[PostGIS] #6042: Getting downgrade errors on debbie for PostGIS 3.4 when newer library can't be loaded
trac at osgeo.org
Sun Feb 8 16:10:32 PST 2026
be loaded
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.4.5
Component: upgrade/soft | Version: 3.5.x
Resolution: | Keywords:
Comment (by robe):
Replying to [comment:1 strk]:
> It fails loading 3.5.1 because it was built against a newer version of
GEOS which isn't found at loading time. We could make such cases a SKIP
instead of a FAIL, given the focus is on testing the target (3.4 in this
case) rather than the source of the downgrade (3.5.1 in this case). Or you
can pass --skip-tests to fine tune which tests to skip ("downgrade
3.5.1dev--3.4.5" in this specific case)
Yah I think this would be the best thing to do cause there is no way
winnie and debbie could ever do this. For now I'm just going to skip the
upgrade tests on debbie so I can move on.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6042#comment:2>
