[SCM] PostGIS branch master updated. 3.7.0beta2-48-g3e1eba5f5
Sat Aug 15 09:58:26 PDT 2026
the project "PostGIS".
       via  3e1eba5f5181f357f7d32309f0ea4132247103d5 (commit)
       via  ef96a35be0f3b5a7978133c07e0bb276d20e3d33 (commit)
      from  40b61a5fc02f0bb2d07be263e180e7f24c6c5a95 (commit)
revisions in full, below.
commit 3e1eba5f5181f357f7d32309f0ea4132247103d5
Merge: 40b61a5fc ef96a35be
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Sat Aug 15 09:58:25 2026 -0700
    Merge pull request 'liblwgeom: validate GSERIALIZED ring counts against buffer, not geometry validity' (!741) from Komzpa/postgis:fix/gserialized-ringcount-buffer-guard-20260815 into master
    Pull request [724](https://gitea.osgeo.org/postgis/postgis/pulls/724) added `gserialized{1,2}_validate_polygon_ring_count()`, rejecting any non-empty polygon ring whose declared point count is 1, 2 or 3, to guard against OSSFuzz 544800490. That guard duplicates, and is stricter than, `gserialized{1,2}_validate_geometry_buffer()`, introduced two weeks earlier in commit c1f681540 ("Harden GSERIALIZED payload readers"). The earlier validator already walks every ring's declared point count with overflow-checked arithmetic and rejects any count whose implied byte size overflows or exceeds the remaining buffer, recursively for collection members, before `lwpoly_from_gserialized{1,2}_buffer` ever reads a ring, and that reader is static with no other caller — so by the time a ring is walked, its buffer bounds are already proven safe.
    The added guard therefore contributed no memory safety and instead rejected geometrically invalid but memory-safe polygons that PostGIS has always accepted at deserialization time: 1-, 2- and 3-point rings built by GeoJSON input (https://trac.osgeo.org/postgis/ticket/4470) and legacy paths pinned by https://trac.osgeo.org/postgis/ticket/408. This change removes the redundant per-ring point-count guard and its call sites in both GSERIALIZED layouts, restoring pre-724 deserialization behavior while leaving `gserialized{1,2}_validate_geometry_buffer()`, and the fuzz-safety invariant it enforces, untouched.
    Un-breaks regress/core/clean test 9, regress/core/geos310 test 31, regress/core/tickets tests 408.3/408.4, regress/core/in_geojson tests 4470.a/4470.c, and the "postgis extension upgrade 3.3.9--3.7.0dev" regression, all red on master since Woodpecker pipeline 7002. PR 724 was not backpatched to stable-3.6 or stable-3.5, so no NEWS entry and no stable-branch action is needed.
    Repurposes the malformed-ring-count CUnit tests in cu_gserialized{1,2}.c to craft a ring count whose implied byte size exceeds the buffer, which is the actual OSSFuzz 544800490 vector, and adds short-ring round-trip coverage for 1- and 3-point rings. Full CUnit suite green (376 tests, 5908 asserts); the four regress tests and the upgrade path validated red at 89cd60efd and green after the fix.
    References https://gitea.osgeo.org/postgis/postgis/pulls/724
    References https://trac.osgeo.org/postgis/ticket/408
    References https://trac.osgeo.org/postgis/ticket/4470
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/741
commit ef96a35be0f3b5a7978133c07e0bb276d20e3d33
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Sat Aug 15 20:17:43 2026 +0400
    Pull request 724 added gserialized{1,2}_validate_polygon_ring_count(),
    2 or 3, to guard against OSSFuzz 544800490. That guard is redundant
    with, and stricter than, gserialized{1,2}_validate_geometry_buffer(),
    payload readers"). That function already walks every ring's declared
    and it runs on the whole geometry tree, recursively for collection
    members, before lwpoly_from_gserialized{1,2}_buffer ever reads a
    ring. lwpoly_from_gserialized{1,2}_buffer is static and has no other
    caller, so by the time it walks a ring, the buffer bounds for that
    ring are already proven safe.
    built by GeoJSON input (Trac #4470), ST_IsValid intermediates, and
    other legacy paths (Trac #408). This narrows the check back to what
    buffer-bounds validation already guarantees by removing the redundant
    gserialized{1,2}_validate_geometry_buffer(), and the fuzz-safety
    regress/core/tickets tests 408.3/408.4 and regress/core/in_geojson
    tests 4470.a/4470.c, and the postgis extension upgrade
    3.3.9--3.7.0dev regression, all broken by 724 on master since
    Woodpecker pipeline 7002. Confirmed not backpatched to stable-3.6 or
    stable-3.5.
