[SCM] PostGIS branch stable-3.2 updated. 3.2.7-68-g5ce3fb961
Sun Feb 8 17:37:53 PST 2026
the project "PostGIS".
The branch, stable-3.2 has been updated
       via  5ce3fb9618f5f40ba31e20c7161f77bed5e5fe0b (commit)
       via  b1cefd1bc2e6e5b5d3d7000237b99d6dc79efe02 (commit)
       via  e6c8937248f2740190c51993d097b1d14efe8b74 (commit)
      from  9c9a4ab6052b2da23dd7b8e239d14b9d7bddc1b4 (commit)
revisions in full, below.
commit 5ce3fb9618f5f40ba31e20c7161f77bed5e5fe0b
Author: Regina Obe <lr at pcorp.us>
Date:   Sun Feb 8 20:37:15 2026 -0500
    NEWS update
    References #6043 for PostGIS 3.2.9
diff --git a/NEWS b/NEWS
index 7793acada..f6eeb4cd5 100644
--- a/NEWS
+++ b/NEWS
@@ -30,6 +30,8 @@ Proj 4.9+ required.
         by extension are owned by extension
         authored: Andrey Borodin (Yandex), reported by Sergey Bobrov (Kaspersky)
  - #5985, Fix configure issue with Debian 12 and 13 (Regina Obe, Sandro Santilli)
+ - #6043, assignment of read-only member
+            ‘postgis_flatbuffers::span<T, Extent>::count_  (Regina Obe)
 PostGIS 3.2.8
 2024/12/22
commit b1cefd1bc2e6e5b5d3d7000237b99d6dc79efe02
Date:   Sun Feb 8 20:31:59 2026 -0500
    FLATGEOBUF error
     - assignment of read-only member ‘postgis_flatbuffers::span<T, Extent>::count_’
    Closes #6043 for PostGIS 3.2.9
diff --git a/deps/flatgeobuf/include/flatbuffers/stl_emulation.h b/deps/flatgeobuf/include/flatbuffers/stl_emulation.h
index 70e5dc944..9b93170b0 100644
--- a/deps/flatgeobuf/include/flatbuffers/stl_emulation.h
+++ b/deps/flatgeobuf/include/flatbuffers/stl_emulation.h
@@ -625,7 +625,7 @@ class span FLATBUFFERS_FINAL_CLASS {
  private:
   // This is a naive implementation with 'count_' member even if (Extent != dynamic_extent).
   pointer const data_;
-  const size_type count_;
+  size_type count_;
  #if !defined(FLATBUFFERS_SPAN_MINIMAL)
commit e6c8937248f2740190c51993d097b1d14efe8b74
Date:   Sat Feb 7 15:02:28 2026 -0500
    Updates to winnie's scripts
diff --git a/ci/winnie/build_postgis.sh b/ci/winnie/build_postgis.sh
index c5423623a..9f3d9f0cf 100644
--- a/ci/winnie/build_postgis.sh
+++ b/ci/winnie/build_postgis.sh
@@ -1,80 +1,6 @@
 #!/usr/bin/env bash
-set -e
-if  [[ "${OVERRIDE}" == '' ]] ; then
-	export GEOS_VER=3.10.0
-	export GDAL_VER=3.3.3
-	export PROJ_VER=7.2.1
-	export SFCGAL_VER=1.4.0
-	export CGAL_VER=5.3
-	export ICON_VER=1.16
-	export ZLIB_VER=1.2.11
-  export PROTOBUF_VER=3.2.0
-	export PROTOBUFC_VER=1.2.1
-	export JSON_VER=0.12
-	export PROJSO=libproj-19.dll
-fi;
-export PROTOBUF_VER=3.2.0
-export PROTOBUFC_VER=1.2.1
-export JSON_VER=0.12
-export PCRE_VER=8.33
-if  [[ "${ICON_VER}" == '' ]] ; then
-  export ICON_VER=1.15
-fi;
-echo "ICON_VER ${ICON_VER}"
-#set to something even if override is on but not set
-if  [[ "${ZLIB_VER}" == '' ]] ; then
-fi;
-if  [[ "${LIBXML_VER}" == '' ]] ; then
-  export LIBXML_VER=2.7.8
-fi;
-if  [[ "${CGAL_VER}" == '' ]] ; then
-fi;
-#export GDAL_VER=2.4.0
-#export PROJ_VER=5.2.0
-echo "ZLIB_VER $ZLIB_VER"
-echo "PROJ_VER $PROJ_VER"
-echo "LIBXML_VER $LIBXML_VER"
-echo "CGAL_VER $CGAL_VER"
-export PROJECTS=/projects
-export MINGPROJECTS=/projects
-export PATHOLD=$PATH
