[SCM] PostGIS branch master updated. 3.7.0beta2-88-g94533b3fb
Fri Aug 21 01:19:23 PDT 2026
the project "PostGIS".
       via  94533b3fb459c31b62937068c6e4b3ca4bc3ec3b (commit)
       via  961da26a061a28cfa962b51f5dd6aac822a964b9 (commit)
      from  bc5e893d1a065c6456f572984007006116155727 (commit)
revisions in full, below.
commit 94533b3fb459c31b62937068c6e4b3ca4bc3ec3b
Merge: bc5e893d1 961da26a0
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Fri Aug 21 01:19:21 2026 -0700
    Merge pull request 'ci: decouple localized HTML workflow steps' (!750) from Komzpa/postgis:fix/docs-ja-pruned-dependency-20260821 into master
    Localized HTML jobs are path-pruned independently, so serial dependencies between locales can reference a step Woodpecker removed from the workflow graph. Each locale now depends only on its own XML check.
    Validated: YAML parsing, no sibling html-* dependency remains, and git diff --check.
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/750
commit 961da26a061a28cfa962b51f5dd6aac822a964b9
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Fri Aug 21 11:33:08 2026 +0400
diff --git a/.woodpecker/docs.yml b/.woodpecker/docs.yml
index 51ee6147c..4caca002b 100644
--- a/.woodpecker/docs.yml
+++ b/.woodpecker/docs.yml
@@ -300,7 +300,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/pt_BR local-html
-    depends_on: [ check-xml-pt_BR, html-it_IT ]
+    depends_on: [ check-xml-pt_BR ]
     when:
       - path: *when_localized
@@ -309,7 +309,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/fr local-html
-    depends_on: [ check-xml-fr, html-pt_BR ]
+    depends_on: [ check-xml-fr ]
     when:
@@ -318,7 +318,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/es local-html
-    depends_on: [ check-xml-es, html-fr ]
+    depends_on: [ check-xml-es ]
     when:
@@ -327,7 +327,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/pl local-html
-    depends_on: [ check-xml-pl, html-es ]
+    depends_on: [ check-xml-pl ]
     when:
@@ -336,7 +336,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ka local-html
-    depends_on: [ check-xml-ka, html-pl ]
+    depends_on: [ check-xml-ka ]
     when:
@@ -345,7 +345,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ko_KR local-html
-    depends_on: [ check-xml-ko_KR, html-ka ]
+    depends_on: [ check-xml-ko_KR ]
     when:
@@ -354,7 +354,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/da local-html
-    depends_on: [ check-xml-da, html-ko_KR ]
+    depends_on: [ check-xml-da ]
     when:
@@ -363,7 +363,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/de local-html
-    depends_on: [ check-xml-de, html-da ]
+    depends_on: [ check-xml-de ]
     when:
@@ -372,7 +372,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ja local-html
-    depends_on: [ check-xml-ja, html-de ]
+    depends_on: [ check-xml-ja ]
     when:
@@ -381,7 +381,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ru local-html
-    depends_on: [ check-xml-ru, html-ja ]
+    depends_on: [ check-xml-ru ]
     when:
@@ -390,7 +390,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/zh_Hans local-html
-    depends_on: [ check-xml-zh_Hans, html-ru ]
+    depends_on: [ check-xml-zh_Hans ]
     when:
@@ -399,7 +399,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/ro local-html
-    depends_on: [ check-xml-ro, html-zh_Hans ]
+    depends_on: [ check-xml-ro ]
     when:
@@ -408,7 +408,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/sv local-html
-    depends_on: [ check-xml-sv, html-ro ]
+    depends_on: [ check-xml-sv ]
     when:
@@ -417,7 +417,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/uk local-html
-    depends_on: [ check-xml-uk, html-sv ]
+    depends_on: [ check-xml-uk ]
     when:
@@ -426,7 +426,7 @@ steps:
     pull: true
     commands:
       - make -C build-docs/doc/po/be local-html
-    depends_on: [ check-xml-be, html-uk ]
+    depends_on: [ check-xml-be ]
     when:
Summary of changes:
 .woodpecker/docs.yml | 30 +++++++++++++++---------------
 1 file changed, 15 insertions(+), 15 deletions(-)
hooks/post-receive
