[SCM] PostGIS branch master updated. 3.7.0beta2-89-gaed2e7e1f
Fri Aug 21 02:39:16 PDT 2026
the project "PostGIS".
       via  aed2e7e1fbc432a6600b67a2282491853dc7c1c0 (commit)
      from  94533b3fb459c31b62937068c6e4b3ca4bc3ec3b (commit)
revisions in full, below.
commit aed2e7e1fbc432a6600b67a2282491853dc7c1c0
Author: Teramoto Ikuhiro <yellow at affrc.go.jp>
Date:   Fri Aug 21 08:08:42 2026 +0000
    Translated PostGIS Manual using Weblate (Japanese)
    Currently translated at 98.0% (5920 of 6037 strings)
    Translation: postgis/PostGIS Manual
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/ja/
diff --git a/doc/po/ja/postgis-manual.po b/doc/po/ja/postgis-manual.po
index 077d1e6ac..759238710 100644
--- a/doc/po/ja/postgis-manual.po
+++ b/doc/po/ja/postgis-manual.po
@@ -10,7 +10,7 @@ msgstr ""
 "Project-Id-Version: postgis 3.5\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2026-08-04 15:37+0000\n"
-"PO-Revision-Date: 2026-08-21 07:39+0000\n"
+"PO-Revision-Date: 2026-08-21 09:39+0000\n"
 "Last-Translator: Teramoto Ikuhiro <teramoto.ikuhiro576 at naro.go.jp>\n"
 "Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/postgis-"
 "manual/ja/>\n"
@@ -45254,6 +45254,10 @@ msgid ""
 "link>, Clarify postgis_full_version() output when installed component "
 "scripts are newer than core scripts (Darafei Praliaskouski)"
 msgstr ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/2808\">#2808</link>"
+", インストールされているコンポーネントのスクリプトが中核のスクリプトより新し"
+"い時には postgis_full_version() の出力でその旨を明示します (Darafei "
+"Praliaskouski)"
 #. Tag: para
 #, no-c-format
@@ -45263,6 +45267,11 @@ msgid ""
 "files, enabling parallel builds, keeping ImageMagick fallbacks working, and "
 "documenting the generator workflow for contributors (Darafei Praliaskouski)"
 msgstr ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/5593\">#5593</link>"
+", ドキュメント: GraphicsMagick を使ったマニュアルの画像の生成で一時ファイル不"
+"要にし、並列画像生成ができるようにし、ImageMagick への後退が引き続き可能なよ"
+"うにし、開発者向け生成処理のワークフローを文書化しました (Darafei "
+"Praliaskouski さん)"
 #. Tag: para
 #, no-c-format
Summary of changes:
 doc/po/ja/postgis-manual.po | 11 ++++++++++-
 1 file changed, 10 insertions(+), 1 deletion(-)
hooks/post-receive
