[SCM] PostGIS branch master updated. 3.7.0beta2-95-g2d730fa21
Fri Aug 21 05:19:54 PDT 2026
the project "PostGIS".
       via  2d730fa218e1c2af3883359a82b6581b5bc917ce (commit)
       via  02b1be58d5dcde9654f5f828459f72a47cd45c3c (commit)
       via  b4c83952e0a6f4830209cd09a118eb58fd307899 (commit)
       via  878b8d1adf1861f7abe69fbb11d163a330e33609 (commit)
      from  7b8342a25554a44b83feaff2904fd7addd530d8f (commit)
revisions in full, below.
commit 2d730fa218e1c2af3883359a82b6581b5bc917ce
Merge: 7b8342a25 02b1be58d
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Fri Aug 21 05:19:53 2026 -0700
    Merge pull request 'liblwgeom: stream NURBS bbox Bezier extraction' (!755) from Komzpa/postgis:fix/nurbs-gbox-work-budget-547330051 into master
    ## Summary
    - Replace whole-curve NURBS knot insertion in bbox calculation with streaming local Bezier extraction.
    - Preserve per-span bbox calculation while avoiding repeated full-array copies for large valid curves.
    - Add bbox regressions for rational Z/M, unclamped knots, and high-degree implicit-knot NURBS.
    Closes https://issues.oss-fuzz.com/issues/547330051
    ## Tests
    - `make -C liblwgeom`
    - `make -C liblwgeom/cunit check` (`376` tests, `5940` asserts)
    - targeted `gserialized_from_bytea_fuzzer` dummy runner: exact 56-byte testcase, 100 iterations, `elapsed=1.49 exit=0`
    - baseline dummy runner on the same testcase/loop timed out at 20 s (`exit=124`)
    - `git clang-format --extensions c,h upstream/master --diff`
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/755
commit 02b1be58d5dcde9654f5f828459f72a47cd45c3c
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Fri Aug 21 16:18:54 2026 +0400
    liblwgeom: document streaming NURBS bbox extraction
diff --git a/liblwgeom/gbox.c b/liblwgeom/gbox.c
index 6a210d9a3..d29541a4a 100644
--- a/liblwgeom/gbox.c
+++ b/liblwgeom/gbox.c
@@ -1030,8 +1030,10 @@ lwnurbscurve_calculate_gbox_cartesian(const LWNURBSCURVE *curve, GBOX *gbox)
 	lwnurbscurve_gbox_init(gbox, lwflags(FLAGS_GET_Z(curve->flags), FLAGS_GET_M(curve->flags), 0));
 	/* Stream the standard B-spline to Bezier decomposition with one current
-	 * and one next control net. This preserves the exact span geometry while
-	 * avoiding whole-curve knot refinement and its quadratic memory churn. */
+	 * and one next control net. This is Boehm knot insertion arranged so the
+	 * insertions for one knot block are applied only to the local control net,
+	 * preserving the exact span geometry while avoiding whole-curve knot
+	 * refinement and its quadratic memory churn. */
 		NURBS_BBOX_HPOINT bezier[degree + 1];
 		NURBS_BBOX_HPOINT next_bezier[degree + 1];
@@ -1048,6 +1050,8 @@ lwnurbscurve_calculate_gbox_cartesian(const LWNURBSCURVE *curve, GBOX *gbox)
 			uint32_t knot_block_start = b;
+			/* Exact comparison is intentional: these values come directly from
+			 * the validated knot vector or its generated uniform replacement. */
 			while (b < m && knots[b + 1] == knots[b])
 				b++;
@@ -1056,6 +1060,9 @@ lwnurbscurve_calculate_gbox_cartesian(const LWNURBSCURVE *curve, GBOX *gbox)
 				double numer = knots[b] - knots[a];
+				/* Precompute the knot-insertion blend factors for this block.
