[SCM] PostGIS branch master updated. 3.6.0rc2-331-g3a860ff70
git at osgeo.org
git at osgeo.org
Mon Feb 9 15:28:19 PST 2026
the project "PostGIS".
via 3a860ff70a1a29f02ffbbac913e53eb1e5098bc7 (commit)
from 5fac7d16ab444240d465a36d717b4f0b95c068dd (commit)
revisions in full, below.
commit 3a860ff70a1a29f02ffbbac913e53eb1e5098bc7
Author: Regina Obe <lr at pcorp.us>
Date: Mon Feb 9 18:26:56 2026 -0500
Remove postgis_extension_remove_objects
References #5853 for PostGIS 3.7.0
Fix postgis_tiger_geocoder upgrade for PostgreSQL < 16
References #6032 for PostGIS 3.7.0dev
diff --git a/extensions/postgis_extension_helper.sql.in b/extensions/postgis_extension_helper.sql.in
index d9c648683..3341f9ef1 100644
--- a/extensions/postgis_extension_helper.sql.in
+++ b/extensions/postgis_extension_helper.sql.in
@@ -14,54 +14,6 @@
-- This is a suite of SQL helper functions for use during a PostGIS extension install/upgrade
-- The functions get uninstalled after the extension install/upgrade process
--- postgis_extension_remove_objects: This function removes objects of a particular class from an extension
--- this is needed because there is no ALTER EXTENSION DROP FUNCTION/AGGREGATE command
--- and we can't CREATE OR REPLACE functions whose signatures have changed and we can drop them if they are part of an extension
--- So we use this to remove it from extension first before we drop
-CREATE FUNCTION postgis_extension_remove_objects(param_extension text, param_type text)
- RETURNS boolean AS
-DECLARE
- var_sql text := '';
- var_r record;
- var_result boolean := false;
- var_class text := '';
- var_is_aggregate boolean := false;
- var_sql_list text := '';
-BEGIN
- var_class := CASE WHEN pg_catalog.lower(param_type) OPERATOR(pg_catalog.=)'function' OR pg_catalog.lower(param_type) OPERATOR(pg_catalog.=) 'aggregate' THEN 'pg_catalog.pg_proc' ELSE '' END;
- var_is_aggregate := CASE WHEN pg_catalog.lower(param_type) OPERATOR(pg_catalog.=) 'aggregate' THEN true ELSE false END;
- var_sql_list := $sql$SELECT 'ALTER EXTENSION ' OPERATOR(pg_catalog.||) e.extname OPERATOR(pg_catalog.||) ' DROP ' OPERATOR(pg_catalog.||) $3 OPERATOR(pg_catalog.||) ' ' OPERATOR(pg_catalog.||) COALESCE(proc.proname OPERATOR(pg_catalog.||) '(' OPERATOR(pg_catalog.||) oidvectortypes(proc.proargtypes) OPERATOR(pg_catalog.||) ')' ,typ.typname, cd.relname, op.oprname,
- cs.typname OPERATOR(pg_catalog.||) ' AS ' OPERATOR(pg_catalog.||) ct.typname OPERATOR(pg_catalog.||) ') ', opcname, opfname) OPERATOR(pg_catalog.||) ';' AS remove_command
- FROM pg_catalog.pg_depend As d INNER JOIN pg_catalog.pg_extension As e
- ON d.refobjid OPERATOR(pg_catalog.=) e.oid INNER JOIN pg_catalog.pg_class As c ON
- c.oid OPERATOR(pg_catalog.=) d.classid
- LEFT JOIN pg_catalog.pg_proc AS proc ON proc.oid OPERATOR(pg_catalog.=) d.objid
- LEFT JOIN pg_catalog.pg_type AS typ ON typ.oid OPERATOR(pg_catalog.=) d.objid
- LEFT JOIN pg_catalog.pg_class As cd ON cd.oid OPERATOR(pg_catalog.=) d.objid
- LEFT JOIN pg_operator As op ON op.oid OPERATOR(pg_catalog.=) d.objid
- LEFT JOIN pg_catalog.pg_cast AS ca ON ca.oid OPERATOR(pg_catalog.=) d.objid
- LEFT JOIN pg_catalog.pg_type AS cs ON ca.castsource OPERATOR(pg_catalog.=) cs.oid
- LEFT JOIN pg_catalog.pg_type AS ct ON ca.casttarget OPERATOR(pg_catalog.=) ct.oid
- LEFT JOIN pg_opclass As oc ON oc.oid OPERATOR(pg_catalog.=) d.objid
- LEFT JOIN pg_opfamily As ofa ON ofa.oid OPERATOR(pg_catalog.=) d.objid
- WHERE d.deptype OPERATOR(pg_catalog.=) 'e' and e.extname OPERATOR(pg_catalog.=) $1 and c.relname OPERATOR(pg_catalog.=) $2 AND (proc.prokind OPERATOR(pg_catalog.=) 'a') OPERATOR(pg_catalog.=) $4;$sql$;
