[SCM] PostGIS branch stable-3.4 updated. 3.4.4-82-gd341f18aa
Mon Feb 9 00:55:23 PST 2026
the project "PostGIS".
The branch, stable-3.4 has been updated
       via  d341f18aa3a31f90671f8cb3f8a11f1f7bf3c188 (commit)
       via  85a6f86c45068db4f0458a945fca81c173d1f312 (commit)
       via  3bef6ba87549fe91030ca44bfc1dea09c5a14e04 (commit)
       via  5f2ad5e4b16c47038ba634ac0806c7ec3610322f (commit)
      from  cd048b71de18eaaf6247f8cf6854ec2aaa2aae85 (commit)
revisions in full, below.
commit d341f18aa3a31f90671f8cb3f8a11f1f7bf3c188
Author: Regina Obe <lr at pcorp.us>
Date:   Mon Feb 9 03:53:28 2026 -0500
    ADd check for XSLBASE and don't do check-xml unless it's set
    References #6044 for PostGIS 3.4.5
diff --git a/ci/winnie/regress_postgis.sh b/ci/winnie/regress_postgis.sh
index 9906d5659..ddd3ff15f 100644
--- a/ci/winnie/regress_postgis.sh
+++ b/ci/winnie/regress_postgis.sh
@@ -79,7 +79,6 @@ LDFLAGS="-Wl,--enable-auto-import -L${PGPATH}/lib -L${LZ4_PATH}/bin -L${PROJECTS
   --with-pgconfig=${PGPATH}/bin/pg_config \
   --with-geosconfig=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin/geos-config \
   --with-libiconv=${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE} \
-  --with-xsldir=${PROJECTS}/docbook/docbook-xsl-1.76.1 \
   --with-gui --with-gettext=no \
   --with-sfcgal=${PROJECTS}/CGAL/rel-sfcgal-${SFCGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin/sfcgal-config \
   --prefix=${PROJECTS}/postgis/liblwgeom-${POSTGIS_VER}w${OS_BUILD}${GCC_TYPE} --with-library-minor-version
@@ -91,7 +90,6 @@ LDFLAGS="-Wl,--enable-auto-import -L${PGPATH}/lib -L${LZ4_PATH}/bin -L${PROJECTS
diff --git a/doc/Makefile.in b/doc/Makefile.in
index b01cc88c9..4beed47ee 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -1,6 +1,6 @@
 # PostGIS - Spatial Types for PostgreSQL
-# http://www.postgis.net
+# https://postgis.net
 # This is free software; you can redistribute and/or modify it under
 # the terms of the GNU General Public Licence. See the COPYING file.
@@ -249,6 +249,7 @@ GENERATED_CHEATSHEET_FILES = $(patsubst \
 VPATH = $(srcdir)
 .PHONY: $(XML_INPUTS_POT)
+CAN_CHECK_XML = yes
 ifeq ($(XML2POT),)
 $(XML_INPUTS_POT): requirements_not_met_xml2pot
 else
@@ -564,15 +565,24 @@ endif
 %_gardentest_${POSTGIS_MAJOR_VERSION}${POSTGIS_MINOR_VERSION}.sql: xsl/postgis_gardentest.sql.xsl postgis-out.xml
 	$(XSLTPROC) -o $@ $(XSLTPROC_PATH_OPT) $^
-check: check-unit
-check-regress:
-check-unit: check-xml
 ifeq ($(XMLLINT),)
 check-xml: requirements_not_met_xmllint
 check-cheatsheets: requirements_not_met_xmllint
-else
+CAN_CHECK_XML = no
+endif
+ifeq ($(XSLBASE),)
+check-xml: requirements_not_met_xmlcatalog
+CAN_CHECK_XML = no
+endif
+CHECK_UNIT_TARGET =
+ifeq ($(CAN_CHECK_XML),yes)
+CHECK_UNIT_TARGET = check-xml
+endif
 check-xml: $(XML_INPUTS)
 	$(XMLLINT) --loaddtd $(XSLTPROC_PATH_OPT) --xinclude --valid postgis-out.xml --noout
@@ -581,8 +591,11 @@ check-cheatsheets: cheatsheets
 		$(abs_top_srcdir)/utils/check_localized_cheatsheets.sh $${f} en $(patsubst -%,%,$(DOCSUFFIX)) || exit 1; \
 	done
-endif
+check: check-unit
+check-regress:
+check-unit: $(CHECK_UNIT_TARGET)
 requirements_not_met_xsltproc:
 	@echo
@@ -602,7 +615,7 @@ requirements_not_met_xmllint:
 	@echo "Install xmllint and then re-run configure. Alternatively "
 	@echo "refer to online manual:"
 	@echo
-	@echo "  http://postgis.net/documentation"
+	@echo "  https://postgis.net/documentation"
 	@echo
 	@false
commit 85a6f86c45068db4f0458a945fca81c173d1f312
Date:   Mon Feb 9 02:56:13 2026 -0500
    Turn off cirrus, as we have no credits left on it
diff --git a/.cirrus.yml b/.cirrus.yml
index c0386ff35..51e64211c 100644
--- a/.cirrus.yml
+++ b/.cirrus.yml
@@ -1,5 +1,5 @@
 task:
-  only_if: true
+  only_if: false
   alias: test-freebsd
   #env:
commit 3bef6ba87549fe91030ca44bfc1dea09c5a14e04
Date:   Sun Feb 8 19:42:38 2026 -0500
    Standardize winnie configs
diff --git a/ci/winnie/winnie_common.sh b/ci/winnie/winnie_common.sh
index 0241c6d85..efbc9f929 100644
--- a/ci/winnie/winnie_common.sh
+++ b/ci/winnie/winnie_common.sh
@@ -68,6 +68,9 @@ export BOOST_VER_WU=1_84_0
 export LZ4_PATH=${PROJECTS}/lz4/rel-lz4-${LZ4_VER}w${OS_BUILD}${GCC_TYPE}
+echo ${PATH}
+PATH="/mingw64/bin:/usr/local/bin:/usr/bin:/bin:/c/Windows/System32:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl"
