[SCM] PostGIS branch stable-3.5 updated. 3.5.7-132-ge7811d246
Sat Aug 15 09:56:07 PDT 2026
the project "PostGIS".
The branch, stable-3.5 has been updated
       via  e7811d2463cafd4b70cd65b8296f8638a64af3c2 (commit)
       via  6e206f337893081d63082423441bd4c5355fa6da (commit)
       via  cfcfbbab82ea3e6109911f6346340a409c9779aa (commit)
      from  b5add6a268caa27eb7ba47cba8cf7155678b1250 (commit)
revisions in full, below.
commit e7811d2463cafd4b70cd65b8296f8638a64af3c2
Merge: b5add6a26 6e206f337
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Sat Aug 15 09:56:06 2026 -0700
    Merge pull request '[3.5] Fix address_standardizer test-security_bounds installcheck failure' (!737) from Komzpa/postgis:fix/addrstd-security-bounds-3.5-20260815 into stable-3.5
    The `test-security_bounds` regression test added by [PR 710](https://gitea.osgeo.org/postgis/postgis/pulls/710) failed `installcheck` on every platform that actually runs it, including a clean Linux build: pg_regress reported "1 of 6 tests failed" with a whitespace-only diff. Real psql right-pads an aligned-mode single-column header with a trailing space, the same convention already used by this extension's pre-existing `test-debug_standardize_address` fixture, and the added fixture was missing that space plus the trailing blank line pg_regress appends. All hardening assertions, including the 254/255/256/300-byte scanner-token boundary and oversized or invalid rule rejection, already matched exactly, so only the captured fixture is corrected.
    This also extends `.editorconfig` so the PGXS `expected/*.out` fixture convention this extension uses gets the same trim-trailing-whitespace protection PostGIS's own `*_expected` fixtures already have, which is the gap that let the broken fixture ship.
    Note: Woodpecker does not run `make -C extensions/address_standardizer installcheck` on any branch, so this failure was only visible on Jenkins Winnie; validated locally on Linux with a clean build (6 of 6 tests pass on both PG15 and PG16, the two configurations red on Jenkins Winnie).
    References https://gitea.osgeo.org/postgis/postgis/pulls/710
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/737
commit 6e206f337893081d63082423441bd4c5355fa6da
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Sat Aug 15 20:10:03 2026 +0400
    Protect PGXS extension regression fixtures from whitespace trimming
    .editorconfig's "*_expected" exception to trim_trailing_whitespace only
    matches PostGIS's own regress/core/<test>_expected naming convention.
    extensions/address_standardizer uses the PGXS pg_regress convention
    instead, expected/<test>.out, which the glob does not match, so an
    editor honoring .editorconfig silently strips the trailing whitespace
    that real psql aligned-mode output requires in these files. That is
    what produced the test-security_bounds fixture defect fixed in the
    previous commit. Extend the exception to cover expected/*.out at any
    depth so future PGXS-style fixtures do not repeat it.
diff --git a/.editorconfig b/.editorconfig
index 8b62171f9..61dfe7af7 100644
--- a/.editorconfig
+++ b/.editorconfig
@@ -13,6 +13,13 @@ insert_final_newline = true
 [*_expected]
 trim_trailing_whitespace = false
+# PGXS-style extension regression fixtures (extensions/*/expected/*.out)
+# use pg_regress's own naming convention instead of *_expected, and need
+# the same protection: aligned-mode psql output legitimately ends lines
+# in trailing whitespace.
+[**/expected/*.out]
+trim_trailing_whitespace = false
 # C files want tab indentation
 [*.{c,h,h.in}]
 indent_style = tab
commit cfcfbbab82ea3e6109911f6346340a409c9779aa
Date:   Sat Aug 15 20:09:55 2026 +0400
    Fix test-security_bounds expected output header padding
    The new address_standardizer regression test added by the pre-split
    address component hardening (GT-710) failed installcheck on every
    platform, including a clean Linux build: pg_regress reported
    "1 of 6 tests failed" for test-security_bounds.
    The regression.diffs is whitespace-only. Real, unmodified psql
    right-pads a single-column aligned-mode header to the border width
    with a trailing space (compare the pre-existing, unrelated
    expected/test-debug_standardize_address.out, whose
    "jsonb_array_length " header already carries the same trailing
    space); the data row below it does not need padding once its width
    already equals the header width. The expected/test-security_bounds.out
    fixture added by GT-710 has that trailing space missing from both of
    its "*_ok" headers, and is missing the trailing blank line pg_regress
    always appends after the last statement's output. Every substantive
    assertion in the file (the NOTICE and error text, the accept/reject
    behavior at the 254/255/256/300-byte token boundaries, the malformed
    rule handling) is untouched and already matched byte for byte.
    This is a fixture authoring defect, not a behavior regression: the
    address_standardizer hardening itself works as intended. The
    .editorconfig "*_expected" trim-trailing-whitespace exception in this
    repository matches PostGIS's regress/core naming convention
    (<test>_expected) but not the extensions/*/expected/<test>.out PGXS
    convention that address_standardizer uses, so any editor honoring
    .editorconfig strips this exact header padding on save; a following
    commit closes that gap.
diff --git a/extensions/address_standardizer/expected/test-security_bounds.out b/extensions/address_standardizer/expected/test-security_bounds.out
index 8bfa88c8e..7261ba068 100644
--- a/extensions/address_standardizer/expected/test-security_bounds.out
+++ b/extensions/address_standardizer/expected/test-security_bounds.out
@@ -65,7 +65,7 @@ BEGIN
 END
 $scanner_bounds$;
 SELECT 'scanner_bounds_ok' AS scanner_bounds_ok;
- scanner_bounds_ok
+ scanner_bounds_ok
  scanner_bounds_ok
 (1 row)
@@ -116,7 +116,8 @@ $$;
 NOTICE:  load_roles: failed to add rule 1 (7): 1 -1 5 -1 5 0
 NOTICE:  bad-rule-type: CreateStd: failed to load 't_bad_rule_type' for rules
 SELECT 'security_bounds_ok' AS security_bounds_ok;
- security_bounds_ok
+ security_bounds_ok
  security_bounds_ok
 (1 row)
Summary of changes:
 .editorconfig                                                     | 7 +++++++
 extensions/address_standardizer/expected/test-security_bounds.out | 5 +++--
 2 files changed, 10 insertions(+), 2 deletions(-)
hooks/post-receive
