[SCM] PostGIS branch stable-3.6 updated. 3.6.1-10-g80eefad13
git at osgeo.org
git at osgeo.org
Tue Jan 13 07:24:52 PST 2026
the project "PostGIS".
The branch, stable-3.6 has been updated
via 80eefad13bd00d1e56d2bec36cd5140f87775ce4 (commit)
from f71e8d8a682cfaf72330ae70bdc24c1e1bbd7802 (commit)
revisions in full, below.
commit 80eefad13bd00d1e56d2bec36cd5140f87775ce4
Author: Sandro Santilli <strk at kbt.io>
Date: Tue Jan 13 12:05:57 2026 +0100
Fix robustness issue in ptarray_contains_point
References #6023 in 3.6 branch (3.6.2dev)
Includes unit test
diff --git a/liblwgeom/cunit/cu_ptarray.c b/liblwgeom/cunit/cu_ptarray.c
index 99c689ac2..6d8ea2faa 100644
--- a/liblwgeom/cunit/cu_ptarray.c
+++ b/liblwgeom/cunit/cu_ptarray.c
@@ -426,6 +426,17 @@ static void test_ptarray_contains_point()
rv = ptarray_contains_point(pa, &pt);
CU_ASSERT_EQUAL(rv, LW_INSIDE);
+ lwline_free(lwline);
+ /* Test for https://trac.osgeo.org/postgis/ticket/6023 */
+ lwline = lwgeom_as_lwline(lwgeom_from_text("LINESTRING(11.230120879533454 62.84897119848748,11.230120879533905 62.8489711984873,11.23020501303477 62.84900750109812,11.230170431987244 62.84904481447776,11.230117909393426 62.8489943480894,11.230120879533454 62.84897119848748)"));
+ pa = lwline->points;
+ pt = getPoint2d(lwline->points, 0);
+ rv = ptarray_contains_point(pa, &pt);
+ ASSERT_INT_EQUAL(rv, LW_BOUNDARY);
diff --git a/liblwgeom/ptarray.c b/liblwgeom/ptarray.c
index 2bc6126b5..2afb12c44 100644
--- a/liblwgeom/ptarray.c
+++ b/liblwgeom/ptarray.c
@@ -768,6 +768,12 @@ ptarray_contains_point(const POINTARRAY *pa, const POINT2D *pt)
seg2 = getPoint2d_cp(pa, i);
+ /* This is required for robustness, see #6023 */
+ if (p2d_same(seg1, pt))
+ return LW_BOUNDARY;
/* Zero length segments are ignored. */
if (p2d_same(seg1, seg2))
Summary of changes:
liblwgeom/cunit/cu_ptarray.c | 11 +++++++++++
liblwgeom/ptarray.c | 6 ++++++
2 files changed, 17 insertions(+)
hooks/post-receive