+				 * A zero denominator would mean the validated active span has
+				 * collapsed, so fail instead of feeding NaNs to the bbox code. */
 				for (j = degree; j > multiplicity; j--)
 					double denom = knots[a + j] - knots[a];
@@ -1074,6 +1081,9 @@ lwnurbscurve_calculate_gbox_cartesian(const LWNURBSCURVE *curve, GBOX *gbox)
 					uint32_t save = r - j;
+					/* Each pass raises the current knot multiplicity by one.
+					 * The rightmost point saved on every pass becomes the left
+					 * side of the next span's control net. */
 					s = multiplicity + j;
 					for (i = degree; i >= s; i--)
@@ -1086,6 +1096,9 @@ lwnurbscurve_calculate_gbox_cartesian(const LWNURBSCURVE *curve, GBOX *gbox)
+			/* Only bbox spans inside the NURBS active parameter domain
+			 * [U[p], U[n]]. Unclamped explicit knot vectors can contain valid
+			 * knots before or after that domain, and those must not contribute. */
 			if (knots[b] > knots[a] && knots[a] >= domain_min && knots[b] <= domain_max)
 				if (lwnurbscurve_add_bezier_span_gbox(bezier, degree, gbox->flags, 0, gbox) ==
@@ -1100,6 +1113,8 @@ lwnurbscurve_calculate_gbox_cartesian(const LWNURBSCURVE *curve, GBOX *gbox)
 			if (knots[b] >= domain_max || b >= m)
 				break;
+			/* Complete the next span from the saved right edge and the untouched
+			 * original control points that are entering the moving local window. */
 			for (i = degree - FP_MIN(multiplicity, degree); i <= degree; i++)
 				lwnurbscurve_get_hpoint(curve, b - degree + i, &next_bezier[i]);
commit b4c83952e0a6f4830209cd09a118eb58fd307899
Date:   Fri Aug 21 16:10:46 2026 +0400
    NEWS: document NURBS bbox extraction fix
diff --git a/NEWS b/NEWS
index 03f7d58f6..63e6b127a 100644
--- a/NEWS
+++ b/NEWS
@@ -11,6 +11,9 @@ These are only changes since 3.7.0beta2.
  - Codex security scan, guard the recursive NURBSCURVE bounding box
           against non-finite control points to stop a backend CPU denial
           of service reachable from WKT input (Darafei Praliaskouski)
+ - GT-755, OSSFuzz 547330051, stream NURBSCURVE bounding box Bezier extraction
+          to avoid repeated full-array knot insertion on large valid curves
+          (Darafei Praliaskouski)
  - Fix geometry input parsing to stop malformed SRID prefixes before the
           end of the input string
           (Dennis Tighe, Google)
commit 878b8d1adf1861f7abe69fbb11d163a330e33609
Date:   Fri Aug 21 15:18:01 2026 +0400
    Replace whole-curve NURBS knot insertion for bbox calculation with a streaming Bezier decomposition that only keeps the current and next local control nets. This preserves the exact span bbox contract while avoiding repeated full-array copies for large valid curves.
    Credit to OSS-Fuzz.
