[SCM] PostGIS branch stable-3.4 updated. 3.4.6-139-g94f95f9c5
git at osgeo.org
git at osgeo.org
Sat Aug 15 11:48:35 PDT 2026
the project "PostGIS".
The branch, stable-3.4 has been updated
via 94f95f9c581166f82c3d0551d89ed8f05dec3f45 (commit)
via 8b360d0fcbea28e5aac47d69383fc0e9d4809d42 (commit)
from d81d4736b575b2a19f8ed0251f366e326bd35724 (commit)
revisions in full, below.
commit 94f95f9c581166f82c3d0551d89ed8f05dec3f45
Merge: d81d4736b 8b360d0fc
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Sat Aug 15 11:48:34 2026 -0700
Merge pull request '[3.4] Fix postgis_tiger_geocoder CREATE EXTENSION CASCADE failing on PostgreSQL < 16' (!744) from Komzpa/postgis:fix/tiger-extschema-3.4-20260815 into stable-3.4
Replaces the earlier `DO $shim$` text-rewrite approach with a build-time fix: stable-3.4's `extensions/postgis_tiger_geocoder/Makefile.in` now strips `@extschema:postgis@`/`@extschema:fuzzystrmatch@` tokens from the generated install SQL only when building against PostgreSQL < 16 (`POSTGIS_PGSQL_VERSION < 160`), the same `EXTSCHEMA_SUPPORTED` mechanism stable-3.6 has shipped since commit bc0854651 (Aug 2024). PostgreSQL 16+ builds keep the qualified, hardened calls untouched. No SQL source under `extras/tiger_geocoder` changes.
References https://gitea.osgeo.org/postgis/postgis/pulls/711
Validated: the generated `postgis_tiger_geocoder--<version>.sql` carries zero `@extschema:` tokens on a PostgreSQL < 16 build and `CREATE EXTENSION postgis_tiger_geocoder CASCADE` succeeds; on PostgreSQL 16+ the tokens are retained and substituted by core, and CASCADE also succeeds. `test-normalize_address` and `test-upgrade` pass. No file under `extras/tiger_geocoder` is modified.
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/744
commit 8b360d0fcbea28e5aac47d69383fc0e9d4809d42
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Sat Aug 15 22:43:44 2026 +0400
tiger_geocoder: strip @extschema qualification for PostgreSQL < 16 at build time
The tiger_geocoder schema-qualification hardening backported into this
branch's extras/tiger_geocoder tree writes @extschema:postgis@ and
@extschema:fuzzystrmatch@ tokens, PostgreSQL's substitution macro for
referencing a required extension's installed schema. That macro is
resolved by PostgreSQL core starting with version 16; the backport
carried the SQL-side qualification onto this branch without also
carrying stable-3.6's Makefile-side mechanism that makes the same
qualification safe on older servers, so on every PostgreSQL version
this branch supports below 16 the token is left completely
unsubstituted and CREATE EXTENSION postgis_tiger_geocoder CASCADE
fails with a syntax error at the first such token.
This ports stable-3.6's EXTSCHEMA_SUPPORTED mechanism, in place there
since commit bc0854651 (Aug 2024): the generated install SQL and the
minor-upgrade SQL are stripped of @extschema:<name>@. prefixes by a
Makefile perl substitution gated on POSTGIS_PGSQL_VERSION < 160, so
PostgreSQL 16 and newer keep the qualified, hardened calls exactly as
written, and older servers install the same bare, search-path-resolved
calls tiger_geocoder used before the hardening. No SQL source under
extras/tiger_geocoder changes; the qualification itself is untouched
where PostgreSQL substitutes it.