-if [ "$OS_BUILD" == "64" ] ; then
-	export MINGHOST=x86_64-w64-mingw32
-else
-	export MINGHOST=i686-w64-mingw32
-fi;
-echo PATH AFTER: $PATH
-#export PG_VER=9.2beta2
-export PGWINVER=${PG_VER}edb
-export WORKSPACE=`pwd`
-echo PATH BEFORE: $PATH
-#export PGHOST=localhost
-#export PGPORT=8442
-export PGUSER=postgres
-#export GEOS_VER=3.4.0dev
-#export GDAL_VER=1.9.1
-export PGPATH=${PROJECTS}/postgresql/rel/pg${PG_VER}w${OS_BUILD}${GCC_TYPE}
-export PGPATHEDB=${PROJECTS}/postgresql/rel/pg${PG_VER}w${OS_BUILD}${GCC_TYPE}edb
-export POSTGIS_VER=${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}
-export POSTGIS_MICRO_VER=${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}
+. $(dirname $0)/winnie_common.sh
 if [ -n "$SOURCE_FOLDER" ]; then
   export POSTGIS_SRC=${PROJECTS}/postgis/$SOURCE_FOLDER
diff --git a/ci/winnie/package_postgis.sh b/ci/winnie/package_postgis.sh
index 28d8dc3e0..85c427386 100644
--- a/ci/winnie/package_postgis.sh
+++ b/ci/winnie/package_postgis.sh
@@ -1,88 +1,11 @@
-#### $Id: package_postgis210.sh 10291 2012-09-15 05:37:23Z robe $
+#!/usr/bin/env bash
 ### this script is used to zip up the compiled binaries
 ## PostgreSQL, OS_BUILD denote the last build to be packaged
 ## and are passed in by the jenkins job process
-## the scp to postgis website is done using Jenkins scp plugin as a final step
-#export OS_BUILD=64
-#POSTGIS_MAJOR_VERSION=2
-#POSTGIS_MINOR_VERSION=1
-#POSTGIS_MICRO_VERSION=0dev
-#export OS_BUILD=32
-#export GCC_TYPE=
-#if no override is set - use these values
-#otherwise use the ones jenkins passes thru
-#!/usr/bin/env bash
-	export GEOS_VER=3.10.3
-	export GDAL_VER=3.4.3
-	export SFCGAL_VER=1.4.1
-	export CURL_VER=7.73
-fi;
-fi;
-if  [[ "${CURL_VER}" == '' ]] ; then
-fi;
-echo "CURL_VER ${CURL_VER}"
-fi;
-  export LIBXML_VER=2.9.9
-fi;
-fi;
-export PGHOST=localhost
-WEB=/home/www/postgis/htdocs
-DWN=${WEB}/download
-export PATHOLD="/mingw/bin:/mingw/include:/c/Windows/system32:/c/Windows:.:/bin:/include:/usr/local/bin"
diff --git a/ci/winnie/regress_postgis.sh b/ci/winnie/regress_postgis.sh
index 3797d6ae7..eab14f4e2 100644
--- a/ci/winnie/regress_postgis.sh
+++ b/ci/winnie/regress_postgis.sh
@@ -1,76 +1,14 @@
 #!/usr/bin/env bash
-set -e
-	export CGAL_VER=5.3.0
-fi;
-fi;
-fi;
-fi;
-fi;
-else
-fi;
+echo "MSYS2_ARG_CONV_EXCL=$MSYS2_ARG_CONV_EXCL"
@@ -79,6 +17,7 @@ export POSTGIS_MICRO_VER=${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POS
+  cd $POSTGIS_SRC
 else
   if [[ "$POSTGIS_MICRO_VERSION"  == *SVN* || "$POSTGIS_MICRO_VERSION"  == *dev* ]] ; then
     export POSTGIS_SRC=${PROJECTS}/postgis/branches/${POSTGIS_VER}
@@ -88,22 +27,16 @@ else
   fi;
 fi;
+export POSTGIS_MAJOR_VERSION=`grep ^POSTGIS_MAJOR_VERSION Version.config | cut -d= -f2`
+export POSTGIS_MINOR_VERSION=`grep ^POSTGIS_MINOR_VERSION Version.config | cut -d= -f2`
+export POSTGIS_MICRO_VERSION=`grep ^POSTGIS_MICRO_VERSION Version.config | cut -d= -f2`
+echo "Version ${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}"
 #export POSTGIS_SRC=${PROJECTS}/postgis/trunk
 export GDAL_DATA="${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/share/gdal"