    Repurposes cu_gserialized{1,2}.c's malformed-ring-count CUnit test to
    craft a ring count whose implied byte size exceeds the buffer, the
    actual OSSFuzz 544800490 vector, and adds a short-ring round-trip test
    covering 1- and 3-point rings.
diff --git a/liblwgeom/cunit/cu_gserialized1.c b/liblwgeom/cunit/cu_gserialized1.c
index 1153c1a8b..58c7cd373 100644
--- a/liblwgeom/cunit/cu_gserialized1.c
+++ b/liblwgeom/cunit/cu_gserialized1.c
@@ -1307,6 +1307,13 @@ gserialized1_test_payload_p(GSERIALIZED *g)
 	return (uint8_t *)(void *)g + gserialized1_header_size(g);
+ * A ring point count that claims far more points than the serialized
+ * buffer actually holds implies a read past the end of the payload; that
+ * is the memory-safety hazard OSSFuzz 544800490 found, and it must stay
+ * rejected regardless of whether the claimed count is itself a
+ * geometrically plausible ring size.
 static void
 test_gserialized1_malformed_polygon_ring_count(void)
@@ -1316,7 +1323,7 @@ test_gserialized1_malformed_polygon_ring_count(void)
 	uint8_t *payload;
 	uint32_t type;
 	uint32_t nrings;
-	uint32_t npoints = 1;
+	uint32_t npoints = 0x10000000; /* claims ~4GB of ring ordinates */
 	CU_ASSERT_PTR_NOT_NULL_FATAL(lwgeom);
 	g = gserialized1_from_lwgeom(lwgeom, NULL);
@@ -1338,6 +1345,51 @@ test_gserialized1_malformed_polygon_ring_count(void)
 	lwfree(g);
+ * Rings with 1-3 points are geometrically invalid (not simple closed
+ * rings) but memory-safe: their declared point count still fits the
+ * serialized buffer. PostGIS intentionally stores and round-trips such
+ * polygons; ST_IsValid, not deserialization, is where that gets flagged.
+ * See Trac #408 and #4470, and ST_GeomFromGeoJSON's degenerate-ring
+ * handling.
+static void
+test_gserialized1_short_polygon_ring_roundtrip(void)
+	const char *short_ring_wkt[] = {
+	    "POLYGON((0 0))",
+	    "POLYGON((0 0, 1 0, 1 1))",
+	const uint32_t expected_npoints[] = {1, 3};
+	size_t i;
+	for (i = 0; i < sizeof(short_ring_wkt) / sizeof(short_ring_wkt[0]); i++)
+		LWGEOM *lwgeom = lwgeom_from_wkt(short_ring_wkt[i], LW_PARSER_CHECK_NONE);
+		GSERIALIZED *g;
+		LWGEOM *roundtrip;
+		LWPOLY *poly;
+		CU_ASSERT_PTR_NOT_NULL_FATAL(lwgeom);
+		g = gserialized1_from_lwgeom(lwgeom, NULL);
+		CU_ASSERT_PTR_NOT_NULL_FATAL(g);
+		cu_error_msg_reset();
+		roundtrip = lwgeom_from_gserialized1(g);
+		CU_ASSERT_PTR_NOT_NULL_FATAL(roundtrip);
+		CU_ASSERT_EQUAL(strlen(cu_error_msg), 0);
+		CU_ASSERT_EQUAL(roundtrip->type, POLYGONTYPE);
+		poly = (LWPOLY *)roundtrip;
+		CU_ASSERT_EQUAL(poly->nrings, 1);
+		CU_ASSERT_EQUAL(poly->rings[0]->npoints, expected_npoints[i]);
+		lwgeom_free(lwgeom);
+		lwgeom_free(roundtrip);
+		lwfree(g);
 static void
 test_gserialized1_malformed_declared_size(void)
@@ -1393,5 +1445,6 @@ void gserialized1_suite_setup(void)
 	PG_ADD_TEST(suite, test_signum_macro);
 	PG_ADD_TEST(suite, test_gserialized1_peek_first_point);
 	PG_ADD_TEST(suite, test_gserialized1_malformed_polygon_ring_count);
+	PG_ADD_TEST(suite, test_gserialized1_short_polygon_ring_roundtrip);
 	PG_ADD_TEST(suite, test_gserialized1_malformed_declared_size);
diff --git a/liblwgeom/cunit/cu_gserialized2.c b/liblwgeom/cunit/cu_gserialized2.c
index 6ee2f877c..49bd3f4d8 100644
--- a/liblwgeom/cunit/cu_gserialized2.c
+++ b/liblwgeom/cunit/cu_gserialized2.c
@@ -589,6 +589,13 @@ test_gserialized2_malformed_nurbs_degree(void)
 	lwfree(g);
 static void
 test_gserialized2_malformed_polygon_ring_count(void)
@@ -598,7 +605,7 @@ test_gserialized2_malformed_polygon_ring_count(void)
 	uint8_t *payload;
 	uint32_t type;
 	uint32_t nrings;
 	g = gserialized2_from_lwgeom(lwgeom, NULL);
@@ -620,6 +627,51 @@ test_gserialized2_malformed_polygon_ring_count(void)
 	lwfree(g);
+ * handling.
