[SCM] PostGIS branch master updated. 3.7.0beta2-50-gc67a47457
git at osgeo.org
git at osgeo.org
Sat Aug 15 10:09:19 PDT 2026
the project "PostGIS".
via c67a47457fcdd72bd136f7f16999114d6a9229b1 (commit)
via ffb4349c52b2e434d98ff680066587eced2d6648 (commit)
from 3e1eba5f5181f357f7d32309f0ea4132247103d5 (commit)
revisions in full, below.
commit c67a47457fcdd72bd136f7f16999114d6a9229b1
Merge: 3e1eba5f5 ffb4349c5
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Sat Aug 15 10:09:18 2026 -0700
Merge pull request 'Link compatibility browser release notes' (!730) from Komzpa/postgis:docs/compatibility-link-targets-20260812 into master
## Summary
Adds link metadata to the generated compatibility-browser payload so existing labels can point at the most specific public changelog or source page available.
The payload now distinguishes:
- project/source pages for dependency group headers
- dependency release-note pages for version labels
- PostGIS branch `NEWS` pages for release-series labels
- PostGIS tag `NEWS` pages for series and patch-version labels
This branch previously also carried an `allow_doctype` fix letting the DocBook source linter parse the expanded `postgis-out.xml`; that was solved more generally on master by https://gitea.osgeo.org/postgis/postgis/pulls/735, so the commit was dropped during the 2026-08-15 rebase.
Companion website branch: `Komzpa/postgis.net:compat/link-targets-20260812`
## Validation
- `python3 -m py_compile utils/docs/support_matrix/payload.py utils/docs/support_matrix/cli.py`
- `python3 utils/docs/support_matrix.py check`
- `python3 utils/docs/support_matrix.py build <output-json>`
- `python3 -m unittest discover -s utils/docs/tests` (276 tests)
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/730
commit ffb4349c52b2e434d98ff680066587eced2d6648
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Wed Aug 12 14:34:31 2026 +0400
docs: link compatibility browser release notes
diff --git a/utils/docs/support_matrix/payload.py b/utils/docs/support_matrix/payload.py
index ff3555648..6c4baae2c 100644
--- a/utils/docs/support_matrix/payload.py
+++ b/utils/docs/support_matrix/payload.py
@@ -200,6 +200,7 @@ BROWSER_DIMENSIONS = (
("gdal", "GDAL"),
("sfcgal", "SFCGAL"),
+BROWSER_DIMENSION_LABELS = dict(BROWSER_DIMENSIONS)
BROWSER_STATUSES = {
"supported": {"symbol": "W", "label": "works, supported"},
"feature-limited": {"symbol": "L", "label": "works with limited features"},
@@ -243,6 +244,13 @@ PROJECT_URLS = {
"dblatex": "https://dblatex.sourceforge.net/",
"imagemagick": "https://imagemagick.org/",
+RELEASE_TAGS = {
+ "postgresql": ("https://www.postgresql.org/docs/release/{version}/", ""),
+ "geos": ("https://github.com/libgeos/geos/releases/tag/{version}", ""),
+ "proj": ("https://github.com/OSGeo/PROJ/releases/tag/{version}", ""),
+ "gdal": ("https://github.com/OSGeo/gdal/releases/tag/v{version}", ""),
+ "sfcgal": ("https://gitlab.com/sfcgal/SFCGAL/-/releases/v{version}", ""),
DEPENDENCY_GROUPS = (
"build-runtime",
@@ -340,6 +348,56 @@ def browser_gate_key(key: str) -> str:
}.get(key, browser_project_key(key))
+def browser_link(value: str, url: str, title: str = "") -> dict[str, str]:
+ return {"value": value, "url": url, "title": title or value}
+def browser_postgis_news_link(version: str) -> dict[str, str]:
+ return browser_link(
+ "NEWS",
+ f"https://gitea.osgeo.org/postgis/postgis/src/tag/{quote(version, safe='')}/NEWS",
+ f"PostGIS {version} release notes",
+def browser_postgis_branch_news_link(series: dict[str, Any]) -> dict[str, str]:
+ minor = str(series.get("minor") or "")
+ if series.get("lifecycle") == "development":
+ "Branch NEWS",
