[PostGIS] #5853: Bug in upgrade scripts for topology and tiger geocoder
PostGIS trac at osgeo.org
Mon Feb 9 16:11:22 PST 2026
  Reporter:  sbrys    |      Owner:  robe
      Type:  defect   |     Status:  closed
  Priority:  low      |  Milestone:  PostGIS 3.3.9
 Component:  upgrade  |    Version:  master
Resolution:  fixed    |   Keywords:
Changes (by Regina Obe <lr@…>):
 * resolution:   => fixed
 * status:  new => closed
Comment:
 In [changeset:"8fef3f68db6337af6b95b990ddd373444fe295ff/git" 8fef3f6/git]:
 {{{#!CommitTicketReference repository="git"
 revision="8fef3f68db6337af6b95b990ddd373444fe295ff"
 Remove postgis_extension_remove_objects
 Closes #5853 for PostGIS 3.6.2
 Fix postgis_tiger_geocoder upgrade for PostgreSQL < 16
 Closes #6032 for PostGIS 3.6.2
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5853#comment:10>
