[PostGIS] #6044: winnie failing make check because of docbook xml validate errors
trac at osgeo.org
Sun Feb 8 18:21:35 PST 2026
Reporter: robe | Owner: robe
Type: defect | Status: assigned
Priority: blocker | Milestone: PostGIS 3.3.9
Component: install | Version: 3.5.x
Keywords: |
This is happening on versions lower than 3.5
/projects/libxml/rel-libxml2-2.9.14w64/bin/xmllint --loaddtd --path
.:/projects/postgis/branches/3.4/doc --xinclude --valid postgis-out.xml
--noout
http://www.oasis-open.org/docbook/xml/4.5/dbcentx.mod:316: warning: failed
to load external entity "http://www.oasis-
open.org/docbook/xml/4.5/ent/isoamsc.ent"
%ISOamsc;
http://www.oasis-open.org/docbook/xml/4.5/dbcentx.mod:360: warning: failed
open.org/docbook/xml/4.5/ent/isogrk4.ent"
%ISOgrk4;
http://www.oasis-open.org/docbook/xml/4.5/dbcentx.mod:380: warning: failed
open.org/docbook/xml/4.5/ent/isotech.ent"
%ISOtech;
http://www.oasis-open.org/docbook/xml/4.5/dbpoolx.mod:3794: warning:
failed to load external entity "http://www.oasis-
open.org/docbook/xml/4.5/htmltblx.mod"
%htmltbl;
http://www.oasis-open.org/docbook/xml/4.5/dbpoolx.mod:3931: parser warning
: PEReference: %attrs; not found
postgis-out.xml:911: element informaltable: validity error : No
declaration for attribute border of element informaltable
postgis-out.xml:979: element informaltable: validity error : No
postgis-out.xml:1088: element informaltable: validity error : No
postgis-out.xml:1186: element informaltable: validity error : No
postgis-out.xml:155: element informaltable: validity error : No
postgis-out.xml:194: element entry: validity error : No declaration for
attribute style of element entry
postgis-out.xml:328: element informaltable: validity error : No
postgis-out.xml:357: element informaltable: validity error : No
make[1]: *** [Makefile:577: check-xml] Error 4
make[1]: Leaving directory '/projects/postgis/branches/3.4/doc'
make: *** [GNUmakefile:25: check-unit] Error 1
I noticed on version 3.5, we are not passing in an xsl style sheet, so
maybe that is preventing validation on 3.5 or above.
I'm going to take that out of the configure on 3.4 and lower to see if
that fixes the issue.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6044>