diff --git a/NEWS b/NEWS
index e2eacf890..9a8191ad3 100644
--- a/NEWS
+++ b/NEWS
@@ -51,6 +51,10 @@ PostGIS 3.4.7
- [tiger_geocoder] Qualify PostGIS and fuzzystrmatch calls, generated table
DDL, PAGC tables, loader scripts, topology loader, and dynamic SQL
against unsafe search paths (Regina Obe, Paul Ramsey)
+ - GT-711, [tiger_geocoder] Strip the PostgreSQL 16-only @extschema:<name>@
+ qualification from the generated install script at build time on older
+ servers, fixing CREATE EXTENSION postgis_tiger_geocoder CASCADE failing
+ with a syntax error on PostgreSQL < 16 (Darafei Praliaskouski)
- #6046, Prefer GraphicsMagick for documentation image generation
- GH-890, Avoid GIDX BRIN summary merges across mismatched
diff --git a/extensions/postgis_tiger_geocoder/Makefile.in b/extensions/postgis_tiger_geocoder/Makefile.in
index da6cb40e3..d5b537fb0 100644
--- a/extensions/postgis_tiger_geocoder/Makefile.in
+++ b/extensions/postgis_tiger_geocoder/Makefile.in
@@ -1,5 +1,6 @@
include @srcdir@/../upgradeable_versions.mk
+POSTGIS_PGSQL_VERSION=@POSTGIS_PGSQL_VERSION@
EXTENSION = postgis_tiger_geocoder
EXTVERSION = @POSTGIS_LIB_VERSION@
MINORVERSION = 2011. at POSTGIS_MAJOR_VERSION@. at POSTGIS_MINOR_VERSION@
@@ -30,6 +31,12 @@ DATA_built = \
REGRESS = test-normalize_address test-upgrade
REGRESS_OPTS = --load-extension=fuzzystrmatch --load-extension=postgis --load-extension=$(EXTENSION)
+EXTSCHEMA_SUPPORTED = yes
+## PostgreSQL < 16 doesn't understand new @extschema:extname@ syntax, so strip it
+ifeq ($(shell expr "$(POSTGIS_PGSQL_VERSION)" "<" 160),1)
+EXTSCHEMA_SUPPORTED = no
+endif
SQL_BITS = $(wildcard sql_bits/*.sql)
EXTRA_CLEAN = sql expected ${SQL_BITS}
@@ -50,8 +57,15 @@ expected:
sql:
mkdir -p $@
+ifeq ($(EXTSCHEMA_SUPPORTED),yes)
sql/$(EXTENSION)--$(EXTVERSION).sql: sql/$(EXTENSION).sql | sql
cp $< $@
+else
+# PG < 16 doesn't support new @extschema:<extension_name>@
+# so we need to strip those out
+sql/$(EXTENSION)--$(EXTVERSION).sql: sql/$(EXTENSION).sql | sql
+ $(PERL) -lpe "s/\@extschema:[^@]+\@\./ /g" < $< > $@
+endif
expected/test-normalize_address.out: sql_bits/test_tuples_only_unaligned.sql.in ../../extras/tiger_geocoder/regress/normalize_address_regress | expected
cat $^ > $@
@@ -199,9 +213,17 @@ sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql: sql_bits/tiger_geocoder--unpack
#aggregates are special
#they can be dropped but we need to remove
#them from the extension first
sql/tiger_geocoder_upgrade_minor.sql: sql/tiger_geocoder_minor.sql.in | sql
sed -e 's/BEGIN;//g' -e 's/COMMIT;//g' \
+else
+sql/tiger_geocoder_upgrade_minor.sql: sql/tiger_geocoder_minor.sql.in | sql
+ sed -e 's/BEGIN;//g' -e 's/COMMIT;//g' \
+ $< > $@.tmp
+ $(PERL) -lpe "s/\@extschema:[^@]+\@\.//g" < $@.tmp > $@
+ rm -f $@.tmp
+endif
#only extension files
EXTRA_CLEAN += $(wildcard expected/*--*.out)
Summary of changes:
NEWS | 4 ++++
extensions/postgis_tiger_geocoder/Makefile.in | 22 ++++++++++++++++++++++
2 files changed, 26 insertions(+)
hooks/post-receive
