[SCM] PostGIS branch stable-3.3 updated. 3.3.10-132-g47098a123
git at osgeo.org
git at osgeo.org
Sat Aug 15 11:48:31 PDT 2026
the project "PostGIS".
The branch, stable-3.3 has been updated
via 47098a123eb435ea5f249df0808e6731756677d2 (commit)
via 942e2fe572ee18cbfb393661a12439acc67c26ec (commit)
from 3ce1a36539ec8db913f226f56288593433c11516 (commit)
revisions in full, below.
commit 47098a123eb435ea5f249df0808e6731756677d2
Merge: 3ce1a3653 942e2fe57
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Sat Aug 15 11:48:30 2026 -0700
Merge pull request '[3.3] Fix postgis_tiger_geocoder CREATE EXTENSION CASCADE failing on PostgreSQL < 16' (!745) from Komzpa/postgis:fix/tiger-extschema-3.3-20260815 into stable-3.3
This branch's `postgis_tiger_geocoder` install previously wrapped every `extras/tiger_geocoder` SQL file in a `DO $shim$` block to work around `@extschema:postgis@`/`@extschema:fuzzystrmatch@` tokens that PostgreSQL only substitutes starting with version 16. That approach has been replaced with a much smaller build-time fix: `extensions/postgis_tiger_geocoder/Makefile.in` now strips `@extschema:<name>@` qualification from the generated install script only when building against PostgreSQL below 16 (via a new `EXTSCHEMA_SUPPORTED` flag gated on `POSTGIS_PGSQL_VERSION`), leaving the qualification — and its protection against search-path hijacking — fully intact on PostgreSQL 16 and newer. No SQL source is modified.
References https://gitea.osgeo.org/postgis/postgis/pulls/712
Validated: the generated `postgis_tiger_geocoder--<version>.sql` carries zero `@extschema:` tokens on a PostgreSQL < 16 build and `CREATE EXTENSION postgis_tiger_geocoder CASCADE` succeeds; on PostgreSQL 16+ the tokens are retained and substituted by core, and CASCADE also succeeds. `test-normalize_address` and `test-upgrade` pass. No file under `extras/tiger_geocoder` is modified.
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/745
commit 942e2fe572ee18cbfb393661a12439acc67c26ec
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Sat Aug 15 22:44:09 2026 +0400
tiger_geocoder: strip @extschema qualification for PostgreSQL < 16 at build time
The tiger_geocoder schema-qualification hardening backported into this
branch's extras/tiger_geocoder tree writes calls such as
@extschema:fuzzystrmatch at .soundex(...) and @extschema:postgis at .geometry.
PostgreSQL only substitutes the colon form of the @extschema@ macro
starting with PostgreSQL 16; on every older server version this branch
supports, the token was left literal in the generated install script and
CREATE EXTENSION postgis_tiger_geocoder CASCADE failed with a syntax error
at the first such token.
The SQL-side hardening was backported without stable-3.6's Makefile-side
stripping mechanism that makes those tokens safe on PostgreSQL versions
below 16. This change ports that mechanism: an EXTSCHEMA_SUPPORTED flag
gated on POSTGIS_PGSQL_VERSION < 160 controls whether the generated
install script and minor upgrade script keep the @extschema:<name>@
qualification (PostgreSQL 16 and newer, where core substitutes the
tokens against the real installed schemas) or have it stripped at
generation time (PostgreSQL below 16, falling back to the tiger schema's
own search_path setup). No SQL source under extras/tiger_geocoder is
touched; the qualification and its search-path-hijacking protection on
PostgreSQL 16+ are unchanged. stable-3.6 has shipped this exact
mechanism since commit bc0854651 (August 2024).