+static void
+test_gserialized2_short_polygon_ring_roundtrip(void)
+	    "POLYGON((0 0))",
+	size_t i;
+		GSERIALIZED *g;
+		LWPOLY *poly;
+		g = gserialized2_from_lwgeom(lwgeom, NULL);
+		roundtrip = lwgeom_from_gserialized2(g);
+		lwfree(g);
 static void
 test_gserialized2_malformed_nurbs_short_vectors(void)
@@ -763,6 +815,7 @@ void gserialized2_suite_setup(void)
 	PG_ADD_TEST(suite, test_gserialized2_malformed_collection_count);
 	PG_ADD_TEST(suite, test_gserialized2_malformed_nurbs_degree);
 	PG_ADD_TEST(suite, test_gserialized2_malformed_polygon_ring_count);
+	PG_ADD_TEST(suite, test_gserialized2_short_polygon_ring_roundtrip);
 	PG_ADD_TEST(suite, test_gserialized2_malformed_nurbs_short_vectors);
 	PG_ADD_TEST(suite, test_gserialized2_malformed_declared_size);
 	PG_ADD_TEST(suite, test_gserialized2_malformed_short_allocation);
diff --git a/liblwgeom/gserialized1.c b/liblwgeom/gserialized1.c
index 2c68f2c71..406f36c3f 100644
--- a/liblwgeom/gserialized1.c
+++ b/liblwgeom/gserialized1.c
@@ -273,17 +273,6 @@ gserialized1_pointarray_payload_size(uint32_t npoints, lwflags_t lwflags, size_t
 	return LW_SUCCESS;
-static int
-gserialized1_validate_polygon_ring_count(uint32_t npoints)
-	if (npoints > 0 && npoints < 4)
-		lwerror("%s: invalid non-empty polygon ring point count %u", __func__, npoints);
-		return LW_FAILURE;
-	return LW_SUCCESS;
 static int
 gserialized1_validate_geometry_buffer(uint8_t *data_ptr, uint8_t *data_end, lwflags_t lwflags, size_t *size)
@@ -1523,15 +1512,14 @@ static LWPOLY* lwpoly_from_gserialized1_buffer(uint8_t *data_ptr, lwflags_t lwfl
 		uint32_t npoints = 0;
-		/* Read in the number of points. */
+		/* Read in the number of points. gserialized1_validate_geometry_buffer() has
+		 * already bounds-checked every ring's declared point count against the
+		 * remaining buffer and rejected overflowing byte sizes; a ring with fewer
+		 * than four points is geometrically invalid but not a memory-safety
+		 * problem, and PostGIS intentionally stores and reports such rings (see
+		 * Trac #408, #4470). */
 		npoints = gserialized1_get_uint32_t(data_ptr);
 		data_ptr += 4;
-		if (gserialized1_validate_polygon_ring_count(npoints) == LW_FAILURE)
-			poly->nrings = i;
-			lwpoly_free(poly);
-			return NULL;
 		/* Make a point array for the ring, and move the ordinate pointer past the ring ordinates. */
 		poly->rings[i] = ptarray_construct_reference_data(FLAGS_GET_Z(lwflags), FLAGS_GET_M(lwflags), npoints, ordinate_ptr);
diff --git a/liblwgeom/gserialized2.c b/liblwgeom/gserialized2.c
index f0a6bdd7c..f3422ae17 100644
--- a/liblwgeom/gserialized2.c
+++ b/liblwgeom/gserialized2.c
@@ -398,17 +398,6 @@ gserialized2_pointarray_payload_size(uint32_t npoints, lwflags_t lwflags, size_t
 	return LW_SUCCESS;
-static int
-gserialized2_validate_polygon_ring_count(uint32_t npoints)
 static int
 gserialized2_validate_geometry_buffer(uint8_t *data_ptr, uint8_t *data_end, lwflags_t lwflags, size_t *size)
@@ -2067,15 +2056,14 @@ lwpoly_from_gserialized2_buffer(uint8_t *data_ptr, lwflags_t lwflags, size_t *si
+		/* Read in the number of points. gserialized2_validate_geometry_buffer() has
 		npoints = gserialized2_get_uint32_t(data_ptr);
 		data_ptr += 4;
-		if (gserialized2_validate_polygon_ring_count(npoints) == LW_FAILURE)
-			poly->nrings = i;
-			return NULL;
Summary of changes:
 liblwgeom/cunit/cu_gserialized1.c | 55 ++++++++++++++++++++++++++++++++++++++-
 liblwgeom/cunit/cu_gserialized2.c | 55 ++++++++++++++++++++++++++++++++++++++-
 liblwgeom/gserialized1.c          | 24 +++++------------
 liblwgeom/gserialized2.c          | 24 +++++------------
 4 files changed, 120 insertions(+), 38 deletions(-)
hooks/post-receive
