[SCM] PostGIS branch stable-3.2 updated. 3.2.10-119-gd3b9cc670
git at osgeo.org
git at osgeo.org
Sat Aug 15 09:55:56 PDT 2026
the project "PostGIS".
The branch, stable-3.2 has been updated
via d3b9cc6700e576a0a66a91821892bd0250548f85 (commit)
via b5ab21141f8519684622a11ccfa9a0186fb9d9b5 (commit)
via 4e7056ae9e60254687306e6ea14a26df46e896cf (commit)
via 2c403d7a05a8882abc366aa178e5e5c9a2845f24 (commit)
from 5dc29232b5d7759e7b90dfede858096df4811c09 (commit)
revisions in full, below.
commit d3b9cc6700e576a0a66a91821892bd0250548f85
Merge: 5dc29232b b5ab21141
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Sat Aug 15 09:55:55 2026 -0700
Merge pull request '[3.2] Fix address_standardizer test-security_bounds build and installcheck failure' (!740) from Komzpa/postgis:fix/addrstd-security-bounds-3.2-20260815 into stable-3.2
[PR 713](https://gitea.osgeo.org/postgis/postgis/pulls/713) extended `REGRESS` to include `test-security_bounds` but did not add the matching `sql/test-security_bounds.sql` prerequisite to the `all:` target, so `installcheck` could not find the generated test file at all ("cannot open .../sql/test-security_bounds.sql: No such file"). Restoring the prerequisite, matching stable-3.4 through stable-3.6, surfaces the same whitespace-only fixture defect fixed in the companion pull requests for the newer branches: real psql pads an aligned-mode single-column header with a trailing space and appends a trailing blank line, and the committed fixture was never actually run against pg_regress before merge. Both are fixed here, and `.editorconfig` gains the same trim-trailing-whitespace protection for `expected/*.out` fixtures that PostGIS's own `*_expected` files already have.
Note: Woodpecker does not run `make -C extensions/address_standardizer installcheck` on any branch, so this failure was only visible on Jenkins Winnie; validated locally on Linux with a clean build (5 of 5 tests pass).
References https://gitea.osgeo.org/postgis/postgis/pulls/713
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/740
commit b5ab21141f8519684622a11ccfa9a0186fb9d9b5
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Sat Aug 15 20:24:18 2026 +0400
Protect PGXS extension regression fixtures from whitespace trimming
.editorconfig's "*_expected" exception to trim_trailing_whitespace only
matches PostGIS's own regress/core/<test>_expected naming convention.
extensions/address_standardizer uses the PGXS pg_regress convention
instead, expected/<test>.out, which the glob does not match, so an
editor honoring .editorconfig silently strips the trailing whitespace
that real psql aligned-mode output requires in these files. That is
what produced the test-security_bounds fixture defect fixed in the
previous commit. Extend the exception to cover expected/*.out at any
depth so future PGXS-style fixtures do not repeat it.
diff --git a/.editorconfig b/.editorconfig
index 9d91e6ff2..a5fde7794 100644
--- a/.editorconfig
+++ b/.editorconfig
@@ -13,6 +13,13 @@ insert_final_newline = true
[*_expected]
trim_trailing_whitespace = false
+# PGXS-style extension regression fixtures (extensions/*/expected/*.out)
+# use pg_regress's own naming convention instead of *_expected, and need
+# the same protection: aligned-mode psql output legitimately ends lines
+# in trailing whitespace.
+[**/expected/*.out]
+trim_trailing_whitespace = false
# C files want tab indentation
[*.{c,h,h.in}]
indent_style = tab
commit 4e7056ae9e60254687306e6ea14a26df46e896cf
Date: Sat Aug 15 20:24:07 2026 +0400
Fix test-security_bounds expected output header padding
With the sql/test-security_bounds.sql build prerequisite restored,
installcheck runs the test but still fails: pg_regress reports
"1 of 5 tests failed" for test-security_bounds.
The regression.diffs is whitespace-only. Real, unmodified psql
right-pads a single-column aligned-mode header to the border width
with a trailing space; the data row below it does not need padding
once its width already equals the header width. The
expected/test-security_bounds.out fixture added by GT-713 has that
trailing space missing from both of its "*_ok" headers, and is
missing the trailing blank line pg_regress always appends after the
last statement's output. Every substantive assertion in the file
(the NOTICE and error text, the accept/reject behavior at the
254/255/256/300-byte token boundaries, the malformed rule handling)
is untouched and already matched byte for byte.