diff --git a/NEWS b/NEWS
index 39153f94c..37c95baaa 100644
--- a/NEWS
+++ b/NEWS
@@ -44,6 +44,11 @@ PostGIS 3.3.11
- [tiger_geocoder] Qualify PostGIS and fuzzystrmatch calls, generated table
DDL, PAGC tables, loader scripts, topology loader, and dynamic SQL
against unsafe search paths (Regina Obe, Paul Ramsey)
+ - GT-712, [tiger_geocoder] Strip @extschema:<name>@ schema qualification
+ from the generated install script at build time on PostgreSQL versions
+ below 16, restoring CREATE EXTENSION postgis_tiger_geocoder CASCADE while
+ keeping the qualification on PostgreSQL 16 and newer
+ (Darafei Praliaskouski)
- #6044, Skip doc XML validation without DocBook XSL stylesheets (Regina Obe)
- GH-894, [raster] Fix Float16 import, mixed nodata warping,
band replacement cleanup, GDAL credential redaction, and Python
diff --git a/extensions/postgis_tiger_geocoder/Makefile.in b/extensions/postgis_tiger_geocoder/Makefile.in
index 1844c10d8..435a465b2 100644
--- a/extensions/postgis_tiger_geocoder/Makefile.in
+++ b/extensions/postgis_tiger_geocoder/Makefile.in
@@ -1,5 +1,6 @@
include @srcdir@/../upgradeable_versions.mk
+POSTGIS_PGSQL_VERSION=@POSTGIS_PGSQL_VERSION@
EXTENSION = postgis_tiger_geocoder
EXTVERSION = @POSTGIS_LIB_VERSION@
MINORVERSION = 2011. at POSTGIS_MAJOR_VERSION@. at POSTGIS_MINOR_VERSION@
@@ -30,6 +31,12 @@ DATA_built = \
REGRESS = test-normalize_address test-upgrade
REGRESS_OPTS = --load-extension=fuzzystrmatch --load-extension=postgis --load-extension=$(EXTENSION)
+EXTSCHEMA_SUPPORTED = yes
+## PostgreSQL < 16 doesn't understand new @extschema:extname@ syntax, so strip it
+ifeq ($(shell expr "$(POSTGIS_PGSQL_VERSION)" "<" 160),1)
+EXTSCHEMA_SUPPORTED = no
+endif
SQL_BITS = $(wildcard sql_bits/*.sql)
EXTRA_CLEAN = sql expected ${SQL_BITS}
@@ -49,8 +56,15 @@ expected:
sql:
mkdir -p $@
+ifeq ($(EXTSCHEMA_SUPPORTED),yes)
sql/$(EXTENSION)--$(EXTVERSION).sql: sql/$(EXTENSION).sql | sql
cp $< $@
+else
+# PG < 16 doesn't support new @extschema:<extension_name>@
+# so we need to strip those out
+sql/$(EXTENSION)--$(EXTVERSION).sql: sql/$(EXTENSION).sql | sql
+ $(PERL) -lpe "s/\@extschema:[^@]+\@\./ /g" < $< > $@
+endif
expected/test-normalize_address.out: sql_bits/test_tuples_only_unaligned.sql.in ../../extras/tiger_geocoder/regress/normalize_address_regress | expected
cat $^ > $@
@@ -198,9 +212,17 @@ sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql: sql_bits/tiger_geocoder--unpack
#aggregates are special
#they can be dropped but we need to remove
#them from the extension first
sql/tiger_geocoder_upgrade_minor.sql: sql/tiger_geocoder_minor.sql.in | sql
sed -e 's/BEGIN;//g' -e 's/COMMIT;//g' \
+else
+sql/tiger_geocoder_upgrade_minor.sql: sql/tiger_geocoder_minor.sql.in | sql
+ sed -e 's/BEGIN;//g' -e 's/COMMIT;//g' -e 's/@extschema:[^@]*@\.//g' \
+endif
#only extension files
EXTRA_CLEAN += $(wildcard expected/*--*.out)
Summary of changes:
NEWS | 5 +++++
extensions/postgis_tiger_geocoder/Makefile.in | 22 ++++++++++++++++++++++
2 files changed, 27 insertions(+)
hooks/post-receive
