[PostGIS] #6045: PostGIS 3.2 no rule to make docs-localized
trac at osgeo.org
Sun Feb 8 22:09:21 PST 2026
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.2.10
Component: build | Version: 3.2.x
Keywords: |
Getting this error on woodie's doc build job
/usr/bin/xsltproc --param section.autolabel 1 --param
section.label.includes.component.label 1 --param chunk.section.depth 0
--param generate.section.toc.level 2 --param funcsynopsis.style kr --param
admon.graphics 1 --param admon.textlabel 0 --param make.clean.html 1
--param simplesect.in.toc 0 --param use.id.as.filename 1 --param
chunk.quietly 1 --param header.rule 0 --param footer.rule 0 --param
table.borders.with.css 1 --stringparam chunker.output.encoding UTF-8
--stringparam chunker.output.indent no --stringparam
saxon.character.representation decimal --stringparam html.stylesheet
style.css --nonet \
--output html/postgis.html \
/usr/share/xml/docbook/stylesheet/docbook-xsl-ns/html/docbook.xsl
postgis-out.xml
Note: namesp. add : added namespace before processing PostGIS
3.2.10dev Manual
Attributed 46627 IDs for element, cleaned up 0
make[1]: Leaving directory
'/woodpecker/src/gitea.osgeo.org/postgis/postgis/doc'
+ make -C doc check
make: Entering directory
/usr/bin/xmllint --loaddtd --xinclude --valid postgis-out.xml > /dev/null
make: Leaving directory
+ make docs-localized
make: *** No rule to make target 'docs-localized'. Stop.
Debbie doesn't bother building localized docs for 3.2 so that is probably
why her make-dist wasn't impacted by this, but woodie is checking. I
question if it's even worthwhile to do this check for stable branches
since we never update localized in stable branches.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6045>