This is a fixture authoring defect, not a behavior regression: the
address_standardizer hardening itself works as intended. The
.editorconfig "*_expected" trim-trailing-whitespace exception in this
repository matches PostGIS's regress/core naming convention
(<test>_expected) but not the extensions/*/expected/<test>.out PGXS
convention that address_standardizer uses, so any editor honoring
.editorconfig strips this exact header padding on save; a following
commit closes that gap.
diff --git a/extensions/address_standardizer/expected/test-security_bounds.out b/extensions/address_standardizer/expected/test-security_bounds.out
index 8bfa88c8e..7261ba068 100644
--- a/extensions/address_standardizer/expected/test-security_bounds.out
+++ b/extensions/address_standardizer/expected/test-security_bounds.out
@@ -65,7 +65,7 @@ BEGIN
END
$scanner_bounds$;
SELECT 'scanner_bounds_ok' AS scanner_bounds_ok;
- scanner_bounds_ok
+ scanner_bounds_ok
scanner_bounds_ok
(1 row)
@@ -116,7 +116,8 @@ $$;
NOTICE: load_roles: failed to add rule 1 (7): 1 -1 5 -1 5 0
NOTICE: bad-rule-type: CreateStd: failed to load 't_bad_rule_type' for rules
SELECT 'security_bounds_ok' AS security_bounds_ok;
- security_bounds_ok
+ security_bounds_ok
security_bounds_ok
(1 row)
commit 2c403d7a05a8882abc366aa178e5e5c9a2845f24
Date: Sat Aug 15 20:23:59 2026 +0400
Build sql/test-security_bounds.sql so installcheck can find it
extensions/address_standardizer's REGRESS variable was extended for
test-security_bounds by GT-713, but the Makefile.in "all:" target's
prerequisite list, which drives the "sql/%.sql: %.sql.in" pattern
rule that actually preprocesses each test-*.sql.in into sql/*.sql,
was not updated to match. pg_regress therefore could not find
sql/test-security_bounds.sql at all:
test test-security_bounds ... /bin/sh: 1: cannot open
installcheck failed outright (make error 2) rather than running the
test, on both PG15 and a from-clean build. Add the missing
prerequisite alongside the extension's other generated test scripts,
matching stable-3.4/3.5/3.6, which already list it.
diff --git a/extensions/address_standardizer/Makefile.in b/extensions/address_standardizer/Makefile.in
index e8f71b724..5f836e6b5 100644
--- a/extensions/address_standardizer/Makefile.in
+++ b/extensions/address_standardizer/Makefile.in
@@ -48,7 +48,7 @@ DATA_built = \
all: sql/address_standardizer.sql sql/address_standardizer--1.0--$(EXTVERSION).sql sql/$(EXTENSION)--$(EXTVERSION).sql sql/$(EXTENSION)--ANY--$(EXTVERSION).sql \
sql/$(EXTENSION)_data_us.sql sql/address_standardizer-- at POSTGIS_LIB_VERSION@.sql sql/$(EXTENSION)_data_us-- at POSTGIS_LIB_VERSION@.sql sql/$(EXTENSION)_data_us--$(EXTVERSION)--$(EXTVERSION)next.sql \
sql/$(EXTENSION)_data_us--$(EXTVERSION)next--$(EXTVERSION).sql sql/$(EXTENSION)_data_us--ANY--$(EXTVERSION).sql \
-sql/test-init-extensions.sql sql/test-parseaddress.sql sql/test-standardize_address_1.sql sql/test-standardize_address_2.sql
+sql/test-init-extensions.sql sql/test-parseaddress.sql sql/test-standardize_address_1.sql sql/test-standardize_address_2.sql sql/test-security_bounds.sql
EXTRA_CLEAN = sql/
Summary of changes:
.editorconfig | 7 +++++++
extensions/address_standardizer/Makefile.in | 2 +-
extensions/address_standardizer/expected/test-security_bounds.out | 5 +++--
3 files changed, 11 insertions(+), 3 deletions(-)
hooks/post-receive
