[SCM] PostGIS branch master updated. 3.7.0beta2-84-g0650c2476
git at osgeo.org
git at osgeo.org
Thu Aug 20 18:39:21 PDT 2026
the project "PostGIS".
via 0650c247648160052e9cacd3c3b96b7f5319d382 (commit)
from b3474d771e3e01b9f64f220eea16fd301d7ca284 (commit)
revisions in full, below.
commit 0650c247648160052e9cacd3c3b96b7f5319d382
Author: Teramoto Ikuhiro <yellow at affrc.go.jp>
Date: Fri Aug 21 01:33:47 2026 +0000
Translated PostGIS Manual using Weblate (Japanese)
Currently translated at 97.8% (5910 of 6037 strings)
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/ja/
diff --git a/doc/po/ja/postgis-manual.po b/doc/po/ja/postgis-manual.po
index e25ac9236..fe140d65a 100644
--- a/doc/po/ja/postgis-manual.po
+++ b/doc/po/ja/postgis-manual.po
@@ -10,7 +10,7 @@ msgstr ""
"Project-Id-Version: postgis 3.5\n"
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2026-08-04 15:37+0000\n"
-"PO-Revision-Date: 2026-08-20 08:39+0000\n"
+"PO-Revision-Date: 2026-08-21 01:39+0000\n"
"Last-Translator: Teramoto Ikuhiro <teramoto.ikuhiro576 at naro.go.jp>\n"
"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/postgis-"
"manual/ja/>\n"
@@ -45065,6 +45065,8 @@ msgid ""
"link>, [raster] Add ST_Value nearest-neighbor boundary options (Darafei "
"Praliaskouski)"
msgstr ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/2116\">#2116</link>"
+", [raster] ST_Value 最近傍補間の境界オプション (Darafei Praliaskouski さん)"
#. Tag: para
#, no-c-format
@@ -45074,6 +45076,10 @@ msgid ""
"4315\">#4315</link>, [raster] Support two-argument ST_MapAlgebra callbacks "
"and pass callback call data as actual arguments (Darafei Praliaskouski)"
msgstr ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/2804\">#2804</link>"
+", <link xlink:href=\"https://trac.osgeo.org/postgis/ticket/4315\">#4315</"
+"link>, [raster] ST_MapAlgebra の 2引数コールバック関数対応とコールバックの"
+"データを実引数で渡す (Darafei Praliaskouski さん)"
#. Tag: para
#, no-c-format
@@ -45081,6 +45087,8 @@ msgid ""
"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/2898\">#2898</"
"link>, Document SQL function cost tiers for contributors"
msgstr ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/2898\">#2898</link>"
+", 開発者向けに SQL 関数のコストレベルの文書化"
#. Tag: para
#, no-c-format
@@ -45089,6 +45097,9 @@ msgid ""
"link>, [topology] Stop using recursive snapping, for improved robustness "
"(Sandro Santilli)"
msgstr ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/6062\">#6062</link>"
+", [topology] 堅牢性向上のためスナップの再帰実行をしないように変更 (Sandro "
+"Santilli さん)"
#. Tag: para
#, no-c-format
@@ -45097,6 +45108,9 @@ msgid ""
"link>, Improved winding order computation robustness for rings having "
"collapsed elements (Sandro Santilli)"
msgstr ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/6065\">#6065</link>"
+", 崩壊した要素を持つリングに対する巻き方向計算の堅牢性向上 (Sandro Santilli "
+"さん)"
#. Tag: para
#, no-c-format
@@ -45107,6 +45121,11 @@ msgid ""
"reprojection support and clarify index creation timing for append loads "
"(Darafei Praliaskouski)"
msgstr ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/3743\">#3743</link>"
+", <link xlink:href=\"https://trac.osgeo.org/postgis/ticket/4385\">#4385</"
+"link>, [raster loader] raster2pgsql -s FROM_SRID:SRID による投影変換機能の記"
+"載と追加ロード時のインデックス生成タイミングの明示 (Darafei Praliaskouski さ"
+"ん)"
#. Tag: para
#, no-c-format
@@ -45115,6 +45134,9 @@ msgid ""
"link>, [raster] Reuse matching source raster overviews in raster2pgsql -l "
msgstr ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/2137\">#2137</link>"
+", [raster] raster2pgsql -l で対応する元ラスターの既存オーバービューを再利用す"
+"る (Darafei Praliaskouski さん)"
#. Tag: para
#, no-c-format
Summary of changes:
doc/po/ja/postgis-manual.po | 24 +++++++++++++++++++++++-
1 file changed, 23 insertions(+), 1 deletion(-)
hooks/post-receive
