[SCM] PostGIS branch stable-3.4 updated. 3.4.6-137-gd81d4736b
git at osgeo.org
git at osgeo.org
Sat Aug 15 09:36:33 PDT 2026
the project "PostGIS".
The branch, stable-3.4 has been updated
via d81d4736b575b2a19f8ed0251f366e326bd35724 (commit)
via 0d450587e85d95e9d4d76ed44f8bf1d685069943 (commit)
via aa34af09fc98f4b6f01c8c9d79f27c6b4dce4616 (commit)
from 587ca07129752b33b3e6707634c57bc93d7d2873 (commit)
revisions in full, below.
commit d81d4736b575b2a19f8ed0251f366e326bd35724
Merge: 587ca0712 0d450587e
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Sat Aug 15 09:36:32 2026 -0700
Merge pull request '[3.4] Fix address_standardizer test-security_bounds installcheck failure' (!738) from Komzpa/postgis:fix/addrstd-security-bounds-3.4-20260815 into stable-3.4
The `test-security_bounds` regression test added by [PR 711](https://gitea.osgeo.org/postgis/postgis/pulls/711) failed `installcheck` on every platform that actually runs it, including a clean Linux build: pg_regress reported "1 of 6 tests failed" with a whitespace-only diff. Real psql right-pads an aligned-mode single-column header with a trailing space, the same convention already used by this extension's pre-existing `test-debug_standardize_address` fixture, and the added fixture was missing that space plus the trailing blank line pg_regress appends. All hardening assertions, including the 254/255/256/300-byte scanner-token boundary and oversized or invalid rule rejection, already matched exactly, so only the captured fixture is corrected.
This also extends `.editorconfig` so the PGXS `expected/*.out` fixture convention this extension uses gets the same trim-trailing-whitespace protection PostGIS's own `*_expected` fixtures already have, which is the gap that let the broken fixture ship.
Note: Woodpecker does not run `make -C extensions/address_standardizer installcheck` on any branch, so this failure was only visible on Jenkins Winnie; validated locally on Linux with a clean build (6 of 6 tests pass).
References https://gitea.osgeo.org/postgis/postgis/pulls/711
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/738
commit 0d450587e85d95e9d4d76ed44f8bf1d685069943
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Sat Aug 15 20:17:47 2026 +0400
Protect PGXS extension regression fixtures from whitespace trimming
.editorconfig's "*_expected" exception to trim_trailing_whitespace only
matches PostGIS's own regress/core/<test>_expected naming convention.
extensions/address_standardizer uses the PGXS pg_regress convention
instead, expected/<test>.out, which the glob does not match, so an
editor honoring .editorconfig silently strips the trailing whitespace
that real psql aligned-mode output requires in these files. That is
what produced the test-security_bounds fixture defect fixed in the
previous commit. Extend the exception to cover expected/*.out at any
depth so future PGXS-style fixtures do not repeat it.
diff --git a/.editorconfig b/.editorconfig
index fe803190a..7979a0d23 100644
--- a/.editorconfig
+++ b/.editorconfig
@@ -13,6 +13,13 @@ insert_final_newline = true
[*_expected]
trim_trailing_whitespace = false
+# PGXS-style extension regression fixtures (extensions/*/expected/*.out)
+# use pg_regress's own naming convention instead of *_expected, and need
+# the same protection: aligned-mode psql output legitimately ends lines
+# in trailing whitespace.
+[**/expected/*.out]
+trim_trailing_whitespace = false
# C files want tab indentation
[*.{c,h,h.in}]
indent_style = tab
commit aa34af09fc98f4b6f01c8c9d79f27c6b4dce4616
Date: Sat Aug 15 20:17:38 2026 +0400
Fix test-security_bounds expected output header padding
The new address_standardizer regression test added by the pre-split
address component hardening (GT-711) failed installcheck on every
platform, including a clean Linux build: pg_regress reported
"1 of 6 tests failed" for test-security_bounds.
The regression.diffs is whitespace-only. Real, unmodified psql
right-pads a single-column aligned-mode header to the border width
with a trailing space (compare the pre-existing, unrelated
expected/test-debug_standardize_address.out, whose
"jsonb_array_length " header already carries the same trailing
space); the data row below it does not need padding once its width
already equals the header width. The expected/test-security_bounds.out
fixture added by GT-711 has that trailing space missing from both of
its "*_ok" headers, and is missing the trailing blank line pg_regress
always appends after the last statement's output. Every substantive
assertion in the file (the NOTICE and error text, the accept/reject
behavior at the 254/255/256/300-byte token boundaries, the malformed
rule handling) is untouched and already matched byte for byte.
This is a fixture authoring defect, not a behavior regression: the
address_standardizer hardening itself works as intended. The
.editorconfig "*_expected" trim-trailing-whitespace exception in this
repository matches PostGIS's regress/core naming convention
(<test>_expected) but not the extensions/*/expected/<test>.out PGXS
convention that address_standardizer uses, so any editor honoring
.editorconfig strips this exact header padding on save; a following
commit closes that gap.
diff --git a/extensions/address_standardizer/expected/test-security_bounds.out b/extensions/address_standardizer/expected/test-security_bounds.out
index 8bfa88c8e..7261ba068 100644
--- a/extensions/address_standardizer/expected/test-security_bounds.out
+++ b/extensions/address_standardizer/expected/test-security_bounds.out
@@ -65,7 +65,7 @@ BEGIN
END
$scanner_bounds$;
SELECT 'scanner_bounds_ok' AS scanner_bounds_ok;
- scanner_bounds_ok
+ scanner_bounds_ok
scanner_bounds_ok
(1 row)
@@ -116,7 +116,8 @@ $$;
NOTICE: load_roles: failed to add rule 1 (7): 1 -1 5 -1 5 0
NOTICE: bad-rule-type: CreateStd: failed to load 't_bad_rule_type' for rules
SELECT 'security_bounds_ok' AS security_bounds_ok;
- security_bounds_ok
+ security_bounds_ok
security_bounds_ok
(1 row)
Summary of changes:
.editorconfig | 7 +++++++
extensions/address_standardizer/expected/test-security_bounds.out | 5 +++--
2 files changed, 10 insertions(+), 2 deletions(-)
hooks/post-receive