    OSS-Fuzz: https://issues.oss-fuzz.com/issues/547330051
diff --git a/liblwgeom/cunit/cu_gserialized1.c b/liblwgeom/cunit/cu_gserialized1.c
index 374fec6bf..c31228c75 100644
--- a/liblwgeom/cunit/cu_gserialized1.c
+++ b/liblwgeom/cunit/cu_gserialized1.c
@@ -196,6 +196,17 @@ static void test_lwgeom_calculate_gbox(void)
 	CU_ASSERT_EQUAL(next_float_up(b.ymax), next_float_up(0.75));
 	lwgeom_free(g);
+	/* The same rational span logic must honor Z and M ordinates. */
+	g = lwgeom_from_wkt("NURBSCURVE ZM(2, (0 0 0 0, 1 1 1 2, 2 0 0 0), (1, 3, 1), (0, 0, 0, 1, 1, 1))",
+			    LW_PARSER_CHECK_NONE);
+	lwgeom_calculate_gbox_cartesian(g, &b);
+	CU_ASSERT_DOUBLE_EQUAL(b.xmin, 0.0, 0.0000001);
+	CU_ASSERT_DOUBLE_EQUAL(b.xmax, 2.0, 0.0000001);
+	CU_ASSERT_EQUAL(next_float_up(b.ymax), next_float_up(0.75));
+	CU_ASSERT_EQUAL(next_float_up(b.zmax), next_float_up(0.75));
+	CU_ASSERT_EQUAL(next_float_up(b.mmax), next_float_up(1.5));
+	lwgeom_free(g);
 	/* Repeated knots split the curve into independent Bezier spans. */
 	g = lwgeom_from_wkt("NURBSCURVE(2, (0 0, 1 1, 2 0, 3 1, 4 0), (1, 1, 1, 1, 1), (0, 0, 0, 0.5, 0.5, 1, 1, 1))",
@@ -205,6 +216,26 @@ static void test_lwgeom_calculate_gbox(void)
 	CU_ASSERT_EQUAL(next_float_up(b.ymax), next_float_up(0.5));
 	lwgeom_free(g);
+	/* An explicit unclamped knot vector only exposes the active parameter
+	 * domain, so local extraction must not emit off-domain spans. */
+	g = lwgeom_from_wkt("NURBSCURVE(2, (0 0, 1 1, 2 0), (1, 1, 1), (0, 1, 2, 3, 4, 5))", LW_PARSER_CHECK_NONE);
+	CU_ASSERT_DOUBLE_EQUAL(b.ymin, 0.0, 0.0000001);
+	CU_ASSERT_DOUBLE_EQUAL(b.xmax, 1.5, 0.0000001);
+	CU_ASSERT_EQUAL(next_float_up(b.ymax), next_float_up(2.0 / 3.0));
+	lwgeom_free(g);
+	/* A high-degree implicit-knot NURBS must keep the exact span bbox rather
+	 * than falling back to the control-point hull ymax of 100. */
+	g = lwgeom_from_wkt("NURBSCURVE(6, (0 0, 1 100, 2 100, 3 100, 4 100, 5 100, 6 0))", LW_PARSER_CHECK_NONE);
+	CU_ASSERT_DOUBLE_EQUAL(b.xmax, 6.0, 0.0000001);
+	CU_ASSERT_EQUAL(next_float_up(b.ymax), next_float_up(96.875));
+	CU_ASSERT(b.ymax < 100.0);
+	lwgeom_free(g);
 	/* A non-finite control point coordinate must not make the recursive
 	 * Bezier-subdivision bbox spin: NaN never compares equal to itself, so
 	 * the stop tests in lwnurbscurve_add_bezier_span_gbox() could not
index 13ebedfa4..6a210d9a3 100644
@@ -37,14 +37,6 @@ typedef struct {
 	double w;
 } NURBS_BBOX_HPOINT;
-typedef struct {
-	uint32_t degree;
-	uint32_t npoints;
-	uint32_t nknots;
-	NURBS_BBOX_HPOINT *points;
-	double *knots;
-} NURBS_BBOX_WORK;
 GBOX* gbox_new(lwflags_t flags)
 	GBOX *g = (GBOX*)lwalloc(sizeof(GBOX));
@@ -740,6 +732,25 @@ lwnurbscurve_hpoint_lerp(const NURBS_BBOX_HPOINT *a, const NURBS_BBOX_HPOINT *b,
 	return out;
+ * Loads one control point in homogeneous coordinates, applying the implicit
+ * weight 1.0 for polynomial curves so Bezier extraction can use the same
+ * arithmetic for rational and non-rational spans.
