2, producing two control
+ * nets that represent the same curve on their respective half-intervals. For
+ * positive weights, each child's projected control hull is contained in the
+ * parent's hull, so subdivision can only tighten the conservative outer box.
+static void
+lwnurbscurve_bezier_split(const NURBS_BBOX_HPOINT *points,
+			  uint32_t degree,
+			  NURBS_BBOX_HPOINT *left,
+			  NURBS_BBOX_HPOINT *right)
+	uint32_t i, r;
+	NURBS_BBOX_HPOINT tmp[degree + 1];
+	for (i = 0; i <= degree; i++)
+		tmp[i] = points[i];
+	left[0] = tmp[0];
+	right[degree] = tmp[degree];
+	for (r = 1; r <= degree; r++)
+		for (i = 0; i <= degree - r; i++)
+			tmp[i] = lwnurbscurve_hpoint_lerp(&tmp[i], &tmp[i + 1], 0.5);
+		left[r] = tmp[0];
+		right[degree - r] = tmp[degree - r];
+ * Recursively bounds one rational Bezier span. Its projected control hull is a
+ * conservative outer box, while its endpoints give an inner box. Subdivision
+ * narrows the two child hulls and adds their shared split point to the endpoint
+ * sample set. Once inner and outer boxes outward-round to the same float box,
+ * the stored GSERIALIZED box is fixed.
+ * This helper owns the stop test, splitting, and recursion. In particular, it
+ * does not merge an oversized parent hull before descending: only terminal
+ * child hulls are merged into gbox.
+static int
+lwnurbscurve_add_bezier_span_gbox(const NURBS_BBOX_HPOINT *points,
+				  uint32_t degree,
+				  lwflags_t flags,
+				  uint32_t depth,
+				  GBOX *gbox)
+	GBOX hull_gbox, endpoint_gbox;
+	NURBS_BBOX_HPOINT left[degree + 1];
+	NURBS_BBOX_HPOINT right[degree + 1];
+	if (lwnurbscurve_bezier_hull_gbox(points, degree + 1, flags, &hull_gbox) == LW_FAILURE ||
+	    lwnurbscurve_bezier_endpoint_gbox(points, degree, flags, &endpoint_gbox) == LW_FAILURE)
+	/* Positive NURBS weights put each rational Bezier span inside the convex
+	 * hull of its projected control points. Subdivision tightens that hull
+	 * until further refinement cannot change the float bbox that PostGIS stores
+	 * in GSERIALIZED. If arithmetic stops changing the control net first, merge
+	 * the current hull; it is still conservative. */
+	if (depth >= DBL_MANT_DIG || lwnurbscurve_gbox_same_float(&hull_gbox, &endpoint_gbox))
+		gbox_merge(&hull_gbox, gbox);
+	/* Keep splitting behind this helper so every child is subjected to the same
+	 * conservative stop and fallback rules before anything is merged. */
+	lwnurbscurve_bezier_split(points, degree, left, right);
+	if (lwnurbscurve_hpoints_same(left, points, degree + 1) || lwnurbscurve_hpoints_same(right, points, degree + 1))
+	if (lwnurbscurve_add_bezier_span_gbox(left, degree, flags, depth + 1, gbox) == LW_FAILURE ||
+	    lwnurbscurve_add_bezier_span_gbox(right, degree, flags, depth + 1, gbox) == LW_FAILURE)
+ * Counts exact copies of a knot value. Exact comparison is intentional: this
+ * code queries values already present in, or copied directly into, the vector.
+static uint32_t
+lwnurbscurve_knot_multiplicity(const double *knots, uint32_t nknots, double knot)
+	uint32_t i, multiplicity = 0;
+	for (i = 0; i < nknots; i++)
+		if (knots[i] == knot)
+			multiplicity++;
+	return multiplicity;
+ * Finds the half-open knot span [U[i], U[i + 1]) used by knot insertion,
+ * clamping either domain endpoint to its valid boundary span. The work knot
+ * vector has already been validated as nondecreasing.
+static uint32_t
+lwnurbscurve_gbox_find_span(const NURBS_BBOX_WORK *work, double knot)
+	uint32_t npoints = work->npoints;
+	uint32_t degree = work->degree;
+	uint32_t low, high, mid;
+	if (knot >= work->knots[npoints])
+		return npoints - 1;
+	if (knot <= work->knots[degree])
+		return degree;
+	low = degree;
+	high = npoints;
+	mid = (low + high) / 2;
+	while (knot < work->knots[mid] || knot >= work->knots[mid + 1])
+		if (knot < work->knots[mid])
+			high = mid;
+		else
+			low = mid;
+	return mid;
+ * Inserts one knot into the homogeneous B-spline work arrays while preserving
+ * the curve, allowing its spans to be converted into Bezier form.