 export RELVERDIR=postgis-pg${REL_PGVER}-binaries-${POSTGIS_MICRO_VER}w${OS_BUILD}
-export PATH="${PATHOLD}:${PGPATH}/bin:${PGPATH}/lib"
-export PATH="${PROJECTS}/xsltproc:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/bin:${MINGPROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
-export PKG_CONFIG_PATH="${PROJECTS}/sqlite/rel-sqlite3w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:/mingw/${MINGHOST}/lib/pkgconfig"
-export SHLIB_LINK="-static-libstdc++ -lstdc++ -Wl,-Bdynamic -lm"
-CPPFLAGS="-I${PGPATH}/include -I${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include"
-#needed for proj.db to be found during cunit - for some reason on winnie it doesn't set
-export PROJ_LIB=${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/share/proj
-#add protobuf
-export PATH="${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
@@ -146,6 +79,7 @@ if [ -n "$SFCGAL_VER" ]; then
 #LDFLAGS="-Wl,--enable-auto-import -L${PGPATH}/lib -L${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib -L${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib" \
+CPPFLAGS="-I${PGPATH}/include -I${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include" \
 LDFLAGS="-Wl,--enable-auto-import -L${PGPATH}/lib -L${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib -L${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib" \
 ./configure \
   --host=${MINGHOST} --with-xml2config=${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin/xml2-config  \
diff --git a/ci/winnie/winnie_common.sh b/ci/winnie/winnie_common.sh
new file mode 100644
index 000000000..244ba3287
--- /dev/null
+++ b/ci/winnie/winnie_common.sh
@@ -0,0 +1,143 @@
+# Common code for all winnie scripts
+# TODO: add more shared code, I guess
+set -e
+export PROJECTS=/projects
+# Don't convert paths
+# See https://trac.osgeo.org/postgis/ticket/5436#comment:5
+export MSYS2_ARG_CONV_EXCL=/config/tags
+if  [[ "${OVERRIDE}" == '' ]] ; then
+	export GEOS_VER=3.13.1
+	export GDAL_VER=3.9.2
+	export PROJ_VER=8.2.1
+	export SFCGAL_VER=1.5.2
+	export CGAL_VER=5.6.1
+	export ICON_VER=1.17
+	export ZLIB_VER=1.2.13
+	export PROTOBUF_VER=3.2.0
+	export PROTOBUFC_VER=1.2.1
+	export JSON_VER=0.12
+	export PROJSO=libproj_8_2.dll
+	export LZ4_VER=1.9.3
+fi;
+export PROTOBUF_VER=3.2.0
+export PROTOBUFC_VER=1.2.1
+export JSON_VER=0.12
+export PCRE_VER=8.45
+#export OS_BUILD=64
+#export PGPORT=8442
+#export OS_BUILD=32
+#export GCC_TYPE=
+#if no override is set - use these values
+#otherwise use the ones jenkins passes thru
+if  [[ "${ICON_VER}" == '' ]] ; then
+fi;
+echo "ICON_VER ${ICON_VER}"
+#set to something even if override is on but not set
+if  [[ "${ZLIB_VER}" == '' ]] ; then
+fi;
+if  [[ "${LIBXML_VER}" == '' ]] ; then
+  export LIBXML_VER=2.12.5
+fi;
+if  [[ "${CGAL_VER}" == '' ]] ; then
+fi;
+##hard code versions of cgal etc. for now
+export CGAL_VER=5.6.1
+BOOST_VER=1.84.0
+export BOOST_VER_WU=1_84_0
+export LZ4_PATH=${PROJECTS}/lz4/rel-lz4-${LZ4_VER}w${OS_BUILD}${GCC_TYPE}
+export PATH="${PROJECTS}/CGAL/rel-cgal-${CGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/CGAL/rel-sfcgal-${SFCGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/boost/rel-${BOOST_VER_WU}w${OS_BUILD}${GCC_TYPE}/lib:${LZ4_PATH}/bin:${LZ4_PATH}/lib:${PATH}"