- FOR var_r IN EXECUTE var_sql_list USING param_extension, var_class, param_type, var_is_aggregate
- LOOP
- var_sql := var_sql OPERATOR(pg_catalog.||) var_r.remove_command OPERATOR(pg_catalog.||) ';';
- END LOOP;
- IF var_sql > '' THEN
- EXECUTE var_sql;
- var_result := true;
- END IF;
- RETURN var_result;
-END;
-LANGUAGE plpgsql VOLATILE;
CREATE FUNCTION postgis_extension_drop_if_exists(param_extension text, param_statement text)
RETURNS boolean AS
diff --git a/extensions/postgis_extension_helper_uninstall.sql b/extensions/postgis_extension_helper_uninstall.sql
index 2fb1d1756..756dc80f8 100644
--- a/extensions/postgis_extension_helper_uninstall.sql
+++ b/extensions/postgis_extension_helper_uninstall.sql
@@ -13,7 +13,6 @@
-- This drops extension helper functions
-- and should be called at the end of the extension upgrade file
-DROP FUNCTION postgis_extension_remove_objects(text, text);
DROP FUNCTION postgis_extension_drop_if_exists(text, text);
DROP FUNCTION IF EXISTS postgis_extension_AddToSearchPath(varchar);
DROP FUNCTION IF EXISTS postgis_extension_AddToSearchPath(text);
diff --git a/extensions/postgis_tiger_geocoder/Makefile.in b/extensions/postgis_tiger_geocoder/Makefile.in
index c486ec0cc..e0faf1caf 100644
--- a/extensions/postgis_tiger_geocoder/Makefile.in
+++ b/extensions/postgis_tiger_geocoder/Makefile.in
@@ -31,6 +31,12 @@ DATA_built = \
REGRESS = test-normalize_address test-upgrade
REGRESS_OPTS = --load-extension=fuzzystrmatch --load-extension=postgis --load-extension=$(EXTENSION)
+EXTSCHEMA_SUPPORTED = yes
+## PostgreSQL < 16 doesn't understand new @extschema:extname@ syntax, so strip it
+ifeq ($(shell expr "$(POSTGIS_PGSQL_VERSION)" "<" 160),1)
+EXTSCHEMA_SUPPORTED = no
+endif
SQL_BITS = $(wildcard sql_bits/*.sql)
EXTRA_CLEAN = sql expected ${SQL_BITS}
@@ -51,14 +57,14 @@ expected:
sql:
mkdir -p $@
-## PostgreSQL < 16 doesn't understand new @extschema:extname@ syntax, so strip it
-ifeq ($(shell expr "$(POSTGIS_PGSQL_VERSION)" "<" 160),1)
+ifeq ($(EXTSCHEMA_SUPPORTED),yes)
sql/$(EXTENSION)--$(EXTVERSION).sql: sql/$(EXTENSION).sql | sql
- $(PERL) -lpe "s/\@extschema:[a-z]+\@\./ /g" < $< > $@
-else
- sql/$(EXTENSION)--$(EXTVERSION).sql: sql/$(EXTENSION).sql | sql
cp $< $@
+else
+# PG < 16 doesn't support new @extschema:<extension_name>@
+# so we need to strip those out
+sql/$(EXTENSION)--$(EXTVERSION).sql: sql/$(EXTENSION).sql | sql
+ $(PERL) -lpe "s/\@extschema:[^@]+\@\./ /g" < $< > $@
endif
expected/test-normalize_address.out: sql_bits/test_tuples_only_unaligned.sql.in ../../extras/tiger_geocoder/regress/normalize_address_regress | expected
@@ -75,13 +81,13 @@ sql/test-upgrade.sql: | sql
echo 'ALTER EXTENSION ${EXTENSION} UPDATE TO "ANY"; ALTER EXTENSION ${EXTENSION} UPDATE TO "$(EXTVERSION)"' > $@
## no_relocate clause is only available in PostgreSQL 16 and above, so strip it for lower
-%.control: %.control.in Makefile
- $(PERL) -lpe 's/^no_relocate.*//g; s/\@EXTVERSION\@/$(EXTVERSION)/g' < "$<" > "$@"
-else
$(PERL) -lpe "s'@EXTVERSION@'$(EXTVERSION)'g" \
+else
+%.control: %.control.in Makefile
+ $(PERL) -lpe 's/^no_relocate.*//g; s/\@EXTVERSION\@/$(EXTVERSION)/g' < "$<" > "$@"
endif
expected/test-upgrade.out: sql/test-upgrade.sql | expected
@@ -98,7 +104,7 @@ sql/$(EXTENSION).sql: sql/$(EXTENSION)_pre.sql ../../utils/create_or_replace_to_
| $(PERL) @top_srcdir@/utils/create_or_replace_to_create.pl sql/$(EXTENSION)_pre.sql \