+static int
+lwnurbscurve_insert_knot_once(NURBS_BBOX_WORK *work, double knot)
+	uint32_t i;
+	uint32_t n = work->npoints - 1;
+	uint32_t k = lwnurbscurve_gbox_find_span(work, knot);
+	uint32_t s = lwnurbscurve_knot_multiplicity(work->knots, work->nknots, knot);
+	double *knots;
+	/* Boehm knot insertion in homogeneous coordinates preserves the rational
+	 * curve while replacing the affected control points by convex blends. */
+	if (s > degree)
+	points = lwalloc(sizeof(NURBS_BBOX_HPOINT) * (work->npoints + 1));
+	knots = lwalloc(sizeof(double) * (work->nknots + 1));
+	for (i = 0; i <= k; i++)
+		knots[i] = work->knots[i];
+	knots[k + 1] = knot;
+	for (i = k + 1; i < work->nknots; i++)
+		knots[i + 1] = work->knots[i];
+	for (i = 0; i <= k - degree; i++)
+		points[i] = work->points[i];
+	for (i = k - s + 1; i <= n + 1; i++)
+		points[i] = work->points[i - 1];
+	for (i = k - degree + 1; i <= k - s; i++)
+		double denom = work->knots[i + degree] - work->knots[i];
+		double alpha;
+		if (denom == 0.0)
+			lwfree(points);
+			lwfree(knots);
+		alpha = (knot - work->knots[i]) / denom;
+		points[i] = lwnurbscurve_hpoint_lerp(&work->points[i - 1], &work->points[i], alpha);
+	lwfree(work->points);
+	lwfree(work->knots);
+	work->points = points;
+	work->knots = knots;
+	work->npoints++;
+	work->nknots++;
+ * Raises a knot to the requested multiplicity through curve-preserving
+ * insertions, preparing domain boundaries and interior Bezier breaks.
+static int
+lwnurbscurve_ensure_knot_multiplicity(NURBS_BBOX_WORK *work, double knot, uint32_t target)
+	while (lwnurbscurve_knot_multiplicity(work->knots, work->nknots, knot) < target)
+		if (lwnurbscurve_insert_knot_once(work, knot) == LW_FAILURE)
+ * Refines the working knot vector into independent Bezier spans, making each
+ * non-empty part suitable for conservative convex-hull bounding.
+static int
+lwnurbscurve_make_bezier_work(NURBS_BBOX_WORK *work, double domain_min, double domain_max)
+	uint32_t i;
+	/* A B-spline decomposes into Bezier spans once the domain endpoints have
+	 * multiplicity p + 1 and every interior knot has multiplicity p. Zero-width
+	 * spans remain in the knot vector and are skipped by the caller. */
+	if (lwnurbscurve_ensure_knot_multiplicity(work, domain_min, work->degree + 1) == LW_FAILURE ||
+	    lwnurbscurve_ensure_knot_multiplicity(work, domain_max, work->degree + 1) == LW_FAILURE)
+	for (i = 0; i < work->nknots;)
+		double knot = work->knots[i];
+		uint32_t multiplicity = 1;
+		while (i + multiplicity < work->nknots && work->knots[i + multiplicity] == knot)
+			multiplicity++;
+		if (knot > domain_min && knot < domain_max && multiplicity < work->degree)
+			i = 0;
+		else
+			i += multiplicity;
+ * Releases the owned arrays used for refinement. Both pointers may be NULL
+ * because initialization can fail after allocating only part of the workset.
+static void
+lwnurbscurve_free_work(NURBS_BBOX_WORK *work)
+	if (work->points)
+	if (work->knots)
+ * Builds owned homogeneous control-point and knot arrays for bounding, so knot
+ * insertion can refine the curve without modifying the input geometry.
