[PostGIS] #6048: postgis_raster crashes in rt_band_set_pixel due to NULL band pointer during ST_Clip operation
trac at osgeo.org
Tue Feb 10 03:36:45 PST 2026
ST_Clip operation
Reporter: maxmli | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.7.0
Component: raster | Version: 3.6.x
Keywords: |
The postgis_raster extension crashes with a segmentation fault in the
`rt_band_set_pixel` function when executing certain `_st_clip` operations.
The crash occurs because a NULL band pointer is passed to
`rt_band_set_pixel`.
'''Steps to Reproduce:'''
{{{#!sql
CREATE EXTENSION postgis;
CREATE EXTENSION postgis_raster;
WITH test_rast AS (
SELECT
ST_AddBand(
ST_AddBand(
ST_AddBand(
ST_SetSRID(
ST_MakeEmptyRaster(10, 10, 1, 1, 1, -1, 0, 0),
4326
'8BUI'::text, 1, 0
'8BUI'::text, 1, 0
'8BUI'::text, 1, 0
) AS rast
test_geom AS (
SELECT ST_SetSRID(
ST_MakeEnvelope(1, 1, 5, 5), 4326) AS geom
SELECT ST_Metadata(_st_clip(r.rast, ARRAY[3], g.geom, ARRAY[255, 255,
255], FALSE))
FROM test_rast r, test_geom g;
'''Stack Trace:'''
#0 rt_band_set_pixel (band=band at entry=0x0, x=x at entry=0, y=y at entry=0,
val=1, converted=converted at entry=0x0) at rt_band.c:1160
#1 0x00007f938f940b68 in RASTER_clip (fcinfo=<optimized out>) at
rtpg_mapalgebra.c:3437
#2 0x00000000006a0553 in ExecInterpExpr (state=0xde46860,
econtext=0xde46f68, isnull=0x7ffcfc9deeef) at execExprInterp.c:931
#3 0x00000000006a28d2 in ExecInterpExprStillValid (state=0xde46860,
econtext=0xde46f68, isNull=0x7ffcfc9deeef) at execExprInterp.c:2311
#4 0x000000000082c007 in ExecEvalExprSwitchContext (state=0xde46860,
at ../../../../src/include/executor/executor.h:440
#5 0x0000000000833498 in evaluate_expr (expr=0xde4c420,
result_type=53657, result_typmod=-1, result_collation=0) at clauses.c:5014
#6 0x000000000083281e in evaluate_function (funcid=54127,
result_type=53657, result_typmod=-1, result_collid=0, input_collid=0,
args=0xde4b528, funcvariadic=false, func_tuple=0x7f9391781f58,
context=0x7ffcfc9e0d10) at clauses.c:4521
#7 0x0000000000831d13 in simplify_function (funcid=54127,
args_p=0x7ffcfc9df100, funcvariadic=false, process_args=true,
allow_non_const=true, context=0x7ffcfc9e0d10) at clauses.c:4110
#8 0x000000000082f367 in eval_const_expressions_mutator (node=0xde43e68,
context=0x7ffcfc9e0d10) at clauses.c:2595
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6048>