 export PATH="${PROJECTS}/CGAL/rel-cgal-${CGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/CGAL/rel-sfcgal-${SFCGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/boost/rel-${BOOST_VER_WU}w${OS_BUILD}${GCC_TYPE}/lib:${LZ4_PATH}/bin:${LZ4_PATH}/lib:${PATH}"
 #export GDAL_VER=2.4.0
@@ -79,7 +82,7 @@ echo "LIBXML_VER $LIBXML_VER"
 echo "CGAL_VER $CGAL_VER"
 export PROJECTS=/projects
 export MINGPROJECTS=/projects
-export PATHOLD=$PATH
 if [ "$OS_BUILD" == "64" ] ; then
 	export MINGHOST=x86_64-w64-mingw32
@@ -99,6 +102,7 @@ fi
 #export PG_VER=9.2beta2
 export PGWINVER=${PG_VER}edb
 export WORKSPACE=`pwd`
+export XSLTPROCFLAGS=--novalid
 echo PATH BEFORE: $PATH
@@ -112,9 +116,9 @@ export PGPATHEDB=${PROJECTS}/postgresql/rel/pg${PG_VER}w${OS_BUILD}${GCC_TYPE}ed
 export GDAL_DATA="${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/share/gdal"
-export PATH="${PATHOLD}:${PGPATH}/bin:${PGPATH}/lib"
-export PATH="${PROJECTS}/xsltproc:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJ_PATH}/bin:${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
-export PKG_CONFIG_PATH="${PROJECTS}/sqlite/rel-sqlite3w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJ_PATH}/lib/pkgconfig:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:/mingw/${MINGHOST}/lib/pkgconfig"
+export PATH="${PGPATH}/bin:${PGPATH}/lib:${PATH}"
+export PATH="${PROJECTS}/xsltproc:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJ_PATH}/bin:${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
+export PKG_CONFIG_PATH="${PROJECTS}/sqlite/rel-sqlite3w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJ_PATH}/lib/pkgconfig:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PCRE_PATH}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:/mingw/${MINGHOST}/lib/pkgconfig"
 export SHLIB_LINK="-static-libstdc++ -lstdc++ -Wl,-Bdynamic -lm"
 CPPFLAGS="-I${PGPATH}/include -I${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include"
@@ -123,22 +127,25 @@ CPPFLAGS="-I${PGPATH}/include -I${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}
 #add protobuf
 export PATH="${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
+export PATH="${PATH}:${PGPATH}/bin:${PGPATH}/lib"
 #add lz4
 export PATH="${LZ4_PATH}/bin:${LZ4_PATH}/lib:${PATH}"
-echo $PATH
-export PATH="${PROJECTS}/xsltproc:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/include:${PROJECTS}/rel-libiconv-${ICON_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/proj/rel-proj-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
-export PKG_CONFIG_PATH="${PROJECTS}/sqlite/rel-sqlite3w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PROJECTS}/protobuf/rel-${PROTOBUF_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/json-c/rel-${JSON_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/proj/rel-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/proj/rel-proj-${PROJ_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/zlib/rel-zlib-${ZLIB_VER}w${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${PROJECTS}/gtkw${OS_BUILD}${GCC_TYPE}/lib/pkgconfig:${LZ4_PATH}/lib/pkgconfig"
 #add protobuf
+# add pcre for address_standardizer
+if [ -n "$PCRE_PATH" ]; then
+    export PATH="${PCRE_PATH}/include:${PCRE_PATH}/lib:${PATH}"
+fi
 echo "PATH AFTER: $PATH"
-if  [[ "${INCLUDE_MINOR_LIB}" == "" ]] ; then
+if  [[ "${INCLUDE_MINOR_LIB}" == '' ]] ; then
 	export INCLUDE_MINOR_LIB=1
 fi;
commit 5f2ad5e4b16c47038ba634ac0806c7ec3610322f
Date:   Sun Feb 8 19:11:48 2026 -0500
    SKIP upgrade tests on debbie
    References #6042 for PostGIS 3.4.5
diff --git a/ci/debbie/postgis_regress.sh b/ci/debbie/postgis_regress.sh
index f2aa5ff17..7a6dfac24 100644
--- a/ci/debbie/postgis_regress.sh
+++ b/ci/debbie/postgis_regress.sh
@@ -17,7 +17,7 @@ export MAKE_EXTENSION=1
 export DUMP_RESTORE=0
 export MAKE_LOGBT=0
 export NO_SFCGAL=0
-export MAKE_UPGRADE=1
+export MAKE_UPGRADE=0
 ## end variables passed in by jenkins
Summary of changes:
 .cirrus.yml                  |  2 +-
 ci/debbie/postgis_regress.sh |  2 +-
 ci/winnie/regress_postgis.sh |  2 --
 ci/winnie/winnie_common.sh   | 25 ++++++++++++++++---------
 doc/Makefile.in              | 31 ++++++++++++++++++++++---------
 5 files changed, 40 insertions(+), 22 deletions(-)
hooks/post-receive