+static int
+lwnurbscurve_init_work(const LWNURBSCURVE *curve, NURBS_BBOX_WORK *work)
+	uint32_t i;
+	memset(work, 0, sizeof(NURBS_BBOX_WORK));
+	work->degree = curve->degree;
+	work->npoints = curve->points->npoints;
+	work->knots = lwnurbscurve_get_or_generate_knots(curve, &work->nknots);
+	if (!work->knots || work->nknots == 0)
+	work->points = lwalloc(sizeof(NURBS_BBOX_HPOINT) * work->npoints);
+	for (i = 0; i < work->npoints; i++)
+		POINT4D point;
+		double weight = (curve->weights && i < curve->nweights) ? curve->weights[i] : 1.0;
+		getPoint4d_p(curve->points, i, &point);
+		work->points[i].x = point.x * weight;
+		work->points[i].y = point.y * weight;
+		work->points[i].z = FLAGS_GET_Z(curve->flags) ? point.z * weight : 0.0;
+		work->points[i].m = FLAGS_GET_M(curve->flags) ? point.m * weight : 0.0;
+		work->points[i].w = weight;
 static int lwpoint_calculate_gbox_cartesian(LWPOINT *point, GBOX *gbox)
 	if ( ! point ) return LW_FAILURE;
@@ -700,6 +1178,56 @@ static int lwline_calculate_gbox_cartesian(LWLINE *line, GBOX *gbox)
 	return ptarray_calculate_gbox_cartesian( line->points, gbox );
+ * Computes a conservative Cartesian box for the whole NURBS curve by
+ * subdividing Bezier spans, which can tighten the box beyond what the original
+ * control points or endpoints show. It submits each complete span to
+ * lwnurbscurve_add_bezier_span_gbox(), which decides whether to split and owns
+ * the recursive merge; splitting here would duplicate that policy.
+static int
+lwnurbscurve_calculate_gbox_cartesian(const LWNURBSCURVE *curve, GBOX *gbox)
+	uint32_t i;
+	int found_span = LW_FALSE;
+	double domain_min, domain_max;
+	NURBS_BBOX_WORK work;
+	if (!curve || !curve->points || curve->points->npoints == 0)
+	if (lwnurbscurve_init_work(curve, &work) == LW_FAILURE)
+	domain_min = work.knots[work.degree];
+	domain_max = work.knots[work.npoints];
+	if (domain_max <= domain_min || lwnurbscurve_make_bezier_work(&work, domain_min, domain_max) == LW_FAILURE)
+		lwnurbscurve_free_work(&work);
+	lwnurbscurve_gbox_init(gbox, lwflags(FLAGS_GET_Z(curve->flags), FLAGS_GET_M(curve->flags), 0));
+	for (i = work.degree; i < work.npoints; i++)
+		if (work.knots[i] < domain_min || work.knots[i + 1] > domain_max || work.knots[i + 1] <= work.knots[i])
+			continue;
+			&work.points[i - work.degree], work.degree, gbox->flags, 0, gbox) == LW_FAILURE)
+		found_span = LW_TRUE;
+	return found_span ? LW_SUCCESS : LW_FAILURE;
 static int lwtriangle_calculate_gbox_cartesian(LWTRIANGLE *triangle, GBOX *gbox)
 	if ( ! triangle ) return LW_FAILURE;
@@ -790,18 +1318,7 @@ int lwgeom_calculate_gbox_cartesian(const LWGEOM *lwgeom, GBOX *gbox)
 	case COLLECTIONTYPE:
 		return lwcollection_calculate_gbox_cartesian((LWCOLLECTION *)lwgeom, gbox);
 	case NURBSCURVETYPE:
-		int rv;
-		LWLINE *line;
-		const LWNURBSCURVE *nurbs = (const LWNURBSCURVE*)lwgeom;
-		if (!nurbs->points || nurbs->points->npoints == 0)
-			return LW_FAILURE; /* Empty curve has no bounding box */
-		line = lwnurbscurve_to_linestring(nurbs, 32);
-		rv = lwline_calculate_gbox_cartesian(line, gbox);
-		lwline_free(line);
-		return rv;
+		return lwnurbscurve_calculate_gbox_cartesian((const LWNURBSCURVE *)lwgeom, gbox);
 	/* Never get here, please. */
 	lwerror("unsupported type (%d) - %s", lwgeom->type, lwtype_name(lwgeom->type));
Summary of changes:
 NEWS                              |   2 +
 liblwgeom/cunit/cu_gserialized1.c |  50 ++++
 liblwgeom/gbox.c                  | 541 +++++++++++++++++++++++++++++++++++++-
 3 files changed, 581 insertions(+), 12 deletions(-)
hooks/post-receive
