[SCM] PostGIS branch stable-3.3 updated. 3.3.10-130-g3ce1a3653
Sat Aug 15 09:36:38 PDT 2026
the project "PostGIS".
The branch, stable-3.3 has been updated
       via  3ce1a36539ec8db913f226f56288593433c11516 (commit)
       via  6746b140c1478b148ca6e1ec152e5bd6c6b3294b (commit)
       via  cb73987847789a1cd6ea77461745134e94596512 (commit)
       via  327a85bfe6669d60e60e38eed4779c69dc76e43e (commit)
      from  fd53d6f18530e34f9551aadb07ebbf0c70d45002 (commit)
revisions in full, below.
commit 3ce1a36539ec8db913f226f56288593433c11516
Merge: fd53d6f18 6746b140c
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Sat Aug 15 09:36:37 2026 -0700
    Merge pull request '[3.3] Fix address_standardizer test-security_bounds build and installcheck failure' (!739) from Komzpa/postgis:fix/addrstd-security-bounds-3.3-20260815 into stable-3.3
    [PR 712](https://gitea.osgeo.org/postgis/postgis/pulls/712) extended `REGRESS` to include `test-security_bounds` but did not add the matching `sql/test-security_bounds.sql` prerequisite to the `all:` target, so `installcheck` could not find the generated test file at all ("cannot open .../sql/test-security_bounds.sql: No such file"). Restoring the prerequisite, matching stable-3.4 through stable-3.6, surfaces the same whitespace-only fixture defect fixed in the companion pull requests for the newer branches: real psql pads an aligned-mode single-column header with a trailing space and appends a trailing blank line, and the committed fixture was never actually run against pg_regress before merge. Both are fixed here, and `.editorconfig` gains the same trim-trailing-whitespace protection for `expected/*.out` fixtures that PostGIS's own `*_expected` files already have.
    Note: Woodpecker does not run `make -C extensions/address_standardizer installcheck` on any branch, so this failure was only visible on Jenkins Winnie; validated locally on Linux with a clean build (5 of 5 tests pass).
    References https://gitea.osgeo.org/postgis/postgis/pulls/712
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/739
commit 6746b140c1478b148ca6e1ec152e5bd6c6b3294b
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Sat Aug 15 20:22:23 2026 +0400
    Protect PGXS extension regression fixtures from whitespace trimming
    .editorconfig's "*_expected" exception to trim_trailing_whitespace only
    matches PostGIS's own regress/core/<test>_expected naming convention.
    extensions/address_standardizer uses the PGXS pg_regress convention
    instead, expected/<test>.out, which the glob does not match, so an
    editor honoring .editorconfig silently strips the trailing whitespace
    that real psql aligned-mode output requires in these files. That is
    what produced the test-security_bounds fixture defect fixed in the
    previous commit. Extend the exception to cover expected/*.out at any
    depth so future PGXS-style fixtures do not repeat it.
diff --git a/.editorconfig b/.editorconfig
index e8c970e3e..5340c503e 100644
--- a/.editorconfig
+++ b/.editorconfig
@@ -13,6 +13,13 @@ insert_final_newline = true
 [*_expected]
 trim_trailing_whitespace = false
+# PGXS-style extension regression fixtures (extensions/*/expected/*.out)
+# use pg_regress's own naming convention instead of *_expected, and need
+# the same protection: aligned-mode psql output legitimately ends lines
+# in trailing whitespace.
+[**/expected/*.out]
+trim_trailing_whitespace = false
 # C files want tab indentation
 [*.{c,h,h.in}]
 indent_style = tab
commit cb73987847789a1cd6ea77461745134e94596512
Date:   Sat Aug 15 20:22:12 2026 +0400
    Fix test-security_bounds expected output header padding
    With the sql/test-security_bounds.sql build prerequisite restored,
    installcheck runs the test but still fails: pg_regress reports
    "1 of 5 tests failed" for test-security_bounds.
    The regression.diffs is whitespace-only. Real, unmodified psql
    right-pads a single-column aligned-mode header to the border width
    with a trailing space; the data row below it does not need padding
    once its width already equals the header width. The
    expected/test-security_bounds.out fixture added by GT-712 has that
    trailing space missing from both of its "*_ok" headers, and is
    missing the trailing blank line pg_regress always appends after the
    last statement's output. Every substantive assertion in the file
    (the NOTICE and error text, the accept/reject behavior at the
    254/255/256/300-byte token boundaries, the malformed rule handling)
    is untouched and already matched byte for byte.
