[SCM] PostGIS branch master updated. 3.7.0beta2-121-g07f2423d4
git at osgeo.org
git at osgeo.org
Sun Aug 23 22:42:02 PDT 2026
the project "PostGIS".
via 07f2423d43a29a909e02d60c34a36e82f6f646c6 (commit)
from a3f36ff78f2dae38e00110e7deacac2cbd5ee9d5 (commit)
revisions in full, below.
commit 07f2423d43a29a909e02d60c34a36e82f6f646c6
Author: Regina Obe <lr at pcorp.us>
Date: Mon Aug 24 01:41:26 2026 -0400
Prep for 3.7.0rc1 release
diff --git a/NEWS b/NEWS
index 05fa84500..a30a62c06 100644
--- a/NEWS
+++ b/NEWS
@@ -1,5 +1,5 @@
PostGIS 3.7.0rc1
-2026/xx/xx
+2026/08/xx
This version requires GEOS 3.10+, PostgreSQL 14-19beta2, Proj 6.1+, libgmp.
To take advantage of all features postgis extension features, GEOS 3.15+ is needed.
To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed.
diff --git a/README.postgis b/README.postgis
index 1ab49a34c..9184fe193 100644
--- a/README.postgis
+++ b/README.postgis
@@ -1,8 +1,8 @@
PostGIS - Geographic Information Systems Extensions to PostgreSQL
-:Version: 3.6.0rc2
-:Date: 2025-08-25
+:Version: 3.7.0
+:Date: 2026-08-24
:Website: https://postgis.net
This distribution contains a module which implements GIS simple features, ties
diff --git a/Version.config b/Version.config
index 2e5a68cb5..8c7c6a020 100644
--- a/Version.config
+++ b/Version.config
@@ -5,7 +5,7 @@
POSTGIS_MAJOR_VERSION=3
POSTGIS_MINOR_VERSION=7
-POSTGIS_MICRO_VERSION=0dev
+POSTGIS_MICRO_VERSION=0rc1
# Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
# when changing POSTGIS_MINOR_VERSION
diff --git a/doc/reference_processing.xml b/doc/reference_processing.xml
index 8b756ce0b..b6b1889ef 100644
--- a/doc/reference_processing.xml
+++ b/doc/reference_processing.xml
@@ -732,7 +732,7 @@ FROM (SELECT 'POLYGON((0 0,8 8,0 16,0 0))'::geometry geom) AS foo;</programlist
<para>The result has interpolated values for the Z and M dimensions when present.</para>
<para>&Z_support;</para>
- <para role="availability" conformance="3.6.0">Availability: 3.6.0</para>
+ <para role="availability" conformance="3.7.0">Availability: 3.7.0</para>
</refsection>
<refsection>
diff --git a/extensions/upgradeable_versions.mk b/extensions/upgradeable_versions.mk
index 64d1614e2..36c6fa06b 100644
--- a/extensions/upgradeable_versions.mk
+++ b/extensions/upgradeable_versions.mk
@@ -130,4 +130,5 @@ UPGRADEABLE_VERSIONS = \
3.6.4 \
3.7.0alpha1 \
3.7.0beta1 \
- 3.7.0beta2
+ 3.7.0beta2 \
+ 3.7.0dev
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 5b77260c1..2dbfd3e74 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -3768,7 +3768,7 @@ CREATE OR REPLACE FUNCTION ST_ChaikinSmoothing(geometry, integer default 1, bool
LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
_COST_MEDIUM;
--- Availability: 3.6.0
+-- Availability: 3.7.0
CREATE OR REPLACE FUNCTION ST_CatmullRomSmoothing(geometry, integer default 5)
RETURNS geometry
AS 'MODULE_PATHNAME', 'LWGEOM_CatmullRomSmoothing'
Summary of changes:
NEWS | 2 +-
README.postgis | 4 ++--
Version.config | 2 +-
doc/reference_processing.xml | 2 +-
extensions/upgradeable_versions.mk | 3 ++-
postgis/postgis.sql.in | 2 +-
6 files changed, 8 insertions(+), 7 deletions(-)
hooks/post-receive
