[SCM] PostGIS branch master updated. 3.7.0beta2-98-g68826c04e
Fri Aug 21 06:29:15 PDT 2026
the project "PostGIS".
       via  68826c04ef9d0aa277add2cb842dcae1a8b82b42 (commit)
       via  983e36a14b7b7dd099c470a5b95854978a3a9f09 (commit)
       via  f7d3017de9608cea7ea6ef73e56d159d06ba21ad (commit)
      from  2d730fa218e1c2af3883359a82b6581b5bc917ce (commit)
revisions in full, below.
commit 68826c04ef9d0aa277add2cb842dcae1a8b82b42
Merge: 2d730fa21 983e36a14
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Fri Aug 21 06:29:14 2026 -0700
    Merge pull request 'regress: use bounded interrupt timing checks' (!754) from Komzpa/postgis:fix/interrupt-relation-timeout-master-tolerance-20260821 into master
    Keep the interrupt test bounded while preserving its timeout assertion, and rename the newly introduced NURBS bbox `numer` local to `numerator` so the current master codespell gate can run.
    Validation: Woodpecker pipeline 7138 passed 30/30 on the pre-rebase head; the updated head is queued for the same matrix.
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/754
commit 983e36a14b7b7dd099c470a5b95854978a3a9f09
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Fri Aug 21 16:47:53 2026 +0400
    ci: fix NURBS bbox codespell finding
diff --git a/liblwgeom/gbox.c b/liblwgeom/gbox.c
index d29541a4a..7685300bd 100644
--- a/liblwgeom/gbox.c
+++ b/liblwgeom/gbox.c
@@ -1058,7 +1058,7 @@ lwnurbscurve_calculate_gbox_cartesian(const LWNURBSCURVE *curve, GBOX *gbox)
 			multiplicity = b - knot_block_start + 1;
 			if (multiplicity < degree)
-				double numer = knots[b] - knots[a];
+				double numerator = knots[b] - knots[a];
 				/* Precompute the knot-insertion blend factors for this block.
 				 * A zero denominator would mean the validated active span has
@@ -1073,7 +1073,7 @@ lwnurbscurve_calculate_gbox_cartesian(const LWNURBSCURVE *curve, GBOX *gbox)
 						return LW_FAILURE;
-					alphas[j - multiplicity - 1] = numer / denom;
+					alphas[j - multiplicity - 1] = numerator / denom;
 				r = degree - multiplicity;
commit f7d3017de9608cea7ea6ef73e56d159d06ba21ad
Date:   Fri Aug 21 15:54:41 2026 +0400
diff --git a/regress/core/interrupt_relate.sql b/regress/core/interrupt_relate.sql
index 619c92df6..dabecdd5f 100644
--- a/regress/core/interrupt_relate.sql
+++ b/regress/core/interrupt_relate.sql
@@ -20,25 +20,25 @@ BEGIN;
 SET LOCAL statement_timeout TO 100;
 select ST_Contains(g,g) from _inputs WHERE id = 1; -- 6+ seconds
 ROLLBACK;
-SELECT _timecheck('contains');
+SELECT _timecheck('contains', '500ms');
 BEGIN;
 select ST_Covers(g,g) from _inputs WHERE id = 1; -- 6+ seconds
 ROLLBACK;
-SELECT _timecheck('covers');
+SELECT _timecheck('covers', '500ms');
 BEGIN;
 select ST_CoveredBy(g,g) from _inputs WHERE id = 1; -- 6+ seconds
 ROLLBACK;
-SELECT _timecheck('coveredby');
+SELECT _timecheck('coveredby', '500ms');
 BEGIN;
 select ST_Crosses(g,g) from _inputs WHERE id = 1; -- 6+ seconds
 ROLLBACK;
-SELECT _timecheck('crosses');
+SELECT _timecheck('crosses', '500ms');
 BEGIN;
@@ -46,7 +46,7 @@ SET LOCAL statement_timeout TO 100;
 --       short-circuit described in #3226
 select ST_Equals(g,st_reverse(g)) from _inputs WHERE id = 1; -- 6+ seconds
 ROLLBACK;
-SELECT _timecheck('equals');
+SELECT _timecheck('equals', '500ms');
 BEGIN;
@@ -54,19 +54,19 @@ SET LOCAL statement_timeout TO 100;
 --       input to make it slower
 select ST_Intersects(g,ST_Segmentize(g,1e-4)) from _inputs WHERE id = 1; -- 6+ seconds
 ROLLBACK;
-SELECT _timecheck('intersects');
+SELECT _timecheck('intersects', '500ms');
 BEGIN;
 select ST_Overlaps(g,g) from _inputs WHERE id = 1; -- 6+ seconds
 ROLLBACK;
-SELECT _timecheck('overlaps');
+SELECT _timecheck('overlaps', '500ms');
 BEGIN;
 select ST_Relate(g,g) from _inputs WHERE id = 1; -- 6+ seconds
 ROLLBACK;
-SELECT _timecheck('relate');
+SELECT _timecheck('relate', '500ms');
 DROP FUNCTION _timecheck(text);
 DROP FUNCTION _timecheck(text, interval);
Summary of changes:
 liblwgeom/gbox.c                  |  4 ++--
 regress/core/interrupt_relate.sql | 16 ++++++++--------
 2 files changed, 10 insertions(+), 10 deletions(-)
hooks/post-receive