+ "https://gitea.osgeo.org/postgis/postgis/src/branch/master/NEWS",
+ "PostGIS development branch NEWS",
+ if browser_is_eol(series) and series.get("latest"):
+ "Latest NEWS",
+ f"https://gitea.osgeo.org/postgis/postgis/src/tag/{quote(str(series['latest']), safe='')}/NEWS",
+ f"PostGIS {series['latest']} release notes",
+ branch = f"stable-{minor}"
+ "Branch NEWS",
+ f"https://gitea.osgeo.org/postgis/postgis/src/branch/{quote(branch, safe='')}/NEWS",
+ f"PostGIS {branch} NEWS",
+def browser_dependency_release_link(key: str, item: dict[str, Any]) -> dict[str, str] | None:
+ template = RELEASE_TAGS.get(key)
+ version = str(item.get("current_minor") or item.get("version") or "")
+ if not template or not version:
+ return None
+ url_template, prefix = template
+ if key == "postgresql" and not re.fullmatch(r"\d+(?:\.\d+)+", version):
+ return None
+ linked_version = f"{prefix}{version}"
+ "Release notes",
+ url_template.format(version=quote(linked_version, safe="")),
+ f"{BROWSER_DIMENSION_LABELS.get(key, key)} {version} release notes",
def browser_dependency_group(item: dict[str, Any]) -> str:
if item.get("id") == "postgis" or item.get("kind") in {
"core",
@@ -600,6 +658,7 @@ def browser_column(
if part
source = browser_source_detail(data, item.get("source") or "")
+ release = browser_dependency_release_link(key, item)
return {
"key": item["version"],
"label": item["version"],
@@ -611,6 +670,7 @@ def browser_column(
or str(item.get("current_minor") or "n/a"),
"final_label": final_label,
"detail": detail,
+ "release": release,
"source": source if item.get("source") else None,
"meta": item,
@@ -681,11 +741,22 @@ def browser_lifecycle(series: dict[str, Any], current_year: int) -> list[dict[st
def browser_matrix(data: dict[str, Any], current_year: int) -> dict[str, Any]:
dimensions: list[dict[str, Any]] = []
for key, label in BROWSER_DIMENSIONS:
+ source_item = next(
+ (item for item in data.get("dependency_versions", {}).get(key, []) if item.get("source")),
columns = [
browser_column(data, key, label, item, current_year)
- dimensions.append({"key": key, "label": label, "columns": columns})
+ dimensions.append(
+ "key": key,
+ "label": label,
+ "source": browser_source_detail(data, source_item.get("source") or "") if source_item else None,
+ "columns": columns,
supported_series = [series for series in data.get("postgis_series", []) if not browser_is_eol(series)]
for dimension in dimensions:
dimension["visible"] = {
@@ -706,21 +777,24 @@ def browser_matrix(data: dict[str, Any], current_year: int) -> dict[str, Any]:
"eol": browser_is_eol(series),
"visible": {"supported": not browser_is_eol(series), "history": True},
"lifecycle": browser_lifecycle(series, current_year),
+ "source": browser_postgis_branch_news_link(series),
"rows": {"series": [], "patches": []},
def make_row(patch: dict[str, Any] | None) -> dict[str, Any]:
effective = browser_patch_series(series, patch)
+ version = str(patch.get("version") if patch else series.get("latest") or "")
row = {
"key": patch.get("version") if patch else series["minor"],
"kind": "patch" if patch else "series",
- "primary": patch.get("version") if patch else str(series.get("latest") or ""),
+ "primary": version,
"secondary": (
browser_release_age(patch.get("release_date"), current_year, month=True) or "patch" if patch else ""
"release_date": str(patch.get("release_date") or "") if patch else "",
- "source": (browser_source_detail(data, str(patch.get("source") or "")) if patch else None),
+ "release": browser_postgis_news_link(version) if version else None,
+ "source": browser_source_detail(data, str(patch.get("source") or "")) if patch else None,
