[SCM] PostGIS branch master updated. 3.7.0beta2-44-ga87600d95
git at osgeo.org
git at osgeo.org
Sat Aug 15 09:37:21 PDT 2026
the project "PostGIS".
via a87600d95611a7c22487f0fa01155bd2fe17f6a2 (commit)
via 43e13fe2235e36d5710b83566e33754ed3ae4105 (commit)
from 89cd60efddcd85323dd9ed9ec33cd3a87dbf1091 (commit)
revisions in full, below.
commit a87600d95611a7c22487f0fa01155bd2fe17f6a2
Merge: 89cd60efd 43e13fe22
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Sat Aug 15 09:37:19 2026 -0700
Merge pull request 'docs: allow DOCTYPE without entities in docbook QA parser' (!735) from Komzpa/postgis:fix/docbook-doctype-selfbuild-20260815 into master
`utils/docs/xml_tree.py` rejected any document containing the literal byte sequence `<!DOCTYPE` before parsing. That guard was added in [PR 719](https://gitea.osgeo.org/postgis/postgis/pulls/719) to close an XXE hole, but it also rejects our own `doc/postgis-out.xml`: xmllint always emits a DocBook DTD DOCTYPE for it, and that DOCTYPE's internal subset carries dozens of already-resolved `SYSTEM` and literal entity declarations left over from assembling `doc/*.xml` into one file at build time. Every `check-docbook-markup`, `lint-html`, `ref-index`, and `postgis_exampletest.py` invocation on master therefore failed on the project's own generated output (first broken pipeline #7002 on Woodpecker). The same byte scan also false-positives on documentation body content that happens to contain the text `<!DOCTYPE`, such as the X3D example in `reference_output.xml`, which sits inside a CDATA section and is not a real prolog DOCTYPE at all.
This replaces the byte scan with an entity-aware guard. A lightweight expat pass collects the names of literal-value ("internal") general entities the DOCTYPE declares, without an `ExternalEntityRefHandler` and without parameter-entity parsing, so nothing external is fetched during this pass either. If the document body actually references one of those internal entity names, parsing is rejected before the real tree-building parse runs; a harmless DOCTYPE whose declarations are unreferenced, which is exactly the shape our own generated corpus has, now parses normally. External entities were already never resolved via the existing `feature_external_ges`/`feature_external_pes` settings; `parse()` now also installs an `EntityResolver` that returns empty content for any external identifier, so the DocBook DTD and any external general entity stay unresolved even if a given libxml2/expat build ignores the feature flags.
Two regression tests added alongside the existing one: a DOCTYPE shaped like `postgis-out.xml`'s, with declared but unreferenced entities, must parse; a DOCTYPE that declares and references an entity must still be rejected.
Validated by regenerating `postgis-out.xml` exactly as `doc/Makefile.in` does (`xmllint --noent`) and running the `Makefile:815` invocation directly, plus `postgis_exampletest.py --report` and `docbook_qa.py ref-index` against the same file; all pass, and a synthetic XXE document does not leak file content. `utils/docs/xml_tree.py` is master-only (absent on `stable-3.6`), so no NEWS entry and no backpatch.
References https://gitea.osgeo.org/postgis/postgis/pulls/719
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/735
commit 43e13fe2235e36d5710b83566e33754ed3ae4105
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Sat Aug 15 20:16:15 2026 +0400
utils/docs/xml_tree.py rejected any document containing the literal byte
sequence "<!DOCTYPE" before parsing. That guard was added to close an XXE
hole, but it also rejects our own doc/postgis-out.xml: xmllint always emits a
of already-resolved SYSTEM and literal entity declarations left over from
assembling doc/*.xml into one file at build time. Every check-docbook-markup,
lint-html, ref-index, and postgis_exampletest.py invocation on master
therefore failed on the project's own generated output. The same byte scan
the text "<!DOCTYPE", such as the X3D example in reference_output.xml, which
is protected by a CDATA section and is not a real prolog DOCTYPE at all.
Replace the byte scan with an entity-aware guard. A lightweight expat pass
DOCTYPE declares, without an ExternalEntityRefHandler and without enabling
parameter-entity parsing, so nothing external is ever fetched during this
were already never resolved via the existing feature_external_ges and
feature_external_pes settings; parse() now also installs an EntityResolver
that returns empty content for any external SYSTEM or PUBLIC identifier, so
Added two regression tests to utils/docs/tests/test_docbook_qa.py alongside
the existing one: a DOCTYPE shaped like postgis-out.xml's, with declared but
diff --git a/utils/docs/tests/test_docbook_qa.py b/utils/docs/tests/test_docbook_qa.py
index aa550da77..2f4b07aa1 100644
--- a/utils/docs/tests/test_docbook_qa.py
+++ b/utils/docs/tests/test_docbook_qa.py
@@ -68,6 +68,27 @@ class DocBookSourceLintTest(unittest.TestCase):
with self.assertRaises(Exception):
parse_xml(path)
+ def test_xml_tree_allows_doctype_without_entity_references(self):
+ # postgis-out.xml itself carries a DOCTYPE: xmllint emits the DocBook DTD's
+ # public identifier plus dozens of unreferenced SYSTEM/literal entity
+ # declarations left over from assembling doc/*.xml at build time. None of
+ # that is an attack when nothing in the document body asks the parser to
+ # expand any of it, so a harmless DOCTYPE like this one must still parse.