+#export GDAL_VER=2.4.0
+#export PROJ_VER=5.2.0
+echo "ZLIB_VER $ZLIB_VER"
+echo "PROJ_VER $PROJ_VER"
+echo "LIBXML_VER $LIBXML_VER"
+echo "CGAL_VER $CGAL_VER"
+export MINGPROJECTS=/projects
+export PATHOLD=$PATH
+if [ "$OS_BUILD" == "64" ] ; then
+	export MINGHOST=x86_64-w64-mingw32
+else
+	export MINGHOST=i686-w64-mingw32
+fi;
+#needed for proj.db to be found during cunit - for some reason on winnie it doesn't set
+if [ -d "${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/share/proj" ]; then
+export PROJ_LIB=${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/share/proj
+export PROJ_PATH=${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}
+else
+export PROJ_LIB=${PROJECTS}/proj/rel-proj-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/share/proj
+export PROJ_PATH=${PROJECTS}/proj/rel-proj-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}
+fi
+#export PG_VER=9.2beta2
+export PGWINVER=${PG_VER}edb
+export WORKSPACE=`pwd`
+echo PATH BEFORE: $PATH
+#export PGHOST=localhost
+export PGUSER=postgres
+#export GEOS_VER=3.4.0dev
+#export GDAL_VER=1.9.1
+export PGPATH=${PROJECTS}/postgresql/rel/pg${PG_VER}w${OS_BUILD}${GCC_TYPE}
+export PGPATHEDB=${PROJECTS}/postgresql/rel/pg${PG_VER}w${OS_BUILD}${GCC_TYPE}edb
+export GDAL_DATA="${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/share/gdal"
+export PATH="${PATHOLD}:${PGPATH}/bin:${PGPATH}/lib"
+export PATH="${PROJECTS}/xsltproc:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJ_PATH}/bin:${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
+export PKG_CONFIG_PATH="${PROJECTS}/sqlite/rel-sqlite3w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJ_PATH}/lib/pkgconfig:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:/mingw/${MINGHOST}/lib/pkgconfig"
+export SHLIB_LINK="-static-libstdc++ -lstdc++ -Wl,-Bdynamic -lm"
+#add protobuf
+export PATH="${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
+#add lz4
+export PATH="${LZ4_PATH}/bin:${LZ4_PATH}/lib:${PATH}"
+echo $PATH
+export PATH="${PROJECTS}/xsltproc:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/proj/rel-proj-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
+export PKG_CONFIG_PATH="${PROJECTS}/sqlite/rel-sqlite3w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/proj/rel-proj-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${LZ4_PATH}/lib/pkgconfig"
+#add protobuf
+echo "PATH AFTER: $PATH"
+if  [[ "${INCLUDE_MINOR_LIB}" == "" ]] ; then
+	export INCLUDE_MINOR_LIB=1
+fi;
Summary of changes:
 NEWS                                               |   2 +
 ci/winnie/build_postgis.sh                         |  76 +----------
 ci/winnie/package_postgis.sh                       |  81 +-----------
 ci/winnie/regress_postgis.sh                       |  84 ++----------
 ci/winnie/winnie_common.sh                         | 143 +++++++++++++++++++++
 .../flatgeobuf/include/flatbuffers/stl_emulation.h |   2 +-
 6 files changed, 158 insertions(+), 230 deletions(-)
 create mode 100644 ci/winnie/winnie_common.sh
hooks/post-receive
