[SCM] PostGIS branch master updated. 3.6.0rc2-277-g48a31d424
Mon Jan 12 13:28:37 PST 2026
the project "PostGIS".
       via  48a31d424a91b9fda7c125a5c5594689e87d562c (commit)
      from  3c50b132d145ab4c8a5a32d8f8bc7f1676e2ad6b (commit)
revisions in full, below.
commit 48a31d424a91b9fda7c125a5c5594689e87d562c
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Mon Jan 12 13:26:14 2026 -0800
    Back ST_DWithin with GEOSPreparedDistance for cases where
    it might be useful. When at least one object is > 1kb.
    Standard caching criteria (see object more than once).
    Use brute force implementation where caching is not
    indicated.
    Includes a commented out ST_DwithinUncached which is backed by the
    old brute force implementation, for testing purposes.
    Closes #2614
diff --git a/NEWS b/NEWS
index f4c61cbc6..9e96fdbe3 100644
--- a/NEWS
+++ b/NEWS
@@ -24,6 +24,7 @@ xxxx/xx/xx
  - #4222, [raster] ST_DumpAsPolygons honours PostgreSQL interrupts (Darafei Praliaskouski)
  - #5109, Document the meaning of topology.next_left_edge and topology.next_right_edge links (Darafei Praliaskouski)
  - #5889, [topology] Include representative locations in topology build errors (Darafei Praliaskouski)
+ - #2614, Use GEOSPreparedDistance and caching to accelerate ST_DWithin (Paul Ramsey)
 * Bug Fixes *
diff --git a/postgis/lwgeom_functions_basic.c b/postgis/lwgeom_functions_basic.c
index b3e1179b3..ed5f076f2 100644
--- a/postgis/lwgeom_functions_basic.c
+++ b/postgis/lwgeom_functions_basic.c
@@ -66,7 +66,7 @@ Datum ST_Distance(PG_FUNCTION_ARGS);
 Datum LWGEOM_closestpoint(PG_FUNCTION_ARGS);
 Datum LWGEOM_shortestline2d(PG_FUNCTION_ARGS);
 Datum LWGEOM_longestline2d(PG_FUNCTION_ARGS);
-Datum LWGEOM_dwithin(PG_FUNCTION_ARGS);
+Datum ST_DWithinUncached(PG_FUNCTION_ARGS);
 Datum LWGEOM_maxdistance3d(PG_FUNCTION_ARGS);
 Datum LWGEOM_mindistance3d(PG_FUNCTION_ARGS);
@@ -727,8 +727,8 @@ Returns boolean describing if
 mininimum 2d distance between objects in
 geom1 and geom2 is shorter than tolerance
-PG_FUNCTION_INFO_V1(LWGEOM_dwithin);
+PG_FUNCTION_INFO_V1(ST_DWithinUncached);
 	double mindist;
 	GSERIALIZED *geom1 = PG_GETARG_GSERIALIZED_P(0);
diff --git a/postgis/lwgeom_geos_predicates.c b/postgis/lwgeom_geos_predicates.c
index 092795921..fb8989f05 100644
--- a/postgis/lwgeom_geos_predicates.c
+++ b/postgis/lwgeom_geos_predicates.c
@@ -46,6 +46,7 @@
 /* Prototypes for SQL-bound functions */
+Datum LWGEOM_dwithin(PG_FUNCTION_ARGS);
 Datum relate_full(PG_FUNCTION_ARGS);
 Datum relate_pattern(PG_FUNCTION_ARGS);
 Datum disjoint(PG_FUNCTION_ARGS);
@@ -1018,3 +1019,100 @@ Datum relate_full(PG_FUNCTION_ARGS)
+ * ST_DWithin(geom1, geom2, radius) returns boolean
+ * For GEOS >= 3.10, this is a cached predicate implementation much
+ * like the other functions in this module. As with the other prepared
+ * predicates, the utility of the caching/preparation is a function
+ * of the size of the inputs, in particular the cached input, and
+ * that caching only happens if the input shows up multiple times in
+ * a row, which mostly is a result of either a literal or a
+ * nested loop join. The size of the inputs is used as an initial
+ * pre-check on whether to engage the geos/prepared geometry
+ * machinery.