    This is a fixture authoring defect, not a behavior regression: the
    address_standardizer hardening itself works as intended. The
    .editorconfig "*_expected" trim-trailing-whitespace exception in this
    repository matches PostGIS's regress/core naming convention
    (<test>_expected) but not the extensions/*/expected/<test>.out PGXS
    convention that address_standardizer uses, so any editor honoring
    .editorconfig strips this exact header padding on save; a following
    commit closes that gap.
diff --git a/extensions/address_standardizer/expected/test-security_bounds.out b/extensions/address_standardizer/expected/test-security_bounds.out
index 8bfa88c8e..7261ba068 100644
--- a/extensions/address_standardizer/expected/test-security_bounds.out
+++ b/extensions/address_standardizer/expected/test-security_bounds.out
@@ -65,7 +65,7 @@ BEGIN
 END
 $scanner_bounds$;
 SELECT 'scanner_bounds_ok' AS scanner_bounds_ok;
- scanner_bounds_ok
+ scanner_bounds_ok
  scanner_bounds_ok
 (1 row)
@@ -116,7 +116,8 @@ $$;
 NOTICE:  load_roles: failed to add rule 1 (7): 1 -1 5 -1 5 0
 NOTICE:  bad-rule-type: CreateStd: failed to load 't_bad_rule_type' for rules
 SELECT 'security_bounds_ok' AS security_bounds_ok;
- security_bounds_ok
+ security_bounds_ok
  security_bounds_ok
 (1 row)
commit 327a85bfe6669d60e60e38eed4779c69dc76e43e
Date:   Sat Aug 15 20:22:05 2026 +0400
    Build sql/test-security_bounds.sql so installcheck can find it
    extensions/address_standardizer's REGRESS variable was extended for
    test-security_bounds by GT-712, but the Makefile.in "all:" target's
    prerequisite list, which drives the "sql/%.sql: %.sql.in" pattern
    rule that actually preprocesses each test-*.sql.in into sql/*.sql,
    was not updated to match. pg_regress therefore could not find
    sql/test-security_bounds.sql at all:
      test test-security_bounds ... /bin/sh: 1: cannot open
    installcheck failed outright (make error 2) rather than running the
    test, on both PG15 and a from-clean build. Add the missing
    prerequisite alongside the extension's other generated test scripts,
    matching stable-3.4/3.5/3.6, which already list it.
diff --git a/extensions/address_standardizer/Makefile.in b/extensions/address_standardizer/Makefile.in
index d382ef19e..9370861bc 100644
--- a/extensions/address_standardizer/Makefile.in
+++ b/extensions/address_standardizer/Makefile.in
@@ -50,7 +50,7 @@ DATA_built = \
 all:  sql/address_standardizer_pre.sql sql/address_standardizer.sql sql/address_standardizer--1.0--$(EXTVERSION).sql sql/$(EXTENSION)--$(EXTVERSION).sql sql/$(EXTENSION)--ANY--$(EXTVERSION).sql \
  sql/$(EXTENSION)_data_us.sql sql/address_standardizer-- at POSTGIS_LIB_VERSION@.sql sql/$(EXTENSION)_data_us-- at POSTGIS_LIB_VERSION@.sql  sql/$(EXTENSION)_data_us--$(EXTVERSION)--$(EXTVERSION)next.sql \
 sql/$(EXTENSION)_data_us--$(EXTVERSION)next--$(EXTVERSION).sql sql/$(EXTENSION)_data_us--ANY--$(EXTVERSION).sql \
-sql/test-init-extensions.sql sql/test-parseaddress.sql sql/test-standardize_address_1.sql sql/test-standardize_address_2.sql
+sql/test-init-extensions.sql sql/test-parseaddress.sql sql/test-standardize_address_1.sql sql/test-standardize_address_2.sql sql/test-security_bounds.sql
 DOCS = README.address_standardizer
 PG_CPPFLAGS = @CFLAGS@ @CPPFLAGS@ -DPCRE_VERSION=@PCRE_VERSION@
Summary of changes:
 .editorconfig                                                     | 7 +++++++
 extensions/address_standardizer/Makefile.in                       | 2 +-
 extensions/address_standardizer/expected/test-security_bounds.out | 5 +++--
 3 files changed, 11 insertions(+), 3 deletions(-)
hooks/post-receive