+static void
+lwnurbscurve_get_hpoint(const LWNURBSCURVE *curve, uint32_t index, NURBS_BBOX_HPOINT *hpoint)
+	POINT4D point;
+	double weight = (curve->weights && index < curve->nweights) ? curve->weights[index] : 1.0;
+	getPoint4d_p(curve->points, index, &point);
+	hpoint->x = point.x * weight;
+	hpoint->y = point.y * weight;
+	hpoint->z = FLAGS_GET_Z(curve->flags) ? point.z * weight : 0.0;
+	hpoint->m = FLAGS_GET_M(curve->flags) ? point.m * weight : 0.0;
+	hpoint->w = weight;
  * Expands a Cartesian box in each enabled dimension, keeping dimensionality
  * decisions out of the projection and subdivision helpers.
@@ -971,217 +982,6 @@ lwnurbscurve_add_bezier_span_gbox(const NURBS_BBOX_HPOINT *points,
 	return LW_SUCCESS;
- * Counts exact copies of a knot value. Exact comparison is intentional: this
- * code queries values already present in, or copied directly into, the vector.
-static uint32_t
-lwnurbscurve_knot_multiplicity(const double *knots, uint32_t nknots, double knot)
-	uint32_t i, multiplicity = 0;
-	for (i = 0; i < nknots; i++)
-		if (knots[i] == knot)
-			multiplicity++;
-	return multiplicity;
- * Finds the half-open knot span [U[i], U[i + 1]) used by knot insertion,
- * clamping either domain endpoint to its valid boundary span. The work knot
- * vector has already been validated as nondecreasing.
-static uint32_t
-lwnurbscurve_gbox_find_span(const NURBS_BBOX_WORK *work, double knot)
-	uint32_t npoints = work->npoints;
-	uint32_t degree = work->degree;
-	uint32_t low, high, mid;
-	if (knot >= work->knots[npoints])
-		return npoints - 1;
-	if (knot <= work->knots[degree])
-		return degree;
-	low = degree;
-	high = npoints;
-	mid = (low + high) / 2;
-	while (knot < work->knots[mid] || knot >= work->knots[mid + 1])
-		if (knot < work->knots[mid])
-			high = mid;
-		else
-			low = mid;
-	return mid;
- * Inserts one knot into the homogeneous B-spline work arrays while preserving
- * the curve, allowing its spans to be converted into Bezier form.
-static int
-lwnurbscurve_insert_knot_once(NURBS_BBOX_WORK *work, double knot)
-	uint32_t i;
-	uint32_t n = work->npoints - 1;
-	uint32_t k = lwnurbscurve_gbox_find_span(work, knot);
-	uint32_t s = lwnurbscurve_knot_multiplicity(work->knots, work->nknots, knot);
-	double *knots;
-	/* Boehm knot insertion in homogeneous coordinates preserves the rational
-	 * curve while replacing the affected control points by convex blends. */
-	if (s > degree)
-		return LW_FAILURE;
-	points = lwalloc(sizeof(NURBS_BBOX_HPOINT) * (work->npoints + 1));
-	knots = lwalloc(sizeof(double) * (work->nknots + 1));
-	for (i = 0; i <= k; i++)
-		knots[i] = work->knots[i];
-	knots[k + 1] = knot;
-	for (i = k + 1; i < work->nknots; i++)
-		knots[i + 1] = work->knots[i];
-	for (i = 0; i <= k - degree; i++)
-		points[i] = work->points[i];
-	for (i = k - s + 1; i <= n + 1; i++)
-		points[i] = work->points[i - 1];
-	for (i = k - degree + 1; i <= k - s; i++)
-		double denom = work->knots[i + degree] - work->knots[i];
-		double alpha;
-		if (denom == 0.0)
-			lwfree(points);
-			lwfree(knots);
-		alpha = (knot - work->knots[i]) / denom;
-		points[i] = lwnurbscurve_hpoint_lerp(&work->points[i - 1], &work->points[i], alpha);
-	lwfree(work->points);
-	lwfree(work->knots);
-	work->points = points;
-	work->knots = knots;
-	work->npoints++;
-	work->nknots++;
-	return LW_SUCCESS;
- * Raises a knot to the requested multiplicity through curve-preserving
- * insertions, preparing domain boundaries and interior Bezier breaks.
