[SCM] PostGIS branch master updated. 3.7.0beta2-46-g40b61a5fc
git at osgeo.org
git at osgeo.org
Sat Aug 15 09:57:21 PDT 2026
the project "PostGIS".
via 40b61a5fc02f0bb2d07be263e180e7f24c6c5a95 (commit)
via 1e4de3b9810b2c1f54be73d74011e1b9389bd958 (commit)
from a87600d95611a7c22487f0fa01155bd2fe17f6a2 (commit)
revisions in full, below.
commit 40b61a5fc02f0bb2d07be263e180e7f24c6c5a95
Merge: a87600d95 1e4de3b98
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Sat Aug 15 09:57:20 2026 -0700
Merge pull request 'docs: document NEWS entry workflow' (!734) from Komzpa/postgis:docs/news-guide-20260813 into master
Add a concise maintainer checklist for PostGIS NEWS entries. It covers entry scope, placement, attribution, release preparation, checker commands, and backpatch wording.
The guide uses neutral examples and keeps the base-ref and released-entry rules explicit.
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/734
commit 1e4de3b9810b2c1f54be73d74011e1b9389bd958
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Thu Aug 13 20:59:21 2026 +0400
diff --git a/doc/development/maintenance/_index.md b/doc/development/maintenance/_index.md
index 312010bb3..27dc9f2c5 100644
--- a/doc/development/maintenance/_index.md
+++ b/doc/development/maintenance/_index.md
@@ -66,8 +66,10 @@ OSGeo legal counsel before committing.
For the maintained commit-message, branch-target, authorship, and post-push
rules distilled from RFC-5, see [Commit and branch guidelines](commit-guidelines.md).
-For supported-branch fix propagation, provenance, `NEWS`, and Trac follow-up
-rules, see [Backpatching fixes](backpatching.md).
+For `NEWS` wording, prerelease sections, release cleanup, and checker rules,
+see [NEWS entries](news.md). For supported-branch fix propagation, provenance,
+branch-local `NEWS`, and Trac follow-up rules, see
+[Backpatching fixes](backpatching.md).
For labels, milestones, draft state, and mirror metadata on pull requests, see
[Pull request metadata](pull-request-metadata.md).
@@ -191,8 +193,9 @@ Before backpatching, confirm the target release line is open in `Version.config`
and `NEWS`. Stable branches normally receive bug fixes, not new features. End of
life branches should not receive new work without explicit release-manager
direction.
-Use [Backpatching fixes](backpatching.md) for the two-pass branch
-scan, one-to-one commit provenance, `NEWS` expectations, and per-ticket Trac
+Use [NEWS entries](news.md) for wording, credit, release cleanup, and checker
+rules. Use [Backpatching fixes](backpatching.md) for the two-pass branch scan,
+one-to-one commit provenance, branch-local `NEWS`, and per-ticket Trac
follow-up wording.
During pre-release code freeze, restrict commits to bug fixes unless the PSC or
diff --git a/doc/development/maintenance/news.md b/doc/development/maintenance/news.md
new file mode 100644
index 000000000..5adb7c86a
--- /dev/null
+++ b/doc/development/maintenance/news.md
@@ -0,0 +1,90 @@
+title: "NEWS Entries"
+date: 2026-08-13
+weight: 25
+geekdocHidden: false
+`NEWS` is a short release changelog, not a commit log.
+## Add
+Add an entry for a user-visible or release-worthy:
+* breaking change, feature, or enhancement;
+* bug, security, or memory-safety fix;
+* stable-branch fix or ticketed behavior change.
+Skip refactors, tests, CI, and packaging unless release users or packagers need
+to know.
+Describe the behavior, not the branch, review, or test run:
+```text
+ - #NNNN, [subsystem] Brief behavior summary
+ (Contributor Name)
+Use `#NNNN` for Trac, `GH-NNN` for GitHub, and `GT-NNN` for Gitea. Do not use
+bare `#NNNN` for GitHub or Gitea. Keep subsystem tags consistent with nearby
+entries.
+Credit authors in the final parentheses. For a reported security fix, use
+`reported by ...; fixed by ...` when the roles differ. If the reporter supplied
+the patch, credit the reporter only. Add missing people to Individual
+Contributors and organizations to Corporate Sponsors.
+## Place
+During development, use the top unreleased section and its existing category.
+If the section says `These are only changes since ...`, add only later changes.
+During release prep, the former top section remains valid if it was unreleased at
+the target base ref. Do not rewrite the first line of a released bullet without
+the release manager's request.
+## Release Prep
+Before tagging:
+1. Set the release date.
+2. Compare `NEWS` with Git history and the Trac milestone.
+3. Check version and dependency text.
+4. Fix categories; merge or remove small internal notes.
+5. Update `doc/release_notes.xml` with curated release notes.
+Dates containing `x` are placeholders. Numeric dates must not be future dates and
+must be in descending order. After release, add the next development section at
+the top.
+## Checks
+Configured tree:
+```sh
+make check-news
+make check-contributor-credits
+Unconfigured tree:
+```sh
+python3 -B utils/docs/tests/test_check_news.py
+sh utils/docs/check_news.sh .
+python3 -B utils/docs/tests/test_check_contributor_credits.py
+python3 -B utils/docs/check_contributor_credits.py --repo .
+For a PR base-ref check:
+```sh
+utils/docs/check_news.sh --base-ref=origin/master .
+The checker allows new bullets only in the current top unreleased section, or in
+the former top section when it was unreleased at the base ref.
+## Backpatch
+For each target branch, check `Version.config` and the top `NEWS` section. Use
+similar wording across branches, changing release-specific facts. Stable
+branches usually need bug-fix wording, not new-feature wording.
Summary of changes:
doc/development/maintenance/_index.md | 11 +++--
doc/development/maintenance/news.md | 90 +++++++++++++++++++++++++++++++++++
2 files changed, 97 insertions(+), 4 deletions(-)
create mode 100644 doc/development/maintenance/news.md
hooks/post-receive
