[PostGIS] #6036: Use PG_MODULE_MAGIC_EXT for Pg18+
trac at osgeo.org
Fri Jan 16 14:52:32 PST 2026
Reporter: pramsey | Owner: pramsey
Type: enhancement | Status: closed
Priority: medium | Milestone: PostGIS 3.7.0
Component: postgis | Version: master
Resolution: fixed | Keywords:
Changes (by Paul Ramsey <pramsey@…>):
* resolution: => fixed
* status: assigned => closed
Comment:
In [changeset:"c460d6928c131cc0ae973200afacfa8c47cc4953/git" c460d69/git]:
{{{#!CommitTicketReference repository="git"
revision="c460d6928c131cc0ae973200afacfa8c47cc4953"
Add use of PG_MODULE_MAGIC_EXT for pg>=18
Allows server to poll the version and extension name from the
dynamically loaded library. Potentially could perform the
same scripts-vs-libs version check we do, but on all
extensions. Automatic update, could we have?
Closes #6036
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6036#comment:2>