-static int
-lwnurbscurve_ensure_knot_multiplicity(NURBS_BBOX_WORK *work, double knot, uint32_t target)
-	while (lwnurbscurve_knot_multiplicity(work->knots, work->nknots, knot) < target)
-		if (lwnurbscurve_insert_knot_once(work, knot) == LW_FAILURE)
- * Refines the working knot vector into independent Bezier spans, making each
- * non-empty part suitable for conservative convex-hull bounding.
-static int
-lwnurbscurve_make_bezier_work(NURBS_BBOX_WORK *work, double domain_min, double domain_max)
-	uint32_t i;
-	/* A B-spline decomposes into Bezier spans once the domain endpoints have
-	 * multiplicity p + 1 and every interior knot has multiplicity p. Zero-width
-	 * spans remain in the knot vector and are skipped by the caller. */
-	if (lwnurbscurve_ensure_knot_multiplicity(work, domain_min, work->degree + 1) == LW_FAILURE ||
-	    lwnurbscurve_ensure_knot_multiplicity(work, domain_max, work->degree + 1) == LW_FAILURE)
-	for (i = 0; i < work->nknots;)
-		double knot = work->knots[i];
-		uint32_t multiplicity = 1;
-		while (i + multiplicity < work->nknots && work->knots[i + multiplicity] == knot)
-			multiplicity++;
-		if (knot > domain_min && knot < domain_max && multiplicity < work->degree)
-			i = 0;
-		else
-			i += multiplicity;
- * Releases the owned arrays used for refinement. Both pointers may be NULL
- * because initialization can fail after allocating only part of the workset.
-static void
-lwnurbscurve_free_work(NURBS_BBOX_WORK *work)
-	if (work->points)
-	if (work->knots)
- * Builds owned homogeneous control-point and knot arrays for bounding, so knot
- * insertion can refine the curve without modifying the input geometry.
-static int
-lwnurbscurve_init_work(const LWNURBSCURVE *curve, NURBS_BBOX_WORK *work)
-	uint32_t i;
-	memset(work, 0, sizeof(NURBS_BBOX_WORK));
-	work->degree = curve->degree;
-	work->npoints = curve->points->npoints;
-	work->knots = lwnurbscurve_get_or_generate_knots(curve, &work->nknots);
-	if (!work->knots || work->nknots == 0)
-	work->points = lwalloc(sizeof(NURBS_BBOX_HPOINT) * work->npoints);
-	for (i = 0; i < work->npoints; i++)
-		POINT4D point;
-		double weight = (curve->weights && i < curve->nweights) ? curve->weights[i] : 1.0;
-		getPoint4d_p(curve->points, i, &point);
-		work->points[i].x = point.x * weight;
-		work->points[i].y = point.y * weight;
-		work->points[i].z = FLAGS_GET_Z(curve->flags) ? point.z * weight : 0.0;
-		work->points[i].m = FLAGS_GET_M(curve->flags) ? point.m * weight : 0.0;
-		work->points[i].w = weight;
 static int lwpoint_calculate_gbox_cartesian(LWPOINT *point, GBOX *gbox)
 	if ( ! point ) return LW_FAILURE;
@@ -1204,42 +1004,114 @@ static int lwline_calculate_gbox_cartesian(LWLINE *line, GBOX *gbox)
 static int
-	uint32_t i;
+	uint32_t a, b, degree, i, j, m, multiplicity, npoints, r, s;
 	int found_span = LW_FALSE;
-	double domain_min, domain_max;
-	NURBS_BBOX_WORK work;
+	double domain_max, domain_min;
+	double *knots;
+	uint32_t nknots;
 	if (!curve || !curve->points || curve->points->npoints == 0)
