[PostGIS] #6044: winnie failing make check because of docbook xml validate errors
PostGIS trac at osgeo.org
Mon Feb 9 00:55:28 PST 2026
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  assigned
  Priority:  blocker  |  Milestone:  PostGIS 3.3.9
 Component:  install  |    Version:  3.3.x
Resolution:           |   Keywords:
Comment (by Regina Obe <lr@…>):
 In [changeset:"d341f18aa3a31f90671f8cb3f8a11f1f7bf3c188/git" d341f18/git]:
 {{{#!CommitTicketReference repository="git"
 revision="d341f18aa3a31f90671f8cb3f8a11f1f7bf3c188"
 ADd check for XSLBASE and don't do check-xml unless it's set
 References #6044 for PostGIS 3.4.5
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6044#comment:2>
