[SCM] PostGIS branch master updated. 3.7.0beta2-86-gbc5e893d1
git at osgeo.org
git at osgeo.org
Fri Aug 21 00:39:16 PDT 2026
the project "PostGIS".
via bc5e893d1a065c6456f572984007006116155727 (commit)
from 3ffaa36a89aa35395cf0d5af8e528fde1637fe4b (commit)
revisions in full, below.
commit bc5e893d1a065c6456f572984007006116155727
Author: Teramoto Ikuhiro <yellow at affrc.go.jp>
Date: Fri Aug 21 05:48:38 2026 +0000
Translated PostGIS Manual using Weblate (Japanese)
Currently translated at 98.0% (5918 of 6037 strings)
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/ja/
diff --git a/doc/po/ja/postgis-manual.po b/doc/po/ja/postgis-manual.po
index 7511d9a76..077d1e6ac 100644
--- a/doc/po/ja/postgis-manual.po
+++ b/doc/po/ja/postgis-manual.po
@@ -10,7 +10,7 @@ msgstr ""
"Project-Id-Version: postgis 3.5\n"
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2026-08-04 15:37+0000\n"
-"PO-Revision-Date: 2026-08-21 03:39+0000\n"
+"PO-Revision-Date: 2026-08-21 07:39+0000\n"
"Last-Translator: Teramoto Ikuhiro <teramoto.ikuhiro576 at naro.go.jp>\n"
"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/postgis-"
"manual/ja/>\n"
@@ -45230,6 +45230,13 @@ msgid ""
"PostgreSQL 18 `pgbench` microbenchmark over 100k four-point groups this "
"reduced `ST_Collect` aggregate latency by about 4% (Darafei Praliaskouski)"
msgstr ""
+"PostgreSQL エクステンションモジュールのビルドにおいて可能なら `-fno-semantic-"
+"interposition` 付でビルドします。これにより、LTO (Link Time Optimization) は"
+"同じ DSO (Dynamic Shared Object) 内のエクスポート済の PostGIS "
+"エントリーポイントへの呼出しをモジュールの PLT (Procedure Linkage Table) を介"
+"さず直接に最適化できます。手持ちの PostgreSQL 18 でマイクロベンチマーク "
+"`pgbench` によって `ST_Collect` のレイテンシーを調べたところ、4点 1組のデータ"
+"を 100k組与える場合には約 4%削減できました (Darafei Praliaskouski さん)"
#. Tag: para
#, no-c-format
Summary of changes:
doc/po/ja/postgis-manual.po | 9 ++++++++-
1 file changed, 8 insertions(+), 1 deletion(-)
hooks/post-receive
