[SCM] PostGIS branch master updated. 3.6.0rc2-280-g3a6b9e454
git at osgeo.org
git at osgeo.org
Tue Jan 13 03:56:43 PST 2026
the project "PostGIS".
via 3a6b9e454c1ce9a53f14ad87fefcf8cf2ee1ad33 (commit)
from 76123f9f6e9653e7f7cce728046b42da1fc1ff03 (commit)
revisions in full, below.
commit 3a6b9e454c1ce9a53f14ad87fefcf8cf2ee1ad33
Author: Sandro Santilli <strk at kbt.io>
Date: Tue Jan 13 12:05:57 2026 +0100
Fix robustness issue in ptarray_contains_point
References #6023 in master branch (3.7.0dev)
Includes unit and regress tests
diff --git a/liblwgeom/cunit/cu_ptarray.c b/liblwgeom/cunit/cu_ptarray.c
index 99c689ac2..6d8ea2faa 100644
--- a/liblwgeom/cunit/cu_ptarray.c
+++ b/liblwgeom/cunit/cu_ptarray.c
@@ -426,6 +426,17 @@ static void test_ptarray_contains_point()
rv = ptarray_contains_point(pa, &pt);
CU_ASSERT_EQUAL(rv, LW_INSIDE);
+ lwline_free(lwline);
+ /* Test for https://trac.osgeo.org/postgis/ticket/6023 */
+ lwline = lwgeom_as_lwline(lwgeom_from_text("LINESTRING(11.230120879533454 62.84897119848748,11.230120879533905 62.8489711984873,11.23020501303477 62.84900750109812,11.230170431987244 62.84904481447776,11.230117909393426 62.8489943480894,11.230120879533454 62.84897119848748)"));
+ pa = lwline->points;
+ pt = getPoint2d(lwline->points, 0);
+ rv = ptarray_contains_point(pa, &pt);
+ ASSERT_INT_EQUAL(rv, LW_BOUNDARY);
diff --git a/liblwgeom/ptarray.c b/liblwgeom/ptarray.c
index cce30d5b2..9a73230f8 100644
--- a/liblwgeom/ptarray.c
+++ b/liblwgeom/ptarray.c
@@ -768,6 +768,12 @@ ptarray_contains_point(const POINTARRAY *pa, const POINT2D *pt)
seg2 = getPoint2d_cp(pa, i);
+ /* This is required for robustness, see #6023 */
+ if (p2d_same(seg1, pt))
+ return LW_BOUNDARY;
/* Zero length segments are ignored. */
if (p2d_same(seg1, seg2))
diff --git a/topology/test/regress/topogeo_addlinestring.sql b/topology/test/regress/topogeo_addlinestring.sql
index 07465dab9..50c716b6b 100644
--- a/topology/test/regress/topogeo_addlinestring.sql
+++ b/topology/test/regress/topogeo_addlinestring.sql
@@ -589,3 +589,27 @@ SELECT '#5993.4', 'snap-split-off-limit', * FROM topology.TopoGeo_addLinestring(
tolerance => 2
SELECT NULL FROM topology.DropTopology ('t5993');
+-- See https://trac.osgeo.org/postgis/ticket/6023
+SELECT NULL FROM topology.CreateTopology ('t6023');
+SELECT NULL FROM topology.TopoGeo_addLinestring('t6023',
+ 'LINESTRING(
+ 11.230021066287687 62.84898276648437,
+ 11.230170431987244 62.84904481447776,
+ 11.230117909393426 62.8489943480894,
+ 11.230121356631185 62.848967479934664,
+ )',-1);
+SELECT 't6023.1', 'errors', (array_agg(v.error))[1] FROM topology.ValidateTopology('t6023') v;
+ 'LINESTRING(
+ 11.23020501303477 62.84900750109812,
+ 11.230120879533905 62.8489711984873,
+ 11.230120879533454 62.84897119848748
+ )', 0);
+SELECT 't6023.2', 'errors', (array_agg(v.error))[1] FROM topology.ValidateTopology('t6023') v;
+SELECT NULL FROM topology.DropTopology ('t6023');
diff --git a/topology/test/regress/topogeo_addlinestring_expected b/topology/test/regress/topogeo_addlinestring_expected
index a9ecae7b9..f80416f71 100644
--- a/topology/test/regress/topogeo_addlinestring_expected
+++ b/topology/test/regress/topogeo_addlinestring_expected
@@ -233,3 +233,5 @@ ERROR: Adding line to topology requires creating more edges than the requested
ERROR: Adding line to topology requires creating more edges than the requested limit of 1
#5993.3|double-split-in-limit|1
+t6023.1|errors|
+t6023.2|errors|
Summary of changes:
liblwgeom/cunit/cu_ptarray.c | 11 ++++++++++
liblwgeom/ptarray.c | 6 ++++++
topology/test/regress/topogeo_addlinestring.sql | 24 ++++++++++++++++++++++
.../test/regress/topogeo_addlinestring_expected | 2 ++
4 files changed, 43 insertions(+)
hooks/post-receive