"cells": {},
@@ -1106,9 +1180,12 @@ def browser_recommended(
(patch for patch in data.get("patch_releases", []) if patch.get("version") == value),
+ release = browser_postgis_news_link(value) if value else {}
return {
"value": value,
"detail": f"released {patch['release_date']}" if patch.get("release_date") else "",
+ "url": release.get("url", ""),
+ "title": release.get("title", ""),
if key == "postgresql":
value = browser_newest_version(
@@ -1124,9 +1201,12 @@ def browser_recommended(
if value:
+ release = browser_dependency_release_link("postgresql", value) or {}
return {
"value": str(value.get("current_minor") or value.get("version") or ""),
"detail": (f"major since {value['first_release_date']}" if value.get("first_release_date") else ""),
if key in {dimension[0] for dimension in BROWSER_DIMENSIONS[1:]}:
@@ -1135,9 +1215,12 @@ def browser_recommended(
lambda candidate: not browser_is_eol(candidate) and not browser_is_development(candidate),
if value:
+ release = browser_dependency_release_link(key, value) or {}
return {
"detail": (f"line since {value['first_release_date']}" if value.get("first_release_date") else ""),
pin = item.get("pin") or {}
if pin.get("value"):
@@ -1435,6 +1518,18 @@ def validate_payload_model(model: dict[str, Any]) -> list[str]:
errors.append(f"browser.{'.'.join(path)} exposes internal source id {match.group(0)!r}")
validate_display_text(model)
+ def validate_link(link: Any, path: str, *, required: bool = False) -> None:
+ if not link:
+ if required:
+ errors.append(f"{path}: link is required")
+ return
+ if not isinstance(link, dict):
+ errors.append(f"{path}: link must be an object")
+ return
+ if not link.get("value") or not str(link.get("url") or "").startswith(("http://", "https://", "/")):
+ errors.append(f"{path}: human label and URL are required")
for index, source in enumerate(sources):
if not source.get("value") or not str(source.get("url") or "").startswith(("http://", "https://")):
errors.append(f"browser.matrix.sources.{index}: human label and URL are required")
@@ -1495,6 +1590,10 @@ def validate_payload_model(model: dict[str, Any]) -> list[str]:
if any(not isinstance(index, int) or index < 0 or index >= len(columns) for index in visible):
errors.append(f"browser.matrix.{dimension.get('key')}.{coverage}: invalid column index")
for column in columns:
+ validate_link(
+ column.get("release"),
+ f"browser.matrix.{dimension.get('key')}.{column.get('key')}.release",
source = column.get("source") or {}
errors.append(
@@ -1503,6 +1602,7 @@ def validate_payload_model(model: dict[str, Any]) -> list[str]:
column_counts = {dimension.get("key"): len(dimension.get("columns", [])) for dimension in dimensions}
for group in series:
+ validate_link(group.get("source"), f"browser.matrix.{group.get('key')}.source", required=True)
base_rows = group.get("rows", {}).get("series", [])
if len(base_rows) != 1:
errors.append(f"browser.matrix.{group.get('key')}: expected one series row")
@@ -1574,6 +1674,8 @@ def validate_payload_model(model: dict[str, Any]) -> list[str]:
errors.append(
f"browser.matrix.{group.get('key')}.{row.get('key')}.source: human label and URL are required"
+ for row in [*base_rows, *group.get("rows", {}).get("patches", [])]:
+ validate_link(row.get("release"), f"browser.matrix.{group.get('key')}.{row.get('key')}.release")
inventory = model.get("inventory", {})
items = [item for group in inventory.get("groups", []) for item in group.get("items", [])]
if not items:
Summary of changes:
utils/docs/support_matrix/payload.py | 108 ++++++++++++++++++++++++++++++++++-
1 file changed, 105 insertions(+), 3 deletions(-)
hooks/post-receive