+PG_FUNCTION_INFO_V1(LWGEOM_dwithin);
+	double tolerance = PG_GETARG_FLOAT8(2);
+	double mindist;
+#if POSTGIS_GEOS_VERSION < 31000
+	const GSERIALIZED *geom1 = PG_GETARG_GSERIALIZED_P(0);
+	const GSERIALIZED *geom2 = PG_GETARG_GSERIALIZED_P(1);
+	LWGEOM *lwgeom1 = lwgeom_from_gserialized(geom1);
+	LWGEOM *lwgeom2 = lwgeom_from_gserialized(geom2);
+	mindist = lwgeom_mindistance2d_tolerance(lwgeom1, lwgeom2, tolerance);
+	PG_RETURN_BOOL(tolerance >= mindist);
+#else
+	SHARED_GSERIALIZED *shared_geom1 = ToastCacheGetGeometry(fcinfo, 0);
+	SHARED_GSERIALIZED *shared_geom2 = ToastCacheGetGeometry(fcinfo, 1);
+	const GSERIALIZED *geom1 = shared_gserialized_get(shared_geom1);
+	const GSERIALIZED *geom2 = shared_gserialized_get(shared_geom2);
+	PrepGeomCache *prep_cache = NULL;
+	const size_t small_threshold = 1024;
+	char is_dwithin = -1;
+	 * Only enter the GEOS/PreparedGeometry code line if one of the
+	 * operands is large enough that the win from indexing will exceed
+	 * the loss from GEOS fixed overhead.
+	bool use_prepared =
+		(LWSIZE_GET(geom1->size) > small_threshold) ||
+		(LWSIZE_GET(geom2->size) > small_threshold);
+	if (tolerance < 0)
+		elog(ERROR, "Tolerance cannot be less than zero");
+	 * Error out early for mismatched SRID or empty inputs.
+	gserialized_error_if_srid_mismatch(geom1, geom2, __func__);
+	if (gserialized_is_empty(geom1) || gserialized_is_empty(geom2))
+		PG_RETURN_BOOL(false);
+	 * Only enter GEOS/PreparedGeometry code line if objects
+	 * are big enough and cache is populated.
+	if (use_prepared)
+		initGEOS(lwpgnotice, lwgeom_geos_error);
+		prep_cache = GetPrepGeomCache(fcinfo, shared_geom1, shared_geom2);
+		if (prep_cache && prep_cache->prepared_geom)
+			GEOSGeometry *g = NULL;
+			if (prep_cache->gcache.argnum == 1)
+				g = POSTGIS2GEOS(geom2);
+			else
+				g = POSTGIS2GEOS(geom1);
+			if (!g) HANDLE_GEOS_ERROR("Geometry could not be converted to GEOS");
+			is_dwithin = GEOSPreparedDistanceWithin(prep_cache->prepared_geom, g, tolerance);
+			if (is_dwithin == 2) HANDLE_GEOS_ERROR("GEOSPreparedDistanceWithin");
+			GEOSGeom_destroy(g);
+	 * If for any reason we did not use GEOS/PreparedGeometry, we still
+	 * need an answer, so use the brute force implementation.
+	if (is_dwithin < 0)
+		is_dwithin = (tolerance >= mindist);
+	PG_RETURN_BOOL(is_dwithin);
+#endif
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 3e5916205..4d13ced28 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -4674,6 +4674,14 @@ CREATE OR REPLACE FUNCTION ST_DWithin(geom1 geometry, geom2 geometry, float8)
 	LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
 	_COST_HIGH;
+-- Availability: 3.7.0
+-- Purpose: Uncomment for testing against cached version of ST_DWithin
+-- CREATE OR REPLACE FUNCTION ST_DWithinUncached(geom1 geometry, geom2 geometry, float8)
+-- 	RETURNS boolean
+-- 	AS 'MODULE_PATHNAME', 'ST_DWithinUncached'
+-- 	LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
+-- 	_COST_HIGH;
 -- Availability: 1.2.2
 CREATE OR REPLACE FUNCTION ST_Touches(geom1 geometry, geom2 geometry)
 	RETURNS boolean
Summary of changes:
 NEWS                             |  1 +
 postgis/lwgeom_functions_basic.c |  6 +--
 postgis/lwgeom_geos_predicates.c | 98 ++++++++++++++++++++++++++++++++++++++++
 postgis/postgis.sql.in           |  8 ++++
 4 files changed, 110 insertions(+), 3 deletions(-)
hooks/post-receive
