[SCM] PostGIS branch master updated. 3.6.0rc2-281-g17d0890cc
Wed Jan 14 02:44:47 PST 2026
the project "PostGIS".
       via  17d0890cc6d156c7e3e482c3c02b221184f3a027 (commit)
      from  3a6b9e454c1ce9a53f14ad87fefcf8cf2ee1ad33 (commit)
revisions in full, below.
commit 17d0890cc6d156c7e3e482c3c02b221184f3a027
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Jan 14 11:44:03 2026 +0100
    Reword error on internal functions returning geometry-less nodes
diff --git a/liblwgeom/topo/lwgeom_topo.c b/liblwgeom/topo/lwgeom_topo.c
index 5dd4b1f6d..359ba1615 100644
--- a/liblwgeom/topo/lwgeom_topo.c
+++ b/liblwgeom/topo/lwgeom_topo.c
@@ -698,17 +698,21 @@ _lwt_CheckEdgeCrossing( LWT_TOPOLOGY* topo,
 	  POINT2D p;
 	  LWT_ISO_NODE *node = &(nodes[i]);
-	  if (node->node_id == start_node)
-		  continue;
-	  if (node->node_id == end_node)
-		  continue;
+	  LWT_ELEMID node_id = node->node_id;
 	  /* check if the edge contains this node (not on boundary) */
 	  /* ST_RelateMatch(rec.relate, 'T********') */
+	  /* skip boundary nodes */
+	  if (node_id == start_node) continue;
+	  if (node_id == end_node) continue;
 	  if (!node->geom || !node->geom->point || !node->geom->point->npoints)
 		  GEOSGeom_destroy(edgegg);
 		  _lwt_release_nodes(nodes, num_nodes);
-		  lwerror("SQL/MM Spatial exception - geometry crosses a node");
+		  lwerror("Internal error: lwt_be_getNodeWithinBox2D returned node %"
+		          LWTFMT_ELEMID " with no vertices", node_id);
 		  return -1;
Summary of changes:
 liblwgeom/topo/lwgeom_topo.c | 14 +++++++++-----
 1 file changed, 9 insertions(+), 5 deletions(-)
hooks/post-receive
