[PostGIS] #5998: Ensure postgis_tiger_geocoder packaged tables are created by the extension
trac at osgeo.org
Wed Feb 11 20:37:13 PST 2026
Reporter: robe | Owner: robe
Type: patch | Status: closed
Priority: medium | Milestone: PostGIS 3.0.12
Component: tiger geocoder | Version: 3.5.x
Resolution: fixed | Keywords:
Changes (by tbussmann):
* cc: tbussmann (added)
Comment:
The backported patch to the 3.2 and 3.3 branches unfortunately did break
upgrades from previous versions.
For `make -C postgis-3.2.9/extensions/postgis_tiger_geocoder installcheck`
the `test test-upgrade` fails with:
/Users/quickfix/Documents/_git/PostgresApp/src-14/postgis-3.2.9/extensions/postgis_tiger_geocoder/expected
/test-upgrade.out 2026-02-11 02:01:47.000000000 +0100
/Users/quickfix/Documents/_git/PostgresApp/src-14/postgis-3.2.9/extensions/postgis_tiger_geocoder/results
/test-upgrade.out 2026-02-11 10:08:36.000000000 +0100
@@ -1 +1,5 @@
ALTER EXTENSION postgis_tiger_geocoder UPDATE TO "3.2.9next"
+ERROR: schema tiger_data is not a member of extension
"postgis_tiger_geocoder"
+DETAIL: An extension may only use CREATE ... IF NOT EXISTS to skip
object creation if the conflicting object is one that it already owns.
+CONTEXT: SQL statement "CREATE SCHEMA IF NOT EXISTS tiger_data"
+PL/pgSQL function inline_code_block line 3 at SQL statement
I also manually verified `postgis_extensions_upgrade()` does fail to
update from 3.2.8 to 3.2.9 if the `postgis_tiger_geocoder` extension is
installed. 3.4 and newer seem not to be affected.
The `installcheck` target does not descend into sub directories, so these
regression tests need to be manually started - this was closed as wontfix
in #5813
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5998#comment:15>