 		return LW_FAILURE;
-	if (lwnurbscurve_init_work(curve, &work) == LW_FAILURE)
+	degree = curve->degree;
+	npoints = curve->points->npoints;
+	knots = lwnurbscurve_get_or_generate_knots(curve, &nknots);
+	if (!knots || nknots == 0)
 		return LW_FAILURE;
-	domain_min = work.knots[work.degree];
-	domain_max = work.knots[work.npoints];
-	if (domain_max <= domain_min || lwnurbscurve_make_bezier_work(&work, domain_min, domain_max) == LW_FAILURE)
+	domain_min = knots[degree];
+	domain_max = knots[npoints];
+	if (domain_max <= domain_min || nknots != npoints + degree + 1)
-		lwnurbscurve_free_work(&work);
+		lwfree(knots);
 		return LW_FAILURE;
-	for (i = work.degree; i < work.npoints; i++)
+	/* Stream the standard B-spline to Bezier decomposition with one current
+	 * and one next control net. This preserves the exact span geometry while
+	 * avoiding whole-curve knot refinement and its quadratic memory churn. */
-		if (work.knots[i] < domain_min || work.knots[i + 1] > domain_max || work.knots[i + 1] <= work.knots[i])
-			continue;
+		NURBS_BBOX_HPOINT bezier[degree + 1];
+		NURBS_BBOX_HPOINT next_bezier[degree + 1];
+		double alphas[degree ? degree : 1];
-		if (lwnurbscurve_add_bezier_span_gbox(
-			&work.points[i - work.degree], work.degree, gbox->flags, 0, gbox) == LW_FAILURE)
+		for (i = 0; i <= degree; i++)
+			lwnurbscurve_get_hpoint(curve, i, &bezier[i]);
+		m = npoints + degree;
+		a = degree;
+		b = degree + 1;
+		while (b < m)
+			uint32_t knot_block_start = b;
+			while (b < m && knots[b + 1] == knots[b])
+				b++;
+			multiplicity = b - knot_block_start + 1;
+			if (multiplicity < degree)
+				double numer = knots[b] - knots[a];
+				for (j = degree; j > multiplicity; j--)
+					double denom = knots[a + j] - knots[a];
+					if (denom == 0.0)
+						lwfree(knots);
+						return LW_FAILURE;
+					alphas[j - multiplicity - 1] = numer / denom;
+				r = degree - multiplicity;
+				for (j = 1; j <= r; j++)
+					uint32_t save = r - j;
+					s = multiplicity + j;
+					for (i = degree; i >= s; i--)
+						double alpha = alphas[i - s];
+						bezier[i] = lwnurbscurve_hpoint_lerp(&bezier[i - 1], &bezier[i], alpha);
+					if (b < m)
+						next_bezier[save] = bezier[degree];
+			if (knots[b] > knots[a] && knots[a] >= domain_min && knots[b] <= domain_max)
+				if (lwnurbscurve_add_bezier_span_gbox(bezier, degree, gbox->flags, 0, gbox) ==
+				    LW_FAILURE)
+					lwfree(knots);
+				found_span = LW_TRUE;
+			if (knots[b] >= domain_max || b >= m)
+				break;
+			for (i = degree - FP_MIN(multiplicity, degree); i <= degree; i++)
+				lwnurbscurve_get_hpoint(curve, b - degree + i, &next_bezier[i]);
+				bezier[i] = next_bezier[i];
+			a = b;
+			b++;
-		found_span = LW_TRUE;
+	lwfree(knots);
 	return found_span ? LW_SUCCESS : LW_FAILURE;
Summary of changes:
 NEWS                              |   3 +
 liblwgeom/cunit/cu_gserialized1.c |  31 ++++
 liblwgeom/gbox.c                  | 359 +++++++++++++-------------------------
 3 files changed, 157 insertions(+), 236 deletions(-)
hooks/post-receive
