[SCM] PostGIS branch stable-3.5 updated. 3.5.4-12-g3ec8542a9
Tue Jan 13 07:32:47 PST 2026
the project "PostGIS".
The branch, stable-3.5 has been updated
       via  3ec8542a9ca9b3a6edcb662731108e22f1779b91 (commit)
      from  9edefcf512798655375eb7ae6a0820546f1d45c9 (commit)
revisions in full, below.
commit 3ec8542a9ca9b3a6edcb662731108e22f1779b91
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Jan 13 12:05:57 2026 +0100
    Fix robustness issue in ptarray_contains_point
    References #6023 in 3.5 branch (3.5.5dev)
    Includes unit test
diff --git a/NEWS b/NEWS
index 8aef123f7..3acc169ad 100644
--- a/NEWS
+++ b/NEWS
@@ -1,4 +1,4 @@
-PostGIS 3.5.5
+PostGIS 3.5.5dev
 xxxx/xx/xx
 To take advantage of all postgis_sfcgal extension features SFCGAL 1.5+ is needed.
@@ -8,6 +8,7 @@ PostgreSQL 12-18 required. GEOS 3.8+ required. Proj 6.1+ required.
   - #5959, #5984, Prevent histogram target overflow when analysing massive tables (Darafei Praliaskouski)
   - #6020, schema qualify call in ST_MPointFromText (Paul Ramsey)
+  - #6023, Fix robustness issue in ptarray_contains_point (Sandro Santilli)
   - #6027, Fix RemoveUnusedPrimitives without topology in search_path (Sandro Santilli)
   - #6028, crash indexing malformed empty polygon (Paul Ramsey)
diff --git a/liblwgeom/cunit/cu_ptarray.c b/liblwgeom/cunit/cu_ptarray.c
index bfb830284..bb1f43925 100644
--- a/liblwgeom/cunit/cu_ptarray.c
+++ b/liblwgeom/cunit/cu_ptarray.c
@@ -426,6 +426,17 @@ static void test_ptarray_contains_point()
 	rv = ptarray_contains_point(pa, &pt);
 	CU_ASSERT_EQUAL(rv, LW_INSIDE);
+	lwline_free(lwline);
+	/* Test for https://trac.osgeo.org/postgis/ticket/6023 */
+	lwline = lwgeom_as_lwline(lwgeom_from_text("LINESTRING(11.230120879533454 62.84897119848748,11.230120879533905 62.8489711984873,11.23020501303477 62.84900750109812,11.230170431987244 62.84904481447776,11.230117909393426 62.8489943480894,11.230120879533454 62.84897119848748)"));
+	pa = lwline->points;
+	pt = getPoint2d(lwline->points, 0);
+	rv = ptarray_contains_point(pa, &pt);
+	ASSERT_INT_EQUAL(rv, LW_BOUNDARY);
diff --git a/liblwgeom/ptarray.c b/liblwgeom/ptarray.c
index 2369bff18..7a5cf234a 100644
--- a/liblwgeom/ptarray.c
+++ b/liblwgeom/ptarray.c
@@ -768,6 +768,12 @@ ptarray_contains_point(const POINTARRAY *pa, const POINT2D *pt)
 		seg2 = getPoint2d_cp(pa, i);
+		/* This is required for robustness, see #6023 */
+		if (p2d_same(seg1, pt))
+			return LW_BOUNDARY;
 		/* Zero length segments are ignored. */
 		if (p2d_same(seg1, seg2))
Summary of changes:
 NEWS                         |  3 ++-
 liblwgeom/cunit/cu_ptarray.c | 11 +++++++++++
 liblwgeom/ptarray.c          |  6 ++++++
 3 files changed, 19 insertions(+), 1 deletion(-)
hooks/post-receive