-sql/$(EXTENSION)--ANY--$(EXTVERSION).sql: ../postgis_extension_helper.sql sql_bits/remove_from_extension.sql.in sql/tiger_geocoder_upgrade_minor.sql sql_bits/mark_editable_objects.sql.in | sql
+sql/$(EXTENSION)--ANY--$(EXTVERSION).sql: ../postgis_extension_helper.sql sql/tiger_geocoder_upgrade_minor.sql sql_bits/mark_editable_objects.sql.in | sql
cat $^ > $@
echo "SELECT postgis_extension_drop_if_exists('${EXTENSION}', 'DROP SCHEMA tiger_data');" >> $@
cat @srcdir@/../postgis_extension_helper_uninstall.sql >> $@
@@ -205,9 +211,14 @@ sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql: sql_bits/tiger_geocoder--unpack
#aggregates are special
#they can be dropped but we need to remove
#them from the extension first
sql/tiger_geocoder_upgrade_minor.sql: sql/tiger_geocoder_minor.sql.in | sql
- sed -e 's/BEGIN;//g' -e 's/COMMIT;//g' \
+ $(PERL) -pe 's/BEGIN\;//g ; s/COMMIT\;//g' $< > $@
+else
+sql/tiger_geocoder_upgrade_minor.sql: sql/tiger_geocoder_minor.sql.in | sql
+ $(PERL) -pe 's/BEGIN\;//g ; s/COMMIT\;//g ; s/\@extschema:[^@]+\@\.//g' $< > $@
+endif
#only extension files
EXTRA_CLEAN += $(wildcard expected/*--*.out)
diff --git a/extensions/postgis_tiger_geocoder/sql_bits/remove_from_extension.sql.in b/extensions/postgis_tiger_geocoder/sql_bits/remove_from_extension.sql.in
deleted file mode 100644
index c0fc12a3e..000000000
--- a/extensions/postgis_tiger_geocoder/sql_bits/remove_from_extension.sql.in
+++ /dev/null
@@ -1,19 +0,0 @@
--- PostGIS - Spatial Types for PostgreSQL
--- http://postgis.net
--- Copyright (C) 2011 Regina Obe <lr at pcorp.us>
--- This is free software; you can redistribute and/or modify it under
--- the terms of the GNU General Public Licence. See the COPYING file.
--- Author: Regina Obe <lr at pcorp.us>
--- This drops extension helper functions
--- and should be called at the end of the extension upgrade file
--- removes all postgis_topology functions from postgis_topology extension since they will be read
--- during upgrade
-SELECT postgis_extension_remove_objects('postgis_tiger_geocoder', 'FUNCTION');
-SELECT postgis_extension_remove_objects('postgis_tiger_geocoder', 'AGGREGATE');
diff --git a/extensions/postgis_topology/Makefile.in b/extensions/postgis_topology/Makefile.in
index ef3f6034c..0bc04fc56 100644
--- a/extensions/postgis_topology/Makefile.in
+++ b/extensions/postgis_topology/Makefile.in
@@ -42,7 +42,6 @@ DATA_built = \
EXTENSION_UPGRADE_SCRIPTS = \
extlock.sql \
../postgis_extension_helper.sql \
- sql_bits/remove_from_extension.sql.in \
sql/topology_upgrade.sql \
sql_bits/mark_editable_objects.sql.in \
diff --git a/extensions/postgis_topology/sql_bits/remove_from_extension.sql.in b/extensions/postgis_topology/sql_bits/remove_from_extension.sql.in
index cc4cca819..000000000
--- a/extensions/postgis_topology/sql_bits/remove_from_extension.sql.in
+++ /dev/null
@@ -1,19 +0,0 @@
--- during upgrade
-SELECT postgis_extension_remove_objects('postgis_topology', 'FUNCTION');
-SELECT postgis_extension_remove_objects('postgis_topology', 'AGGREGATE');
Summary of changes:
extensions/postgis_extension_helper.sql.in | 48 ----------------------
extensions/postgis_extension_helper_uninstall.sql | 1 -
extensions/postgis_tiger_geocoder/Makefile.in | 37 +++++++++++------
.../sql_bits/remove_from_extension.sql.in | 19 ---------
extensions/postgis_topology/Makefile.in | 1 -
6 files changed, 24 insertions(+), 101 deletions(-)
delete mode 100644 extensions/postgis_tiger_geocoder/sql_bits/remove_from_extension.sql.in
delete mode 100644 extensions/postgis_topology/sql_bits/remove_from_extension.sql.in
hooks/post-receive
