[SCM] PostGIS branch master updated. 3.6.0rc2-279-g76123f9f6
Tue Jan 13 02:59:42 PST 2026
the project "PostGIS".
       via  76123f9f6e9653e7f7cce728046b42da1fc1ff03 (commit)
       via  5dbb1546c1a7d6158d099be9b1268966230419db (commit)
      from  48a31d424a91b9fda7c125a5c5594689e87d562c (commit)
revisions in full, below.
commit 76123f9f6e9653e7f7cce728046b42da1fc1ff03
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Jan 13 11:59:32 2026 +0100
    Clarify comment
diff --git a/liblwgeom/topo/lwgeom_topo.c b/liblwgeom/topo/lwgeom_topo.c
index 61edd3ef5..5dd4b1f6d 100644
--- a/liblwgeom/topo/lwgeom_topo.c
+++ b/liblwgeom/topo/lwgeom_topo.c
@@ -2238,7 +2238,7 @@ _lwt_AddFaceSplit( LWT_TOPOLOGY* topo,
       if ( found ) continue;
       LWDEBUGF(1, "Edge %" LWTFMT_ELEMID " is not a known edge of the new ring", e->edge_id);
-      /* Check if the edge is now binding a different face */
+      /* Check if the edge is inside the new face */
       if ( ! getPoint2d_p(e->geom->points, 0, &ep) )
commit 5dbb1546c1a7d6158d099be9b1268966230419db
Date:   Tue Jan 13 11:59:21 2026 +0100
    Fix typo in comment
diff --git a/liblwgeom/lwalgorithm.c b/liblwgeom/lwalgorithm.c
index 5cb90a04c..1ab3d74a6 100644
--- a/liblwgeom/lwalgorithm.c
+++ b/liblwgeom/lwalgorithm.c
@@ -97,7 +97,7 @@ lw_pt_in_arc(const POINT2D *P, const POINT2D *A1, const POINT2D *A2, const POINT
 * Returns true if P is between A1/A2. Only makes sense if P has already been
-* deterined to be on the line defined by A1/A2.
+* determined to be on the line defined by A1/A2.
 int
 lw_pt_in_seg(const POINT2D *P, const POINT2D *A1, const POINT2D *A2)
Summary of changes:
 liblwgeom/lwalgorithm.c      | 2 +-
 liblwgeom/topo/lwgeom_topo.c | 2 +-
 2 files changed, 2 insertions(+), 2 deletions(-)
hooks/post-receive