+ path = write_tmp(
+ ".xml",
+ '<!DOCTYPE book PUBLIC "-//OASIS//DTD DocBook XML 5.0//EN" '
+ '"http://docbook.org/xml/5.0/dtd/docbook.dtd" ['
+ '<!ENTITY last_release_version "3.6.0">'
+ '<!ENTITY introduction SYSTEM "introduction.xml">'
+ + DOCBOOK_OPEN
+ + '<para>no custom entity is referenced here</para>'
+ + DOCBOOK_CLOSE,
+ tree = parse_xml(path)
+ self.assertEqual("book", tree.tree.getroot().tag.rsplit("}", 1)[-1])
def test_mixed_programlisting_dash_run_markers_and_sql_comments(self):
for output in ("left | right\n----|----\n1 | 2", "----RESULT output ---\n1"):
with self.subTest(output=output):
diff --git a/utils/docs/xml_tree.py b/utils/docs/xml_tree.py
index 042a71be6..502dcbecb 100644
--- a/utils/docs/xml_tree.py
+++ b/utils/docs/xml_tree.py
@@ -2,11 +2,14 @@
from __future__ import annotations
+import re
from dataclasses import dataclass
from pathlib import Path
import xml.etree.ElementTree as ET
+import xml.parsers.expat
import xml.sax
-from xml.sax.handler import ContentHandler, feature_external_ges, feature_external_pes, feature_namespaces
+from xml.sax.handler import ContentHandler, EntityResolver, feature_external_ges, feature_external_pes, feature_namespaces
+from xml.sax.xmlreader import InputSource
@dataclass
@@ -75,21 +78,62 @@ class _TreeBuilder(ContentHandler):
current.text = (current.text or "") + content
-def _reject_doctype(path):
+_GENERAL_ENTITY_REFERENCE_RE = re.compile(rb"&([A-Za-z_][\w.-]*);")
+def _internal_general_entity_names(path):
+ """Return the names of literal-value ("internal") general entities the
+ document's DOCTYPE declares, without resolving or fetching anything external.
+ Our own generated postgis-out.xml carries a DOCTYPE whose internal subset
+ declares dozens of SYSTEM entities; xmllint uses those only to assemble
+ doc/*.xml into one file at build time, so by the time this module sees the
+ output they are unreferenced text in the DOCTYPE. They are external, so
+ ExternalEntityRefHandler is left unset here and they are never resolved or
+ counted. Only an entity with a literal replacement value can inject
+ attacker-controlled text or drive an entity-expansion blowup if the document
+ goes on to reference it, so only those names are worth tracking.
+ names = set()
+ def entity_decl(name, is_parameter_entity, value, _base, _system_id, _public_id, _notation_name):
+ if value is not None and not is_parameter_entity:
+ names.add(name)
+ parser = xml.parsers.expat.ParserCreate()
+ parser.EntityDeclHandler = entity_decl
with Path(path).open("rb") as handle:
- previous = b""
- while True:
- chunk = handle.read(8192)
- if not chunk:
- return
- haystack = previous + chunk.upper()
- if b"<!DOCTYPE" in haystack:
- raise xml.sax.SAXException("DOCTYPE declarations are not supported")
- previous = haystack[-8:]
+ parser.ParseFile(handle)
+ return names
+def _reject_internal_entity_references(path):
+ entity_names = _internal_general_entity_names(path)
+ if not entity_names:
+ return
+ data = Path(path).read_bytes()
+ for match in _GENERAL_ENTITY_REFERENCE_RE.finditer(data):
+ name = match.group(1).decode("ascii", "replace")
+ if name in entity_names:
+ raise xml.sax.SAXException(f"entity references are not supported: &{name};")
+class _EmptyEntityResolver(EntityResolver):
+ """Refuse to fetch an external entity's replacement content.
+ feature_external_ges/feature_external_pes below already tell a conformant
+ parser not to resolve external entities, but that support is best-effort
+ (see the try/except immediately below). Overriding resolveEntity makes the
+ refusal unconditional: any external SYSTEM/PUBLIC identifier, including the
+ DocBook DTD itself, resolves to an empty document instead of a real fetch.
+ def resolveEntity(self, _public_id, _system_id):
+ return InputSource()
def parse(path):
- _reject_doctype(path)
+ _reject_internal_entity_references(path)
parser = xml.sax.make_parser()
parser.setFeature(feature_namespaces, True)
for feature in (feature_external_ges, feature_external_pes):
@@ -97,6 +141,7 @@ def parse(path):
parser.setFeature(feature, False)
except (xml.sax.SAXNotRecognizedException, xml.sax.SAXNotSupportedException):
pass
+ parser.setEntityResolver(_EmptyEntityResolver())
builder = _TreeBuilder()
parser.setContentHandler(builder)
parser.parse(str(Path(path)))
Summary of changes:
utils/docs/tests/test_docbook_qa.py | 21 +++++++++++
utils/docs/xml_tree.py | 69 ++++++++++++++++++++++++++++++-------
2 files changed, 78 insertions(+), 12 deletions(-)
hooks/post-receive
