[PostGIS] #5790: Postgis-functions in Materialized views fail in Postgres 17 due to not fully qualified search path
PostGIS trac at osgeo.org
Wed Feb 4 20:21:56 PST 2026
  Reporter:  maxbo    |      Owner:  robe
      Type:  defect   |     Status:  closed
  Priority:  high     |  Milestone:  PostGIS 3.4.4
 Component:  postgis  |    Version:  3.4.x
Resolution:  fixed    |   Keywords:
Comment (by robe):
 @landry,
 I have one additional thought about this, given that the issue sounds
 intermittent at least in psql (always fails pn pyschopg), it just occurred
 to me that ST_EstimatedExtent is very sensitive to vacuum analyze process.
 I would really avoid using it in a materialized view if you can.  My
 thought is maybe depending on the frequency of your updates/delete/inserts
 to this table, it could be all over the place and even at times perhaps
 just return garbage.  I haven't dug deep into the function to see what it
 is doing.
 But based on your error message, I gather it is failing here -
 https://gitea.osgeo.org/postgis/postgis/src/commit/3ec6fdb951aaec20db3fc35ee274752eeb15d07c/postgis/gserialized_estimate.c#L2493
 @pramsey have any thoughts on this why a geometry data type would suddenly
 turn invalid?
 To get a more predictable answer, and perhaps it might even solve your
 issue, try redoing your materialized view as
 below, though you will suffer a performance penalty.  Depending on the
 size of your public.pictures and the number of cpus you have, the
 performance penalty may be acceptable and the behavior would be more
 predictable
 CREATE MATERIALIZED VIEW test_grid AS
 SELECT row_number() OVER() AS id,  g.geom
 FROM
    (SELECT ST_SetSRID(ST_Extent(geom), 4326) AS ext FROM public.pictures)
 AS t
    CROSS JOIN LATERAL ST_SquareGrid(
         0.1,
         t.ext
     ) AS g;
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5790#comment:13>
